Review: BLF-348 (SingFire SF-348) Nichia Special Edition Flashlight (Runtimes, Output, Etc)
Thanks! I think we already got a couple more reservations because of your review.. :)
Like the haircut
Another great video review! :beer:
Thanks for the nice video! The runtimes are useful to know, and that it runs without problem on a 10440 battery.
GREAT REVIEW! I carry this everyday clipped in shirt pocket. Can't beat it. Got spares coming too. It's that great.
I just looked at that thread, maybe so!
It was about time. Best $18 dollars I spent that day!
Thank you, I’m having a beer right now.
Yep, no problem at all. Just don’t hold it near the lens.
It’s a no brainer at this price.
Great review thanks.
Thanks for another good one! The time and effort you put into these is much appreciated. Here are the data I extracted from the vid.
BLF-348 – Measurements by MHanlen
Battery Lumens Candela Distance Runtime
Eneloop AAA 48 193 27 1 hour
Efest IMR14400 176 744 54 27 minutes
I could not tell for sure, but I think you were joking about the "thermal regulation" offered when running on Li-ion. I take the flickering to be a sign that the driver is overheated. Component values in the driver are evidently changing as they cyclically heat up and then cool down.
My own choice is not to use Li-ion. I think this light runs too hot on that battery.
I was being serious. I’m making an educated guess based upon a few things. First the brightening and dimming. I’ve done many video runtime tests now, and the only lights I’ve seen do this are ones with thermal regulation. The Noctigon Meteor and the Xtar H3 are examples- and if you watch my video reviews you can see this happen during the runtime test sections. Another piece of evidence: This thread here shows the BLF-348 light being disassembled with a 7135 chip used on the driver.
And this says that 7135 chips have built in thermal regulation.
I might be wrong though, so someone feel free to correct me as to why this isn’t true. Also, one other thing. The light does not have built in low voltage protection, so be careful about running the battery for the full runtime.
Thanks for the great video. I really wasn’t thinking I needed one of these. I think you helped change my mind.
Oh yeah, that copper tool looks sweet! I’ll Check out that video next. 8)
I'm learning something here. Thanks.
Is the thermal fold-back a self-defense mechanism of the 7135 chip? Is the chip protecting itself from damage? That would be good thing. But how late in the process does the protection kick in? By the time it gets that hot, are other driver or emitter components at risk?
With a stainless steel host, the problem is that once it gets hot it stays hot. It takes a significant amount of time for one to cool down.
I will be reading this thread to learn more. For the time being, however, I will stick with my original decision. The fact of the flicker tells you the BLF 348 runs too hot on Li-ion. It's nice to know that at least the 7135 is trying to protect itself, but that does not make a flickering light any more useful.
As always, the user plays a big part in this. For those in need of brighter output for limited periods of time, there should be no issue with Li-ion. Just remember to turn off your light if you feel it is overheating. For me, that would mean before it starts flickering.
It’s not a flicker. It’s a steady ramping up and down its something you may not notice while you’re using it. Personally, yes the light is kind of small for this sort of heat. I’d use a larger light for prolonged on/off times. But since this is a pocketable EDC light, it’s great for uses ranging a few seconds to a minute or two. I’m more inclined to use an eneloop in the light anyway. I think 40ish lumens in a tiny EDC is more than enough… If I need 170 lumens or more I usually carry a bigger light, with a bigger cell. But this tends to be one of those places that likes to push the limits of what lights should do.
Me, too.
A multi-mode version of this flashlight would be more suited for Li-ion. With lower modes available, you could just change modes when high got too hot.
Yep. But look at the Noctigon Meteor. No light that size can handle 4000-8000 lumens for more than a few minutes. It has thermal regulation built in, because it has to, to protect the light from damaging itself. I don’t know how advanced the 7135 thermal regulation is, but it’s temperature controlled… And I the meteor also gets just as hot to hold too. I also own other lights that get just as hot too handle too. The 348 though is still very holdable even after 10 minutes. But yeah… Less heat equals a longer life to the internal components.
Can you sum up the results for those of us who are text-based?
Here is the basic data KeepingItLight formatted from the video.
Battery
Lumens
Candela
Distance
Runtime
Eneloop AAA
48
193
27
1 hour
Efest IMR10440
176
744
54
27 minutes
Is that what you’re looking for? If you’re curious about anything else just ask.
How so?
Edit: Oops… It is. It should be multiplied by 2. Good catch, I’ll annotate the video. I skipped the final step when doing calculations.
Funny that no one notice its the wrong battery format in the table.
I love this little light! But I’m a little disappointed about the CRI. Not much difference with regular CREE 3D tint, only slightly better but close.
By the way someone know the best place to get the best 10440 battery?
I think the efest 10440 is the best regarded 10440. I think. I don’t know if any international stores carry it. Mountain electronics ships certain things overseas, but I don’t know if Liion cells are included.
Fixed the table. I’ve been viewing this on my phone and never looked close at it. I’m a bonehead.
Too many tables now…deleted my comment above for clarity :slight_smile:
