DEL could answer this better, but I'd say probably not. This is more or less for us hackers , but, the chinese changed the BLF A6 driver anyway, so they did not 100% duplicate the wight FET+1 driver we started with. The soldering problems were not a design issue - it was a manufacturing/production/QC issue - sloppy and rushed basically, from the looks of it.
I work for a manufacturing company, and we insist our PCB suppliers test the boards before shipped to us. We will design/engineer/produce test fixtures for them to use in order to achieve as close to 0% DOA failure rate as possible. This is one way of doing QC - you want this done as close to the source as possible.
Sorry to say the way our group buys are done here are far from ideal in time and cost. This whole cycle of sample testing in the US is very inefficient and wasteful, but not much other choices unfortunately...
Let me verify the clearance under an 85 with bent pins tonight. I'm pretty sure that there is height for a 0805 1uF, but I haven't tested that idea yet.
Think it will depend on the voltage rating as well - higher the voltage, bigger the part. Think we use 16v rated caps in general. I believe it helps having a higher rating - not sure.
Gap under an 85 with legs pushed in most of the way to touching the chip is .028" to .029" (.72mm). My 1uF caps in an 0805 package (I believe 16V rated) measure .034" to .035" (.88mm). So it seems one could get away with a cap under the MCU as solder can quite easily bridge a .006" gap.
Or, the gap could be completely eliminated by slightly straightening the legs.
I've been away from this game for far too long; it's time to jump back in again. I had to force myself away just when things were getting interesting around here so that I could focus on some of my "other work".
The layout on that 85 driver I did really stinks...way too much space around the MCU, but I figured that it would be easy to flash the thing a million times. It looks like it also needed a bodge capacitor to work right. I guess I should have labeled it "alpha".
I haven't read through everything here, but a capacitor underneath the MCU sounds like a really bad idea unless you like tedious leg bending and soldering on every driver. I'm sure we can make it work without resorting to stuff like that.
Welcome Back!! You were missed! A scope on the signal lines sure would come in handy for this, I don't have the tools. Had success with the extra caps though, and definitely we've had some great help going on with texaspyro and DEL stepping in.
Not sure if you read it, but I finally got a good fix to the hi->OFF->moon flashing problem -- with that sequence, many times got a quick flash when moon mode starts. It looks like it's 100% resolved now in my latest firmware update - I solved it in code, not hardware, explained above somewhere... I've seen this flashy thing happen on power tail switch's too - wonder if it can be fixed in a similar way. Haven't looked into it yet.
On the high amp problem (caps), I believe TK has been getting the same reports coming in on her 25 based driver. Not sure if she is following this thread though.
Sort of agree - I'm leaning towards the bent pin solution being what we can do with our small runs, hobbyists, etc., but not a solution for large runs going forward.
If space is needed, I think it's good idea. I bend all my 85 pins anyway because they clip some much easier and the clip holds much more securely. If you haven't tried it, you should.
Another benefit of the bent legs is the MCU sits more proud and you can put resistor right up to the legs without programming clip interference.
I wonder if we really need LED - pads when the FET Drain tab available to solder to. It's nice to have a spot that is labelled and a spot that will fail first from mechanical stress, but is it really necessary when space is short?
Pyro1son,
The FET Drain Pad and LED _ Pad appear close to shorting with the pill. It's probably fine, but it looks like the FET could be slid closer to the ground ring edge.
I have dealt with the issue on a lot of drivers and have scoped it when it happens. Usually from a 3.8v-3.9v supply you'll see a 6V+ peak with 2V-3V peak-to-peak ripple (BAD). They actually run with a really dirty supply but when you get them up past 5.5V-6V it's going to have some issues. We are really pushing the MCU pretty hard switching these low-RDS but high-gate-charge FETs directly from the MCU pin, especially without any gate resistor. You can end up with either too little decoupling or if you have the cap. behind the diode you can get quite a bit of boosting. You also get a lot of ground bounce from the FET switching. There are a lot of layout tweaks that can make them run without expensive or extra parts.
You do absolutely need at least a small LED- pad if you want to use anything but an LFPAK56 FET. The SiR800DP, for example, does not really work without some extra exposed pad out the back. You can sacrifice it if you only use an LFPAK56, but I know that quite a few use the SiR800DP and it has proven to be a top performer.
Think you really need some pad space for LED-, at least with the SIR800DP FET - there's nothing on the FET there to solder to. That was my issue with Richard's board.
I’ve moved the FET away from the edge and the 2nd CAP from under the MCU as I just don’t like the Idea. I would rather just put both caps on the bottom of the board.
I'm liking it . Nice to have a pin #3 pad.This last one is still with a 13A footprint, I believe. It's still a lot to squeeze in.
I'm think'n we'll need it both ways - one design with the full 45/85 footprint, and one with the 13A/25 size. I'm thinking Richard will be working on a design as well.
Should be noted - this happened to me twice already. The 380 7135's seem to want 5 as a PWM value at a minimum (moon mode) - not sure if this has to do with the faster PWM rate of PHASE correct mode on the 25/45/85's when run at 8 Mhz.
So what I'm using now is using 3 for 350 7135's and 5 for 380 7135's as a standard practice. The 5 on a 380 may even be lower output than a 3 for a 350.
Also, I made a change in the firmware that was annoying me. For going into lock-out with the 2 clicks, then click/hold, I made the hold time shorter so you don't have to see that annoying strobe. So basically instead of strobe for about one second, you get the 4 short blinks - much more pleasing, easier to enter and confirm you are in lock-out. I checked the manual and didn't see an impact there - I didn't get too specific on hold time in the manual.
Update, more changes to the firmware:
Couple more things that kind of bugged me:
losing your place in the configuration settings. With 5 settings, hard sometimes to track if your are on setting #3 (mode ordering) or #4 (mode memory) for example. So, I now do 2 fast blinks, then blink the setting # when entering a configuration setting. When you get to 5 of course, it takes some time to do 5 blinks, but hoping it's easier to track now.
No way to completely bail out of configuration mode - you can skip to the next setting by click/hold, but still takes a while. So, I added a long hold option to bail out completely. So in configuration mode, a hold of about 1/2 sec skips to next, while a hold of 1.1 secs bails out, signaled by 5 fast blinks. I increased the config mode exit blinks from 3 to 5, since they blink faster now.
Not yet posted... Will be doing more testing... Once again, the SupFire M2-Z light is working great for re-programming/testing . Thanks Richard!
Just want to start by saying thanks to everyone putting time in on this project.
I have an idea about making some extra room for component placement on this driver. I dont know anything about running the electrical traces so if this sounds dumb please forgive.
What if the foot print for the larger micro 45/85 and the FED were put on the bottom ( the spring side) and all of the other components were put on the top. The work around for loosing the spring pad on the bottom could be mechanical.
The battery + could be a large via in the center (like in some of the above desings) that we could either just solder a rivet into or use a machined part with a larger top that a spring could be soldered to.
Like this.
I would think the top components could then be reflowed on and the bottom 2 could be hand soldered easily. Plus if only the rivet was used for the + contact the micro could be reflashed without unsoldering the driver from the pill.
Copper rivets are cheap too, a box of like 250 is ten bucks.
