Huh, okay then. Sounds reasonable to me. I’ve also got a few Zebra’s and I guess my opinion of what undyed ano looks like comes from them. And I’d never really considered the surface treatment before anodizing and its effects. Maybe armytek hits theirs with 80-grit before ano to get their matte finish. :bigsmile: Thanks Dale.
So yeah, something that basically looks like bare aluminum but has the strength of anodized sounds perfect. I’m in!
Thanks for the links KB. That should help add some understanding. It helped me to see what’s possible. I don’t have experience working with metals but Simon has confirmed that it would be clear anodizing, not just a coating so it should be pretty tough. I’ve posted pics of my 501B several times and that has a clear anodizing with a slight grey-blue hue but it is definitely clear as you can “clearly” see all the machining marks through the anodizing. When metal is well machined that can be a good thing. It’s always been a favorite of mine in the looks department and it’s held up very well. Because the holidays are upon us we will not see clear anodized lights from Convoy until early next year but I’ve expressed how much talk there is about new finishes like this and I think there is a very good chance the clear (bare) look may be extended to other models.
I may have mentioned it already but extra OP reflectors will be made along with the first run if the L6. Simon says he will make a batch of SMO reflectors after the initial run.
I don’t have a date yet. All I know at this point is that we are getting pretty close. I would guess within a month but I can’t make any promises. The last thing Simon told me on the status of the L6 is that he would take extra time to try to get better tints in the XHP70 as the only tint available through the Cree rep at the time was cool white. When I do know I will post the info here.
So…this uses xhp70 outputting 3500 lumen…at bout $60…and thrower
*Use 2x 26650 (Me only can afford TF 26650) :Sp
How long will it last when using 2 x 26650?
*When it is on the brightest mode?
Or , it have the programm that will auto drop the brightness?
How far *Estimated it will throw?
Me should be getting some… :bigsmile:
And yeah… i do agree that J20’s head is ugly…Ermm not that ugly, jus that i do not like it base on personal preference…
3500 lumens is just an estimate but Simon is putting a lot of time into this one to make it right. Once he has a production sample I will be able to post some more accurate specs. I don’t have the knowledge or experience to give an estimate on runtime. It will depend on what type of cells you are using. You might want to look into the King Kong ICR26650. It is a much better cell and unlike the Trustfire it gives you more actual capacity than it’s rated for. The TF will give you less than the rated capacity. Trustfire makes some decent low budget cells but I think the King Kong is a big step up in quality in this case and is still very affordable. To run in series you should look for a button top or at least a slightly raised top version. Simon was carrying the ICR26650 but I don’t see them listed now. I’ll have to ask him about that. My guess is with the sales of the L2 customers bought up his stock of 26650 cells. As far as I know the driver he’s using will not automatically drop down until it hits the low voltage level so it’s going to be up to you to change modes if it gets hot. I’m hoping to work with Simon in the near future on some drivers with more intelligent firmware. As far as throw, your guess is as good as mine. Being a quad die emitter it’s not exactly designed for throw but the raw power and reflector design will help make up for that. Should be pretty sweet.
The Acebeam K60 is rated at 124 kcd, so looks like this L6 is a smaller head (K60 is 88 mm head diameter), running at lower amps (estimated output of 3500 vs. 5000), so I'm thinking it will be in the 45-60 kcd range or so - expected for a non-thrower emitter.
If the head diam is close or closer to the K60 though, kcd goes up, and tweaking up amps would help. Gotta go big for throw with these monster multi-dye LED's, but I could see keeping the head small for carry. Love the side switch though .
Any chance of talking Simon into also offering a XHP-50 ‘semi’ “Thrower” version of this light too?
I probably have somewhat larger hands than most men, but find the 3x/4x parallel lights to be quite a handful, so I really do like the slimmer hand profile of the 26650 tube. - I have the Acebeam K40M, and the Olight SR52-UT, and they both seem a little “Fat” to me
Regardless of which emitter is in the new Convoy L6, (XHP…50/70), it looks inevitable that I will be a Buyer!
Actually when this thing started I was pushing for an XHP50 or MT-G2 but Simon decided to go big. I respect that but I do like the idea of an XHP50 option. Probably a bit less heat and a bit more throw right? Knowing the specs on the driver would it just be as simple as an emitter swap with a different centering ring? I’m not going to bug him much before this thing hits the store but if it’s that simple I could see that as a possible emitter option. Can someone chime in about the emitter swap using all the same components otherwise?
The beam does tend to look a little tighter with a 50 vs 70 because of less spill, but surface brightness of the dies is actually about the same so, to a lux meter there would probly not be much change.
As for the heat. Yes, it would save on heat IF the drive current was reduced. If the drive current remains the same the 50 will run hotter. Case in point I tried this with my copper P60 bulbs. At the 6-7 amp level the 50 got hot much faster and produced less light.
The main advantage of a 50 vs 70 is cost per emitter, and ease of mating with existing reflectors and mcpcbs.
I built a JAX x6 hunter with a XHP50 driven 4A and wasn’t impressed with the output, doesn’t seem like a major improvement over my YEZL Y3 MT-G2 2.4A, so I agree going big is the only way
It’s me again. The head and reflector size of the L6 was brought up in the L2 thread and I got a response from Simon so I figure I should post it here too.
The L6 head diameter is 72mm and the reflector diameter is 65.48mm
