Is v009 the latest and best version to order for a FET+7135 driver?
wight’s profile says he has been absent for a while so there were no updates in the OP.
thanks.
thanks.
Pablo - The masking is easy to scrape off - I use an exacto type knife with a curved edge - works great, never had a problem - the curved edge is the important part, no point to deep scratch. Actually I do this all the time when I want to expose copper for grounds, or for other traces, etc.
tech - Well, I'm still using these v009's. Richard has an OSHPark design too, as well as other variations out there, maybe by PD68 and pyroson1.
This wight v009 was the board design the BLF A6 is based on.
Mmmm… i think i have a perfect knive for that somewhere, I might give it a try.
Thank you, Tom E.
guess I’ll order the v009’s
I think you can use really fine sandpaper, just lay it on a flat surface and you can sand off mask coating! At least I could try that method…
Yes, sanding is an option, but i have experienced lapping tiny things very difficult to do even, being borders worn much faster than center.
BTW, i already have a new boards bach on a new panel, nice good service from OSH park :bigsmile:
This is my first time building the a driver on my own. I have everything needed my question is do I flash the attiny before or after I bake it on the pcb? I assume I can flash and re-flash in circuit.
Thanks,
Neil
Neil - You can do it before or after, I've done them both ways.
Before: the SOIC-8 clip does seem to work fine with the "in air" MCU. Just be sure you get it positioned correctly before releasing pressure on the clip - clamping down on the MCU pins. I'm always concerned I'm gonna bend pins, but it never happened, but again, I'm extra careful before I let the clip clamp down on the pins in-air.
After: as long as you positioned the parts correctly, on this board you should be able to get a good clip on the MCU. Be sure your clip is wired correctly with a good ground. (lot of earlier posts and ref. pics and posts had it wrong!!). Also, I found it helps cleaning up the MCU pins with isopropyl alcohol to get off any residual flux from the reflow. I like using a small stiff brush.
Note: I updated the flashlight wiki page on the AVR Drivers for the ground pin connection here: http://flashlightwiki.com/AVR_Drivers. The ground is on dongle side pin #10 (or #8), not pin #4.
I was told to use a horse hair brush to clean pcbs; so I went to a nearby horse stable (fairly common here) and got some hair for free. bundled them into a brush and it works great.
Interesting bout the horse hair... How could you make a brush though?
For the grnd wire, it worked for me a long time not having it wired correctly, but had occasional problems, thinking it was the clip, etc. - intermittent issues. Once I corrected the grnd wire, worked sooo much better. Only problems I've had since is when there's flux on the pins, if I didn't clean them first. After cleaning, works all the time. Been trying to make a habit of always cleaning, since I'm probably getting flux contamination on the clip , and could build up. The clip can always be cleaned as well.
Thank you so much for the detailed info.
Neil
horsehair is supposed to be an anti-static material (not easily charged electrically).
I stole my girlfriends’ old makeup brush and replaced / glued the horsehair in. Hope she is ok with that.
Shrinkwrap-and-glue a bundle of horsehair over the end of a stick. Google ‘handmade brush’ or ‘homemade brush’ for pictures.
Trim the end with a razor for applying paint, or leave the end variable for ‘dusting’
I think this is the right thread to ask.
Are there any firmwares except toykeeper’s ready-to-flash ?
Could you provide me a link ?
Not sure. I don't usually post HEX files because I build mine on demand for modes, tweaked, turbo timeout setup, etc., so not a good idea, unless you have a fixed, static setup: same hardware, same modes, same options.
This is why I'm going with the more versatile programmable UI, so we can use a common hex file, then reconfigure it after it's burned in, but this requires more memory than a 13A has, so why we are migrating to the Tiny25 and Tiny85.
Thanks for your answer. I’m new to the whole programming thing , and I don’t know how to do edit modes on code and so on.
I’m still searching , but if you had any recommendations (where to start from , or some guides) it would be great.
Thanks again
CRX's incredible reference thread, https://budgetlightforum.com/t/-/23020, has a section for programming drivers - you will find some useful info there.
I'm using the latest Atmel Studio 7, free download here: http://www.atmel.com/tools/atmelstudio.aspx. You can begin with that and go from there, if you haven't dnld'ed it already.
Looks like plenty of interesting discussion happened on this one while I was out. I think that I’ve skimmed it all, but I didn’t necessarily absorb everything and I know that some of this stuff gets discussed in other threads too.
Hi Alex!! Wow - welcome back!
I was getting a flash going from hi/turbo to moon (on this FET+1 w/ATTiny85, SIR800DP FET) that I was able to solve in firmware (e-switch firmware called "Narsil"). Had to do with removing redundant setting of PWM modes.
For a power switch setup (also on this FET+1 driver, ATTiny25 w/SIR800DP), I tried several things in firmware with no luck, then added a 12K resistor across the FET (gate resistor) and it solved it perfectly.
One guy, think an EE, found a FET that didn't have the flash. I did some amps tests and the 12K resistor seemed to have no effect - I'm pretty happy with the fix.
25, 45, and 85's seem to have their own problems in high amp setups. Caps seem to fix it - I add a 0.1 uF cap across the MCU grnd and VCC pins and it fixed it with the e-switch firmware/setup. On power switch setups, I stacked a 2nd 10 uF cap on the C1 cap and it fixed it. The problem is in either just hi/turbo or any FET modes, the MCU flakes out - resets sometimes, or get weird blinks, etc.
I agree with more exposure of the ground ring - would help, I've done lots of scraping.
Thanks Tom E.
EDIT: added strikethrough for “DOPE!” moment. See posts below for correction(s).
