Pablo - The masking is easy to scrape off - I use an exacto type knife with a curved edge - works great, never had a problem - the curved edge is the important part, no point to deep scratch. Actually I do this all the time when I want to expose copper for grounds, or for other traces, etc.
tech - Well, I'm still using these v009's. Richard has an OSHPark design too, as well as other variations out there, maybe by PD68 and pyroson1.
This wight v009 was the board design the BLF A6 is based on.
This is my first time building the a driver on my own. I have everything needed my question is do I flash the attiny before or after I bake it on the pcb? I assume I can flash and re-flash in circuit.
Thanks,
Neil
Neil - You can do it before or after, I've done them both ways.
Before: the SOIC-8 clip does seem to work fine with the "in air" MCU. Just be sure you get it positioned correctly before releasing pressure on the clip - clamping down on the MCU pins. I'm always concerned I'm gonna bend pins, but it never happened, but again, I'm extra careful before I let the clip clamp down on the pins in-air.
After: as long as you positioned the parts correctly, on this board you should be able to get a good clip on the MCU. Be sure your clip is wired correctly with a good ground. (lot of earlier posts and ref. pics and posts had it wrong!!). Also, I found it helps cleaning up the MCU pins with isopropyl alcohol to get off any residual flux from the reflow. I like using a small stiff brush.
Note: I updated the flashlight wiki page on the AVR Drivers for the ground pin connection here: http://flashlightwiki.com/AVR_Drivers. The ground is on dongle side pin #10 (or #8), not pin #4.
I was told to use a horse hair brush to clean pcbs; so I went to a nearby horse stable (fairly common here) and got some hair for free. bundled them into a brush and it works great.
Interesting bout the horse hair... How could you make a brush though?
For the grnd wire, it worked for me a long time not having it wired correctly, but had occasional problems, thinking it was the clip, etc. - intermittent issues. Once I corrected the grnd wire, worked sooo much better. Only problems I've had since is when there's flux on the pins, if I didn't clean them first. After cleaning, works all the time. Been trying to make a habit of always cleaning, since I'm probably getting flux contamination on the clip , and could build up. The clip can always be cleaned as well.
Not sure. I don't usually post HEX files because I build mine on demand for modes, tweaked, turbo timeout setup, etc., so not a good idea, unless you have a fixed, static setup: same hardware, same modes, same options.
This is why I'm going with the more versatile programmable UI, so we can use a common hex file, then reconfigure it after it's burned in, but this requires more memory than a 13A has, so why we are migrating to the Tiny25 and Tiny85.
Thanks for your answer. I’m new to the whole programming thing , and I don’t know how to do edit modes on code and so on.
I’m still searching , but if you had any recommendations (where to start from , or some guides) it would be great.
CRX's incredible reference thread, https://budgetlightforum.com/t/-/23020, has a section for programming drivers - you will find some useful info there.
I'm using the latest Atmel Studio 7, free download here: http://www.atmel.com/tools/atmelstudio.aspx. You can begin with that and go from there, if you haven't dnld'ed it already.
Looks like plenty of interesting discussion happened on this one while I was out. I think that I’ve skimmed it all, but I didn’t necessarily absorb everything and I know that some of this stuff gets discussed in other threads too.
What’s the situation on “unwanted flashes”? I read Tom E’s post #18 over in pilotdog68’s TripleDown threadanddthoang’s post #231 in this thread. I also skimmed the discussion from TK, RMM, etc. From what I gathered there may be more than one “blink/flash” issue under discussion. Can someone get me up to speed on the current info?
I’m not sure what’s up with all of the OSH Park mistakes. I’ve certainly made some flagrant mistakes on other things with them in the past, but as far as I know everything is pretty kosher with this one. I definitely do go right up to the minimum tolerances sometimes, but I do not see how that would cause such flagrant issues with the resist mask…
I’m inclined to agree with anyone who thinks that more of the GND ring should be exposed. Maybe I picked up the skinny-GND-ring habit form Mattaus, who knows. I do prefer to create a “dam” of resist around any component pads that are near the edge of the board. That helps prevent components from scooting towards the edge of the board when soldered, which can create fitment/shorting issues once installed in a light. I don’t always achieve this of course, it’s just my preference. In any case, Eagle doesn’t really have an automatic way to do make sure those dams happen - so the easiest solution is a skinny GND ring. I think I have an updated version of this board with a larger GND ring. I’ll see about dragging that out.
I was getting a flash going from hi/turbo to moon (on this FET+1 w/ATTiny85, SIR800DP FET) that I was able to solve in firmware (e-switch firmware called "Narsil"). Had to do with removing redundant setting of PWM modes.
For a power switch setup (also on this FET+1 driver, ATTiny25 w/SIR800DP), I tried several things in firmware with no luck, then added a 12K resistor across the FET (gate resistor) and it solved it perfectly.
One guy, think an EE, found a FET that didn't have the flash. I did some amps tests and the 12K resistor seemed to have no effect - I'm pretty happy with the fix.
25, 45, and 85's seem to have their own problems in high amp setups. Caps seem to fix it - I add a 0.1 uF cap across the MCU grnd and VCC pins and it fixed it with the e-switch firmware/setup. On power switch setups, I stacked a 2nd 10 uF cap on the C1 cap and it fixed it. The problem is in either just hi/turbo or any FET modes, the MCU flakes out - resets sometimes, or get weird blinks, etc.
I agree with more exposure of the ground ring - would help, I've done lots of scraping.
So that’s a 12k pulldown resistor on the gate? (EG the resistor is connected to the “gate” pin and to “GND”?)
How are people feeling about 0603 sized components these days? Sourcing is not an issue: the days of using Nanjg boards for donor components are well past. Almost everyone building a driver of this type is certainly sourcing parts elsewhere. It’s just a question of whether people can handle soldering the smaller size stuff.
I’d say that the v009 layout of this board does not provide very good filtering for the MCU. We got away with it before, but it looks like the seams are coming out now. A decent sized overhaul is in order to fix that… and frankly I think it’s probably time to start breaking these boards out into single cell and multi-cell rather than “universal”. In the past I liked to keep these designs as flexible as possible, but the more we push the limits the more specific they need to be if all else remains the same. The 17mm boards cost <$0.75/ea from OSH Park, so it’s hard for me to feel bad about making them less universal. In order to meet these new design goals it seems like something’s got to give - either step down to smaller components, build less universal board layouts, move to some pricier parts, or all of the above…
Speaking of pricier parts, back to the LDO discussion. From my looking at the ATtiny85 datasheet in Section 21.3 / page 163… looks like 8Mhz @ 2.5v has Atmel’s blessing. So maybe a 2.5v LDO if we wanted to use an LDO in single-cell applications? I’m not 100% confident that we even want to do that. (For the higher voltage stuff I’m pretty confident!)
EDIT: added strikethrough for “DOPE!” moment. See posts below for correction(s).
I don't see 0603 being a problem, as most people would be using paste/heat gun rather than manually soldering these things with an iron. If the size saved is going to make a board possible where it was otherwise not, then I say go for it.
The additional/larger Cap seems to overcome the MCU spike issue on the current boards, so another revision of this design may not be time well invested. I think a new design targeting multi-cell applications(Buck w/ATtiny) would now be more sought after.
