ENEDED
436 posts / 0 new
Sirius9
Sirius9's picture
Last seen: 1 day 7 hours ago
How about shaved XHP70? or maybe even XHP35-HI as an alternative to XPL-HI, for thighter beam!
wkhchin81
Last seen: 2 years 7 months ago
I am using iPhone and could not find the appropriate link to set into this forum, but you can see some of the BOSS1 photos here:
BOSS1
CWK
pilotdog68
pilotdog68's picture
Last seen: 10 months 1 week ago
Good pics, thanks. Any chance it could take any pictures with other common lights to compare size?
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 14 hours ago
Nice collection of lights wkchin. B-)
Tom E
Tom E's picture
Last seen: 57 min 9 sec ago
Inset 20 mm for the star looks like, almost flat reflector - slight flare up at the hole. Looks like that big pill top may be a screw-in, like a COURUI.
Sirius9
Sirius9's picture
That driver does not inspire confidence!
Presumably, center point contact on a driver pcb is if you want to use one 26650 cell in the center of the battery tube which is a bit strange since all cell are in parallel so you could use 1 or 2 or 3 or 4 cells anyway…
Tom E
Tom E's picture
Driver is pretty simplistic - those 0 resistors are basically jumpers, so no restrictions coming out of the two FET's. Makes you wonder why there's no decent amps, if output is 700-800 lumens.
AlexGT
AlexGT's picture
Last seen: 4 days 27 min ago
+1 nice taste in throwers Beer
will34
will34's picture
Last seen: 13 hours 32 min ago
I like your throwers!
That driver was obviously designed to be simply a contact board for us to do driver mods. Smile
freeme
freeme's picture
Last seen: 11 hours 11 min ago
Palight has given us a blank canvas to work on Tongue Out
Untitled
Untitled
wkhchin81 wrote:
I am using iPhone and could not find the appropriate link to set into this forum, but you can see some of the BOSS1 photos here: "BOSS1":https://www.flickr.com/photos/wkhchin81/[/quote]
DB Custom
DB Custom's picture
Last seen: 53 min 50 sec ago
Those 2 little mosfets should deliver more power than that, I’ve used them on 10mm drivers and had at least 3A even from a 10440 cell, up to 5A from an 18650…. and that’s just one of those FET’s. Surely we can easily piggyback a better driver onto that big board and get some serious output out of the thing… Should be able to get a real 1600 lumens from an XP-L pretty easily. Even a de-domed XP-G2 in the 5-5.5A range should rock in that big reflector. Hate seeing that massive flat bottom though. Sure poses issues, surmountable but unnecessary if it was made a little different to begin with.
pinkpanda3310
Could the low current be related to the high vf of xml2 ?
DB Custom
DB Custom's picture
When the higher Vf XM-L2’s first came out, everyone was agast at the lower current that was max. Then we discovered that while the current indeed was lower, the output was almost the same or… in some cases… actually higher!
I’ve seen an XM-L2 U4 1C do 1811 lumens in an Eagle Eye X6. Tom saw 1900 before I think. These emitters are capable of making some great output, and their new efficiency allows them to do so with lower amp draw, saving your cells while still delivering.
This big hoss of a light surely can do more in the output department. And surely WILL do more, in the hands of some of the BLF members… Round 1, Tom E. Wink
AlexGT
AlexGT's picture
Maybe machine a collar and use the KD reflector like that TK61 mod…
pinkpanda3310
Thanks for the explanation Dale.
Alex – I was hoping this reflector would work better with emitters larger than a dedomed xpg. The KD reflector works awesome with smaller dies but in my opinion has a sliding scale of awesomeness related to the size of die (e.g. big die = not awesome).
johny723
Last seen: 1 week 1 day ago
wkhchin81
thanks! could you also measure the size of the reflector?
Jubeldum
Jubeldum's picture
Last seen: 4 years 6 months ago
Tom E wrote:
I’ll try. Hoping to max it out for throw. Once I get it and measure the lens, I’ll probably order a custom UCLp. Thinking of a de-domed XP-L, but I’m working on de-domed XP-G2’s. Unfortunately, I don’t have the capability to do much in a custom heat sink, but we’ll see. I’d rather keep the cells 4P – easier to works thing out with a stock driver. I’m thinking this is between a COURUI D01 and TK61 in reflector diameter. Of course a lot depends on the quality/shape of the reflector to get top #‘s.
Great for something this big at a decent price though.
I wonder what a dedomed Nichia 219C would be like in this beast?
wkhchin81
Many are looking forward to buy something “big”.
(additional comparison and measurement photos: BOSS1 , cheers Smile )
See the dimensions below first before deciding to buy one:
Head OD: 100mm
Glass Dia x Thk: 90×2mm
Reflector Biggest OD: 89.7mm Biggest ID: 85 mm (TK61 only 81+mm, sorry for wrong info initially) Height: ~58.6mm Base Diameter: 34mm Protruded area: 11.1mm OD x 0.7mm height LED ID hole: ~9mm
Driver Chamber Height: ~10mm
LED Base Plate/Pill: 4mm with 1mm depth (therefore only 3mm, see photos)
Spring Height: ~16.6mm (Wire Dia: 0.7mm)
Some comments:
1. The Glass is too thin, once removed, it may be crack when tighten. I heard mine with some scratch sound and edge chip off.
2. Reflector is smooth compared with TK61’s, hot spot is more even and slightly smaller than TK61’s.
3. The driver chamber is too shallow for thicker driver.
4. The Aluminium Pill is just 3mm, the shallow chamber limits additional thickness, but very large diameter may compensate this:).
5. The diameter of the body is too big (72.5mm) to hold, as my hand is not big enough.
6. Too heavy, personally prefer TK61.
Thanks for viewing (sorry for messy photos, as I taken them in a small store room).
CWK
gaston01
gaston01's picture
Last seen: 5 months 2 days ago
Head OD: 100mm
Some comments:
Many thanks for all the information and the images! H)
Sorry for my bad English…
pilotdog68
yes thanks for all the images. Does that “pill”/plate thing screw in or how is it attached?
I’m not sure about that 3mm thickness… definitely not enough for an XHP build but maybe if it has a good heatpath to the rest of the light it would be fine for XM class?
wkhchin81
The pill is not screwed in, just slight press onto the seat area which has been coated.
Heat transfer would be lousy. Pure copper pill can distribute better but surely will add a lot more weight to this heavyweight BOSS1!
(More photos here: BOSS1)
CWK
pilotdog68
gaston01
gaston01's picture
pilotdog68 wrote:
+1 :~
DB Custom
DB Custom's picture
Hmmmmm, problems but solvable ones. I can see cutting a spacer ring and threading it so that the bezel would screw on and accept a much thicker emitter shelf. Perhaps even a big solid copper adapter if copper can be found in that diameter. I know aluminum can, so it’s at least correctable but the issue remains… is it worth it?
The light obviously works well as made, but to hot rod it will take some doing and some specialized equipment of sorts, like a lathe. A new shelf could be cut with a cup on the top side to embrace the reflector, gaining a doubling or tripling of essential mass for heat sinking and if done carefully actually allowing the reflector to act as a heat sink as well. This would allow leaving the external apperance as is, optimizing available space between the driver/contact board and the reflector. Wink
I’m not altogether sold on total throw, a CBT140 would be a nice candidate for this big reflector, the XHP series would be a pita to get the “+” out of the beam. A big fat MT-G2 would be nice in there probably, so there are options that might not require going crazy on extra heat sinking, albeit new problems arise if a 6V or 12V emitter is desired.
If there’s 3 mm above the components already on the board then it’d be easy to sandwich in an FET driver that would run our Cree emitters all out, raising lumens output to much more smile producing levels. Our FET drivers are single sided, fairly easy to solder a copper sheet to an incoming power supply after first attaching the other end to the battery contact on the FET driver, this keeps it very flat, only about 2mm more thickness than the components already on this driver board. Doable. Not too difficult really. So that would get some 6A to an HI emitter, the sheer diameter of the emitter shelf would help offset the lack of thickness. If need be, a hole could be bored in the aluminum emitter shelf to show the driver underneath, easily allowing clearance then (since the shelf doesn’t screw in, this would be doable but probably not necessary)
All that remains is to mount the XP-L HI on some copper sheet material to raise it off the mcpcb so it’ll sit high enough into the lens to be in focus, should produce a nice tight spot. Should be interesting.
Anyway, those are just some initial thoughts, I’m sure Tom will show us the way in the next few days…
Sirius9
Sirius9's picture
Yes, if you have a lathe, otherwise you are pretty much stuck with stock emitter shelf which is quite disappointing and major limiting factor in any modification…
DB Custom
DB Custom's picture
Yeah, well, it didn’t stop me before I got the lathe… a drill and a rotary tool and I made what I needed. Threads were the only problem and that was because I didn’t have a tap and die set. Where there’s a will….
eebowler
eebowler's picture
Last seen: 2 weeks 4 days ago
my goodness, that ‘shelf’ is a freaking disappointment :_(
I’m sorry. Freeme, I’d like to be removed from the list for this light. I’m not in a position to do or pay for any machining or copper bits.
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
pilotdog68
I’ll wait to see what Tom thinks
pinkpanda3310
I’m not sure why the shelf is that much of a disappointment…? Yes it could be better but DTP star is going to do way more for cooling the led than anything else.
The anodizing is a thermal restrictive point but see how much contact area there is on something that diameter and compare it to something like a convoy s2 (which some like to hotrod). Saturating the shelf (with heat) is not going to be a problem with that kinda battery capacity but who here is looking to mod this (super thrower) and have it running for a half hour at a time?
freeme
freeme's picture
What is the main issue with the pill design? Is it:
  1. Too thin.
  2. Insufficient contact with the wall.
  3. Non screw on design.
  4. Not enough head room to piggy-back driver.
Done.
eebowler wrote:
I'd like to be removed from the list for this light.
