Voltage sag under load - Some figures
I thought I would note some voltage sag figures .. Used 4 batteries
Trustfire Flame 18650
Yezl 18650
Xtar 2200
Ultrafire BRC3600
I discharged at 1A - 500mA and 200mA to see battery voltage sag at various loads ..
Measurements were noted at 15 seconds , 30 seconds and 60 seconds ...
@ 1A the largest amount of battery sag noted was to 3.72v , that's almost half a volt [ 0.46v of sag ]
Brand Starting Voltage 1A Discharge
Trustfire 4.21 3.81v-15sec, 3.78v-30sec, 3.75v-60sec
Yezl 4.2 3.93v-15sec, 3.9v-30sec, 3.89v-60sec
BRC 3600 4.18 3.73v-15sec, 3.72v-30sec, 3.72v-60sec
Xtar 4.19 3.9v-15sec, 3.9v-30sec, 3.87v-60sec
Brand Starting Voltage 500mA Discharge
Trustfire 4.19 3.99v-15sec, 3.99v-30sec, 3.96v-60sec
Yezl 4.19 4.05v-15sec, 4.02v-30sec, 4.02v-60sec
BRC 3600 4.19 3.87v-15sec, 3.87v-30sec, 3.87v-60sec
Xtar 4.2 4.08v-15sec, 4.08v-30sec, 4.06v-60sec
Brand Starting Voltage 200mA Discharge
Trustfire 4.19 4.11v-15sec, 4.11v-30sec, 4.11v-60sec
Yezl 4.2 4.16v-15sec, 4.15v-30sec, 4.14v-60sec
BRC 3600 4.19 4.11v-15sec, 4.11v-30sec, 4.11v-60sec
Xtar 4.19 4.14v-15sec, 4.14v-30sec, 4.14v-60sec
Updated = Going the other way ...
Time to charge the batteries ...
Ive gone with the BRC3600 [ since this is time consuming ]
1A charge rate :
Batt resting Voltage = 3.62v [ after 1A discharge to 3v ]
Put on the charger , and after the charger reached 1A the voltage reading from the charger was 4.06v , if its the battery voltage , then thats a 0.44v increase .
[ There must be some voltage overhead - higher charge voltage than batt voltage , but what is it ? = will have to test for this as time permits ] [ buy data logging MM ]
500mA Charge
Batt resting Voltage = 3.64v [ after 1A discharge to 3v ]
Put on the charger , after charge current reached 500mA , the voltage reading from the charger was some 3.96/7volts , a 0.32v increase
200mA Charge
Batt resting Voltage = 3.66v
Put on the charger , after reaching 200mA , voltage reading was 3.85v , after 60 seconds 3.83v and after 90 seconds 3.82v [ well that was different , voltage actually dropping under charge , one possible reason comes to mind , = the battery had been rested after discharge - takes a long time to charge @ 200mA - so wanted to do most of it while I slept - so it may have initially resisted charging [ more than usual ] , but as the current flowed into the battery the resistance dissipated and the voltage dropped ] = I could be wrong ! [ so related to storing a discharged battery for several hours - Like 10 ]
Charge VS Discharge
1A - Discharge = - 0.46v , Charge = +0.44v
500mA - Discharge = -0.32v , Charge = +0.32v
200mA - Discharge = -0.08v , Charge = +0.16v
Hmmm , interesting .
Thanks, that's why the regulated lights would give higher current readings for some batteries.
Sag depends on internal resistance of cells mostly. If the discharge current exactly 1A, and you measure the sag whitin 1-2sec, you get the internal resistance. Sag= internal resistance.
I use 3-5 watt low value(2-5ohms) resistances for measuring internal resistance usualy. There are a couple of methods to calculate the internal resistance value, you have to use simply Kirchhoff and Ohm's law.
Unfortunately I cheap'ed out on the Hobby charger , 1A Max Discharge ...
ATM Im looking at spending money on a data logging Multimeter ... Maybe the last purchase for 2011 , Ive spent plenty in the last month or so .
Thanks for providing the test results, very helpful information. Would you happen to have 26650 batteries to compare?
-JH
Yeah, that would be nice.
No 26650 batteries [ in my collection ] , though there have been some tempting lights lately for that battery .
1A charge rate :
500mA Charge
Charge VS Discharge
1A - Discharge = 0.46v , Charge = 0.44v
500mA - Discharge = 0.32v , Charge = 0.32v
200mA Charge
Charge VS Discharge
200mA - Discharge = 0.08v , Charge = 0.16v
