Conformation here with the two lights I used.
S2+ tailcap fits on A6 body but not the other way around.
hat tip to DARCANGEL in the F13 thread, 1/18/2015
And just before that, in the same thread, also said
hat tip to escereal
at: EAGLE EYE X6 XPL HI V21A 1200lunens LED flashlight Free shipping $22.13 — EAGLE EYE X6 XPL HI V21A
AAA Legos:
Maratac, Lumintop Tool, Thrunite, Prometheus Beta all swap
Maratac head on Beta Body (did not light, Maratac pill set too deep, ymmv), and Beta head on Maratac body (works!)
Thrunite head, Maratac body (works!)
Beta head, Thrunite body (works!)
Maratac head on Tool body, and vice versa (both swaps work!)
This ones a bit of a crazy one…
Takes 3 flashlights parts.
1x Ultrafire SK68, 1x Foursevens MLR2 and 1x Ultrafire C3 extension tube:
Take the switch from the Sk68, the extension tube from a C3 and stick in place of the ML2 tube.
You can now use AA and 14500 batteries with the MLR2 head!
Eagle Eyes, X6, SE body fits into Convoy S2 head and the S2 body fits on the X6 head. The S2 tailcap fits on the X6 body but X6 tailcap doesn’t work with S2 body. (similar to what hank posted earlier)
The old style extension tube for the Convoy C8 (from Fasttech) fits onto the Jacob body however, the tailcap for the jacob is a bit weird (requires a lot of tube to go into the tailcap) so now, the Jacob has a C8 tailcap as well.
Note here what you find does and doesn’t lego together, collect them all ….
Remember as noted above:
- even several of the very exact same flashlight may not have interchangeable parts.
Reports are reliable only for the exact parts someone checks, not generally safe to assume true for any particular model.
My guess is Chinese budget flashlights are assembled by people reaching into a big bin’o’parts and trying them until they find a head, body, and tailcap that all are close enough to spec to screw together and not fall apart mostly.
For any given flashlight, some parts fit tight, some are loose, some won’t fit at all, and some are just right.
How to headswap your way to an N219 Maratac, and a Maratac clickie
Tool and Maratac, both swaps work
How to headswap your way to an N219 Thrunite, for the cost of a worm.
Worm head works on Maratac, as well as on Thrunite Ti
3 out of 4 combos work. Only the Worm body with Maratac head does not work, but I dont use the worm body anyway, it lacks reversible pocket clip.
Cool photos. I own several of these lights, too:
Out of curiosity, what’s with all the similarities between the Maratac lights and the Lumintop lights? I know Lumintop makes the Promethus Beta QR2 I’ve got, but do they also build Maratac’s lights, too?
imho, yes. Based on the appearance, the Worm, Beta, Maratac, and Tool are all Lumintop.
Love your copper pic too!
Beta head also works on a Maratac and on a Thrunite
BetaTac:
BetaNite:
and ThruTac, aka MaraNite
Huh, I’ve got a Thrunite Ti as well. Never really even tried to lego them together, although they are very similar lights.
So I’m pretty sure that Thrunite builds their own lights, so it can be safely assumed that those two lights are built by different companies even though they’re very similar. Makes me wonder even more about Maratac. I guess they could have their own production facility and just be making very similar lights to the Lumintop line. I’d love to know something definite on that.
I dont see any reason to swap a Thrunite and a Maratac, since neither offers High CRI. fwiw, the thrunite head will not light on a worm body, but it will light on the Maratac body. The Maratac head will not light on a Thrunite body, nor on a Worm body, Maratac head lights only on a Tool.
you could ask CountyComm
Im just stating my opinion from personal observation, nothing official
Imo yes the Thrunite Company is separate from Lumintop. And No, CountyComm is not a producer of anything, imo they are just a US company reselling Chinese imports (supposedly to the US Military). Same with darksucks.com (Prometheus Beta) they are a US company reselling chinese imports too.
Note also that Thrunite uses MUCH lower low and Medium than Maratac and Tool, plus the Thrunite mode sequence is always LMH, Thrunite is not offered in MLH sequence like the Maratac and Tool. iow, Thrunite driver is very different than Lumintop driver. Also, Thrunite driver is NoPWM, while prior to Oct2015 Maratac, Tool and Beta were all PWM driven.
Look at these LED rings on post Sept 2015 production runs of Maratac, Tool, and Worm… identical… to me they all come from the same Lumintop factory.
A placeholder for khas who has big Lego news in another thread:
khas
Skilhunt H02 shorty
I’ve got two bare BLF A6 tubes that [lego with the Skilhunt H02]
see Group Buy Active >> Skilhunt H15 and more >> Review Inside for pictures, it’s around this point in the thread:
Sun, 01/17/2016 - 03:20 #184
Anyone tried this BLF A6 Flashlight 18350 Body Extension Tube on convoy s2? Will this fit on the s2?
Reminder, report what you actually know — there’s enough variation that even several samples of “exactly the same light” may not swap parts easily.
We can’t tell you what you will find out with the parts you get — not with any real assurance it will or won’t work.
Nope. It doesn’t fit.
(if you’re set to view 300 comments per page, this should work: BLF Kronos X6/X5 GB - Group Buy now closed.
The bare A6 tubes that don’t work on the BLF A6 fits a Skilhunt H02 :
It also fits a Skilhunt H15 but you need a tailcap from a H02 :
In the headband :
Family foto :
EDITED, more thorough look:
The older Solarforce chromed steel clip (meant for the Solarforce tail threads) happen to very nicely fit over the KX5 head-to-bezel thread.
This is the old “deep carry/reversible” clip that, sad to say, Solarforce no longer has for sale.
It’s chromed steel — quite thin, and only slightly thicker than the gap on my KX5 between the head and bezel.
Check yours — see if there’s a gap between bezel and head, or if the bezel screws down tight on the head
The ring of the clip can be made even thinner with a little sanding, as the chrome plating made it rough and bumpy.
(The bezel is at the bottom, then the clip, then the ribbed part of the head is at the top, in this picture)
The regular Solarforce clip sold now does not fit, it has a smaller opening and is thicker (made of aluminum)
BUT SEE the big X5/X6 thread at Mon, 02/08/2016 - 14:24 #5594
search for “reflector fitment” for a caution to check
