Yeah, the cheapest ones (~$10) only do AC with the clamp, but around $25 you start to see DC on the clamp
How do you blow a DMM. Don’t they have fuses? I’ve overloaded mine, but just had to replace a fuse. I think they all pretty much have the same standard 10amp fuse,
Hmm that’s probably what happened then, but they were Klein brand so I took them back to Home Depot and they swapped for new one.
I have a clamp meter which I think detects DC, but it’s buried since it’s too big for anything I might need it for.
If you’d go by the local auto parts store or junk yard, you could pick up a Ballast Resistor from an old point-style ignition system. You could wire it in series, measure V across it, then compute your I to see if your meter can handle it. That would ultimately be faster than going back to HD…
Replacing the fuses & batteries isn’t hard, but I’ve seen meters that use weird proprietary screw heads. Fortunately I have all those bits, so…
Fuses actually offer suprisingly limited protection. Even the best fast blow fuses take milliseconds to open up, you can fry electronics in microseconds. Exceed the
maximum rating on the input by an order of magnitude (factor of 10), and odds are both the meter and the fuse will be toast.
Either way my meter can’t measure over 10 amps, and it’s always affecting my readings by adding resistance. I don’t want to open up my meter to mod it because I use it for other things too.
So I’m pretty set on getting a clamp meter, just looking for tips on a good deal.
I've blown four since I've owned my DMM and nothing was harmed. That's the point of having a fuse. I just popped it out and dropped In a new one. I guess there's no knowing what kind of fuses they're using in some of the budget meters, but "Limitron KTK-10" are pretty standard fuses in DMMs. Mine is a Brymen, but I know that the Flukes have standard "Limitron" fuses too. They're pretty standard. I'm pretty sure it would be a waste of money if the fuse couldn't protect your $450.00 Fluke.
Dale uses a clamp meter. Not sure what kind. He might know something.
Build one of these and you won't look back:
Can, what’s the model# on that Mastercraft?
Krono: I think I knew Dale had one, but I’m sure he has a more pricey model.
I have an Amprobe clamp on at work that I use, but way out of the range for me to buy off the shelf. I use one piece of 12 Ga multistrand copper that I cut at 5” long to maintain consistency during measurements. I will be interested to see what pops up here for budget options.
I swear I’ve read that thread 20 times over the last couple years, and I just don’t get it. Also it’s clear I need a reliable meter to tune in the new shunt, which I do not have.
Can: I’ve seen ones similar to that one in my desired price range, glad it’s working for you.
I sent a rather low-ball offer on this model, we’ll see what he says.
PD68 wrote:
ImA4Wheelr wrote:Build one of these and you won’t look back:
I used a bench top variable power supply to make mine. I don't know how accurate the meters on it are, but it's all I have to go by. I just cut a 6" 14ga wire with an inch of insulation stripped from each end. I then put the wire in the power supply and then ran 10amps of current through the wire. I then probed for the spots that gave me 10mV. I then soldered wires to spots just a tad wider than those spots because the solder reduces resistance a tad. You can then tune the wire be either notching the wire or adding solder. You have to let the wire cool from soldering before testing it for accuracy.
My version, banana sockets are to plug a multi-meter (set to mV range):
22 AWG wire for shunt, about 8” gives 10 mohm (so 10 mV/A). Trim exact length by using an amp meter in series with the shunt and a voltage source. Going over 10A you should probably use thicker wire and lower resistance for the shunt, as per the linked thread above.
Note that copper wire has a relatively high tempco re. resistance. There will be a 4% change in shunt resistance with every 10 C change in temperature. Proper shunt/resistance wire is manufactured from alloys with much lower tempcos.
These are made with Nichrome wire where the resistance increases as the wire heats so I wouldn’t go there. They will handle a lot of current though, just not accurately until the temperature settles down. These were used to compensate for lower battery voltage while the starter motor operated, then lowered current afterward to make the coil and contact points last longer.
Phil
was undecided between that 210E (24-28 USD) (because of the 1mA resolution, I prefer precision for what i do than 500+ Amp capability), the Mastech MS21080-35 USD (the cheaper 2108A version has not TrueRMS and no Inrush current 27-30 USD) but in the end I opted for a 216C for no reason…. (as always), well the reason was mainly because it seemed a bigger discount even if i ended spending more of what i had planned…47 euros shipped tskk . Always speaking of DC current clamps
It was able to detect 8mA (the clamped displayed 0.01A) And testing various low currents with my linear variable PSU i got very very decent results
But somehow i was not able to measure the battery drain of my sister Toyota Yaris with headlights on, I whink they should absorbe near 9Amp, dunno why
Instead , don’t know if it was reliable for instantaneous DC current (because it calculates the inrush current doing the Fourier transfor of a variable current) i was able to measure 466 Amp from the same yaris D4D to start the engine (battery rated for 570Amp cold start, so it could well be)
If you need me to check something just ask, i’ll do what i can while i’m not at work
I was also looking for one last year too. My budget is enough for Uni-T only. 210E seem to be a good choice for measuring Amp consumption for flashlight. 211 cost almost double of 210.
More precise resolution would be nice, but probably not necessary. I can always use my normal meter for the lower stuff.
I don’t think I’ll ever measure AC with it, so I’m probably ok without the TrueRMS feature?
Can your wizardry get us a fantastic deal on the 210e?
