What i really want to see is some numbers on the throw kings in there sizes, the dedomed XP-G2 S4 and/or XM-L2 U4.
If any of those makes some budget disruptive for the max thrower light market, killer numbers i will be really happy :). Because every other option for a ready made light with a reflector this big has always costed WAAAAAY over a $100 and the BOSS is about half that
And if they really haven’t screwed up heatsinking on it for a XP-G2/XM-L2 class emitter running flat out, there is no way a 1.2kg massive hunk of alu will not be able to eat that heat like nothing. Of course high amp XPH70 builds can overheat anything not aircooled but, i hope at least we get a nice shelf for the mcpcb.
Yes, I finally found this hoss of a light here in the forum. The name BOSS1 made me look. lol
Looks to me like the reflector is comparatively shallow for how wide it is, the head is pretty “square” so with some room for an emitter shelf and driver, the reflector might be on the shallow side. Not that that in itself is so horrible, but it would surely affect the ratio of hot spot to spill. The sample pictures from Palight seem to indicate it’s got a lot of spill, but the hot spot is still tight and concentrated. It’d be fun to exploit that…
1680 is easily doable out of an XM-L2, I’ve had one at 1980 before. Just saying. (and that was in an EE X6!) Remains to be seen if they really are pushing this one that hard. What’s that Tom, around 6A? 5.7? Will indeed need a good emitter shelf to tie it in to all that head mass…
I'm hoping we can get those hot FET's Mitko came across. We can't find any around, but he has a local source. All those high #'s of amps and throw Mitko's been getting from single cell lights were mostly achievable by that special FET he's been using, link here: http://www.a-power.com.tw/index.aspx?lang=eng&fn=product_list_pms&ID=104 -- click on datasheet, then Merge Documents.
Did you get any definite info on the head diameter?
I just requested custom sizes of a few UCLp lenses from Chris at flashlightlens.com, including for the new Convoy L2 and UranusFire 818, so they are shipped and on the way. If this is plain glass, thinking it is, then a UCLp would be an awesome upgrade. He's got sizes in 73, 76, 88, and 93 now, but sounds like he can turn over a custom size in plastic (UCLp) quick. Glass is a whole # story - needs mins and time. The big UCLp's get a bit pricey, and still have to see if the 2.25 mm thickness will work out ok.
This light looks like it's made for the EFEST 4200 26650 cell - best cell on the planet right now, least I know of... I got a few more on order, planning on running 4 of them in this. Really for max throw, it comes down to the quality/design of the reflector. Some designs can kill throw, and can't be tuned, but there are also serious variations from piece to piece in reflectors, so never can tell. A UCLp should give a nice boost on throw - they always do.
Wish I could read Chinese - wonder what the X960 means, was hoping it's 96 mm head or reflector . 960 doesn't seem to match up to anything else, unless it's just a sort of model #.
