ENEDED
436 posts / 0 new
will34
will34's picture
Given the size of the led shelf disc I would say this is no major problem for a 3V emitter, I built a Courui without changing the shelf dic, instead used thermal epoxy to fix it and it did alright. Of course the large copper heatsink heated up much quicker but after 5 minutes there was really no difference at all. This disc is much larger than the courui’s and seems like it has about the same contact area. But for a behemoth like this, that is a serious bottleneck!
pilotdog68
pilotdog68's picture
Last seen: 4 months 1 week ago
Some would say all of those are issues. For me, #2 is the biggest issue. #3 would be one way to attempt to solve #2.
What’s the point in toting around that big heavy body if it isn’t soaking up heat? What’s the point of big battery capacity if I can only run it for 2min before output starts reducing?
Again, I’ll wait to see what Tom thinks before deciding anything, but that’s my train of thought. It could very well end up being a non-issue, that’s why I’m not backing out now.
unknown00101
Wasn't it determined that anodization has very little effect on thermal properties? IIRC someone did a fair bit of testing on an anodized shelf directly under the mcpcb.
nothing I've seen yet is a deal breaker though I'm still not sure what the heck I would use a giant, long-lasting, super thrower like this for..
Looking forward to seeing what yall can do with it.
pinkpanda3310
pinkpanda3310's picture
Last seen: 5 hours 5 min ago
freeme wrote:
What is the main issue with the pill design? Is it:
  1. Too thin.
  2. Insufficient contact with the wall.
  3. Non screw on design.
  4. Not enough head room to piggy-back driver.
1. As pointed out by will34 the courui is also thin. So is a tk61. I’ve never had an srk with a shelf but I imagine that is also light-on for 3 or more emitters.
2. With the larger diameter I expect it has more contact area than the above mentioned lights.
3. Point taken. Still no biggy to me, when it’s all assembled it doesn’t rattle around does it? So one would assume it is being pressed into the body allowing for heat transfer.
4. That has little to do with the shelf and more to do with the design of the light. But none the less, this is a problem, I agree.
Looks to me like 4-5mm of contact area around the radius. I didn’t find the measurement but I guess the shelf is over 70mm diameter??
Untitled
KawiBoy1428
KawiBoy1428's picture
Last seen: 14 min 51 sec ago
I’d might still buy it, say $30.00 maybe? Looks to be Cheap, down and dirty, perfect BLF light, if you can get it for $30 bucks!
KB1428 “Live Life WOT
DanielM
DanielM's picture
Wow what a pathetic light.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
M4D M4X
M4D M4X's picture
Last seen: 15 min 27 sec ago
maybe sell as host with unpopulated driver to use as contact plate?
that way the costs could go down
and i think no one planned to use it out of the box for more than 30 seconds Wink
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
freeme
freeme's picture
Last seen: 3 hours 15 min ago
SealedTongue OutCool Will see.
High anticipation usually lead to big disappointment when people do not get what they want. It is totally understandable.
If you do not like what you see here, just submit your name and walk away from this deal.
Tom E
Tom E's picture
Last seen: 24 min 22 sec ago
Lots of good specs posted above. Been a little out of it - awful cold/infection, something. Goin to the doc this morn I hope. If I'm home tomorrow, can get the delivery, or gotta setup a sign approval some how...
Internally, agree - big disappointment. Might need a lathe to do it right, but unless the manufacturer is willing to change the design, there are many of us who can't do the mech work at that level (myself..), so maybe a simple single LED is viable - the reflector is sounding good.
DB Custom
DB Custom's picture
Last seen: 5 days 1 hour ago
Wondering out loud here, wasn’t it said there was 10mm of driver bay area? So, with a single sided 17mm FET driver being around 3mm thick, isn’t there a LOT of room to add a heat sink press fit into the driver bay for the emitter shelf to sit on? Couldn’t this heat sink go all the way to the current pcb, (remove all components on the driver, place Katpton tape over all contacts or sand it smooth) This 10mm thick heat sink could have a 17mm driver bay cut into it, or simply a 17mm hole bored through, if done in the middle it could actually replace the current contact board and the battery positive could press into the 17mm driver itself, with battery tube negative pressing into the heat sink.
Effectively, a 70mm dia 10mm thick heat sink being introduced in place of the current driver. That would be sufficient for virtually anything we could stuff in, right?
How is the driver currently being held in place? Is it a press fit? Could I machine aluminum inserts to have a wider lip on top, sized to fit the walls of the driver bay, such that it would replace the driver and have a 17mm driver bay in the center, effectively acting like any of our smaller lights? I could add the 4mm emitter shelf onto that for a 14mm solid piece, then it wouldn’t be an issue for the two piece to have good mated contact.
I don’t know how many lights will sell in a group buy here, or how many of those would need this heavier heat sink, but I could try making one and see how it goes and if I’m able to do it successfully I could offer to do it for those wanting to push this light harder. Not sure how many I could do, and of course I’d have to make sure I could do it at all, but I’m game…. I work cheap, by the way, Wink (well, for this lol)
DB Custom
DB Custom's picture
Tin foil isn’t optimum, a direct contact between metals is the best, tin foil gets wrinkled and allows air space, that extra sheet of metal doubles the available air space with more surfaces. Best to have the 2 pieces in contact directly and not need a go-between.
As I understand it, the emitter shelf “plate” is already sort of a press fit, so it should be good.
Tom E
Tom E's picture
Looks like a few mm's of space in there from post #124 - enough for a piggyback FET driver. At a min with no metal work, could sand down the shelf the pill top sits on, and use a good thermal grease - it would help I'd think, not great. Just the shear size of the pill top would shed some heat.
Those tailcap springs look awful - definitely need bypass wires.
The whole anodized surface issues - I'm not sure - better or worse thermally. Could also drill and tap holes and screw it down w/brass screws, if there's enough thickness in that area of the head. 12 brass screws around it - would look cool anyways...
Of course a custom copper substitute of the whole piece from Dale would be totally awesome, and secured down.
will34
will34's picture
the driver can go anywhere in the space beneath the reflector, this would give us more space for the heatsink and would be extremely easy to mod and fw reflash since all the components are on top of the shelf.
johny723
Last seen: 5 hours 24 min ago
this light is begging for a direct drive from 4×26650 without any electronics between emitter and cells since there is so little space inside. Just for running one mode on and off. Like those flashlights we had when we were kids. A solution to heatsinking could be using a small fan right under the pill or a copper plate attached to the pill from beneath
Tom E
Tom E's picture
Got it! Packing wasn't ideal, but it seems to be in great condition so far look'n:
Full Content of the box shown below. Thin bubble wrap, 2 little cushions were at the bezel end. Would definitely prefer to see foam in the box. The box itself was ok - could be thicker, but it's thicker than the usual budget light boxes. The foam around the box wasn't covering the box ends, and the DHL envelope was the thin kind - no padding/bubbles.
(I'm more anal now about packing, after my recent experiences with thin bubble wrapping)
Condition of the light looks pristine:
Just for size comparison, the pic shows it about right (zoomed in from a higher distance):
Threads between the head and battery tube (connection for battery replacement). I think the threads are so pointed, I couldn't get them in focus:
thijsco19
Last seen: 1 week 4 hours ago
Hmm not as big as I have thought!
Not that it is small but I just thought it would be bigger.. Silly
Tom E
Tom E's picture
Want some #'s? K- this is totally stock as-is. Threads came bone dry and they are not square, so I applied some Nyogel - only thing not stock, and couldn't stand the squeaky sound.
There are 4 modes: lo-med-hi-variable strobe, in that order. Appears to reset to lo in a couple secs.
Tail amps on one EFEST 4200 40/60 cell - measured with direct contact on the driver (14 AWG DMM wires):
  Lo: 0.54A   Med: 1.40A   Hi: 2.4-2.5A (readings are moving around, generally go up over the first few secs)
Tail amps on four EFEST 4200 40/60 cells - measured by jumping the switch with the DMM leads:
  Lo: 0.77A   Med: 2.10A   Hi: 3.58A (readings appear to be steadier)
On the one cell with no battery housing or tail, pretty loud buzzing. On 4 cells all closed up, but with the tailcap removed to expose the switch, the lower modes seemed silent.
Lumens on hi: 1020 @start, 962 @30 secs  (my PVC lightbox)
Throw on Hi - measured indoors at 5 meters, as I always do:
  163 kcd (807 meters)
Well, seems like a lot of potential. Who knows what XM-L2 LED it is, could be T6 or U2, and on a cheap alum MCPCB. Again all stock for now...
johny723
Do protected cells fit?
Tom E
Tom E's picture
It fits tight with the unprotected ones, but the springs are long. It feels awkward tightening up with cells loaded - you can feel the cells brushing over the driver bumps. I'm think'n not to even try protected - no point to ever use them anyway - let me try...
pilotdog68
163kcd at only 962lumens from a domed XM-L2 does indeed sound promising. How is the beam quality? any ugly rings?
MRsDNF
MRsDNF's picture
Last seen: 18 hours 29 min ago
Thanks for the info Tom E. I'd consider this a whopper. a shame i cant catch fish the size of this light. I wonder how many 18650's weight wise is comparable to a 26650?
Tom E
Tom E's picture
The Trustfire protected 26650 cells fit fine, so probably all protected will work.
I measured 9.45 mm vertical clearance in the pill, between the driver/contact board and the pill top plate.
The head is a true 100 mm in diameter - it is huge.
The driver retaining ring is super thin aluminum - maybe 1 to 1 1/2 threads on it (spots seem to have 1 thread, but other spots maybe 2). Also, why they have a loose alum ring under the driver, I have no clue - guess they thought it was needed for better contact of the cells to the driver, so it raises the driver. Probably an after thought/fix. Would have been much better eliminating it, increasing the thickness of the driver PCB, and making a thicker retaining ring. The retaining ring scares me - too much fiddling I can see this thing falling apart. There are 6 holes for loosening/tightening it, and one I already tore one side out from trying to get it out - used a punch and light hammer taps to get it loose. I have no tool than can span 90 mm or so.
For the driver - all cell contact points (5 including the center) go thru a big bad diode each before the LED+ wire. Also there's fairly long traces on each side of the PCB for each cell. Probably explains some of the voltage drops, resulting amp drops - diodes and long traces.
For piggybacking a driver, those diodes can be removed and replaced with wires - that would certainly help. Might be able to jumper some of those traces as well.
unknown00101
Reupping the hype! Smile
Looks very promising. Bit of a shame they cheaped on the threads.
edit: dangit.. Driver situation is a bummer
Tom E
Tom E's picture
Well, think bout it - this light does stock about what a TK61 stock does, and the TK61 has an AR lens, copper MCPCB, maybe the TK61 is a little lower in amps. For the LED, dunno - TK61 is a U2 but not sure what this is.
My 163 kcd could be low - I measure only at 5m. I've seen as much as 10% bump measuring at 10m+.
johny723
if it stays cheap, it will be an interesting host – it has a lot of potential, but just as many issues that need improvement. I cant wait to see what an overdriven dedomed xp-g2 can do in this light.
Tom E
Tom E's picture
Beam spill is wider than a HD2010, which is pretty wide.
Took out the pill top/shelf thing. On mine, it's just sitting there - no tight fit at all. The MCPCB is epoxied in - I got it off ok.
Stock MCPCB is 1.52mm thick, Noctigons are 1.55 mm - this is good.
Only got bout 2.6A on a single charged SANYO GA on the batt+ brass pad with shortest routes, diode jumpered, LED- wired direct to ground connection (no MCU). Not sure where the loss's are from, though could be the LED/MCPCB, or driver PCB design itself somewhere - maybe the board traces are thin, but they look pretty wide. This is a simple, crude driver for sure.
Looks easy to piggyback a driver in though.
The aluminum LED/MCPCB shelf is 4.0 mm at the thickest, 2.0 mm on the edge, 3.0mm thick in the middle area, and about 2.1mm thick in the center, under the MCPCB. Of course the thinnest parts are under the MCPCB and the edge that makes contact to the host/body.
Tom E
Tom E's picture
Just to address these issues so far with my opinions on it:
  • Too thin. -> Well, it's thin but really, really wide, so lots of metal, but I'd like to see it twice as thick
  • Insufficient contact with the wall. -> Again maybe, but the radius is so darn big, there's lots of 2.0 mm shelf overlap material. Screwed down would be a good solution
  • Non screw on design. -> Threaded maybe is better, all depends on how tight, how many threads, etc.
  • Not enough head room to piggy-back driver. -> it's like 9.5 mm open vertical area - fine for typical FET drivers
Ouchyfoot
Ouchyfoot's picture
Last seen: 2 weeks 6 days ago
That shelf is pretty vast. I mean, we’re only trying to slough off the heat from a single emitter. It’s not like we’re trying to cool down a hard driven triple.
freeme
freeme's picture
BOSS1 does look a bit smaller than we though in your coke pic, but body is still too thick to hand-held steady grip according to wkhchin81.
There is probably nothing much to improve for most buyers on for the pill, except to strip off the coating on the contact surface and cement it to the wall.
9mm head room should be sufficient but what it people want to convert into 2S2P?
Palight is one of the few companies that keeps improving there flagship models. According to their site, their current X960 model is already a 6th generation design. I am pretty sure they will work on next gen of BOSS1 very soon.
wkhchin81
Last seen: 2 years 1 month ago
I just tried changing 4 springs from KD’s Big Spring, added braided copper along the contact points of the PCB boards, changing the LED to Noctigon’s 20mm MCPCB XP-L V6, fully charged the batteries to 4.2V. Yet the brightness I got still lower than my stock TK61. Something is not right somewhere.
I have checked using reflection from the ceiling focusing at the same area and same spot size (All using fresh batteries, with copper based LEDs):
TK61 (Stock) – 102 lux (claimed to be 1000 lumens)
BOSS1 (xp-l V6) – 85 lux
Courui (xm-l2 U3) – 117 lux (stock driver, 0 ohm resistor, EDC’s SPRING )
Small Sun ZY-T20 (xp-l Hi V3 1C from KD) – 119 lux (18× 350mA 7135 driver: HOND’s HZ-3905 ; EDC’s SPRING)
HOND’s No-name (mod to 3x xp-l Hi – 2x 1A & 1x 3B) – 276 lux (stock driver, 0 ohm resister)
Courui Mod to XHP70 N4 1C (12.6V) – 315 lux (FX-30 driver; EDC’s SPRING on cartridge; main contact point using Beryllium Copper Spring ; with machined copper base; 3× 18650 Series Cartridge )
Acebeam K60 (Stock) – 457 lux
Meteor M43 (S4) – 667 lux
Based on the numbers above, the BOSS1 after mod is still under 1000 lumens, quite disappointed! The xp-l v6 was “stolen” from my other flashlight that produces 120+ lux for the same ceiling reflection testing.
One of the leg of the main switch seems does not penetrate to the face of the battery negative base, that’s could be the last reason for the low Amp.
CWK
