Try that on your fet driven XPG2(or any other) mod. You will be unpleasantly surprised with massive light(lux) drop :)
It’s free, so I won’t complain.
[quote=MRsDNF] All the insides swapped directly into the tailcap of the B158 and worked perfectly of the linked remote switch from the 1504. Unfortunately they are out of stock. I've others on order which I'll report on when I receive them.http://www.gearbest.com/diy-parts-and-tools/pp_168264.html [/quote] Try that on your fet driven XPG2(or any other) mod. You will be unpleasantly surprised with massive light(lux) drop :)
Yes, this was discussed somewhere here earlier.
Still waiting for mine, plan is dedomed xpg-2 and LD-2 or BLF A6 driver, have all those things, need the flashlight now, tracking said it is send to destination country 5 days ago. Cant wait
This one would be my first good zoomie, i have ultrafire SK98 and im not impressed, it is used for indoor needs because it has no hotspot but other than that it haven’t seen much usage.
5 minutes mod to my B158.
Changed the led for a XP-L hi 16mm noctigon from intl-outdoor, removed the driver and connected the led directly from the contact plate for direct drive as i only needed max output.
I also removed the Klingon protrusions on the body with a lathe since i don’t intend to mount the B158 to anything, lost 26 grammes in the process and the light is much nicer to hold.
I contacted them also to remove that chunk to 30 mm and to made me 50 pcs of them but I got no response.
I don't find them as serious company any more.
Uniquefire here I come :)
Good luck with that!
They are far better company to deal with.
They just don't have that good lenses... Yet :)
And I really don't get small flashlight manufacturers like Brinyte... Someone wants to order OEM and ODM of B158 and they don't even response to mail?
Maybe 50 pcs is not a lot but they should consider that as a good start of business, and then maybe we could talk about larger moq.
So yes Brinyte your costumer service and your way of doing business sucks.
These are some great results to get over 300 kcd! So far it's KKW, djozz and l-a reporting on this. My B158 is still not here, bout 4 week from shipped. I'll give it another week or so, but thinking it's lost. It's rare to go over 4 weeks for me here in NY.
Could someone or all who got the de-domed XP-G2's over 300 kcd please post a tailcap amp reading? I don't see one anywhere, unless I missed it somehow. I assume djozz is doing a hot dedome, and l-a is doing a gas dedome, not sure bout KKW - probably hot dedome?
I'm very interested because I've been getting from 3.9A to just over 5A on S2 2B's - it seems to vary greatly, and I thought the S2 2B's did better than the S4 2B's, but maybe the S4 2B's put out the same or more light at lower amps?
They just don’t have that good lenses… Yet
And I really don’t get small flashlight manufacturers like Brinyte… Someone wants to order OEM and ODM of B158 and they don’t even response to mail?
I mean, I don’t agree but that’s my opinion. They’ve been very responsive to me, answering all of my questions… Getting the bare pills… Asking me for suggestions. They even sent me an email wishing me merry Christmas. What email address are you contacting?
Which leads me to wonder what any company requires for a custom order? Is 50 enough? They require quantities of 50 to get the price to $22.99. So I wonder what your willing to pay for custom machining work to the lights? My feeling would be that it’s going to be more than $30 per light to get custom work done. Have you contacted other companies about doing this?
I contacted them at customerservice@brinyte.com
Edit: It is not custom machining. I am not asking them to rework me old stock of B158 flashlights. I am asking them for small cosmetic change in new series they would made for me.
They are flashlight manufacturers with cnc machines and everything right? It is even easier and faster to made my version without that nasty and unnecessary chunk than their B158 chunk and unnecessary mount version.
I would not need mount/manufacturing process is easier and faster and whole light would be 30 gr. lighter. So price should go down with this process and not up.
They are flashlight manufacturers with cnc machines and everything right? It is even easier and faster to made my version without that nasty and unnecessary chunk than this B158 version and I would not need mount and whole light would be 30 gr. lighter. So price should go down with this process and not up.
So putting old stock lights on a machine to remove or modify them should make the price go down? Alright, I absolutely don’t agree with that but I’ll send you the email of the person I’ve been dealing with there. The email above is CCed on all the emails, but I’ve never received an email from that address. It is possible you’re being sent to a spam filter.
And considering you said they suck without having actually talked to anyone there, well…
I’ll just PM you the contact and hopefully you can get it sorted out. I however don’t expect the price to go down, for any sort of modification to existing stock of their flashlights. That’s like me asking for a custom engraving for free from a company, because they’re actually REMOVING metal.
Mhanlen,
You did not even read my answer... So read up again:
Edit: I cant find them as serious company cause they are not answering on my emails. I have sent more than just one mail.
Well agree to disagree. I don’t want to get into an argument. I did read your response and understand it. I gave you the address, so see what they say before declaring they are a bad company. I know my work email often sends items to the spam folder… And considering it is NOT the email I’ve dealt with I can’t say what the situation is.
I am not attacking you man. You are not Brinyte.
But again... Is it a problem for flashlight manufacturer to made small cosmetic change on new specific costumer order? They don't need to rework anything. They just need to made new batch. You saw what I mean... That is far easier to do than existing B158 model with additional unnecessary mount.
So if you or other guys disagree with that? OK :) I accept... I think this is just right way of doing business.
So if they can't do that or if they demand extra large MOQ they do not have their own machines. Someone else is doing that for them.
But again… Is it a problem for flashlight manufacturer to made small cosmetic change on new specific costumer order? They don’t need to rework anything. They just need to made new batch. You saw what I mean… That is far easier to do than existing B158 model with additional unnecessary mount.
So if you or other guys disagree with that? OK I accept… I think this is just right way of doing business.
So if they can’t do that or if they demand extra large MOQ they do not have their own machines. Someone else is doing that for them.
Ok fine. Email them first. I have had many many emails not returned from manufacturers. I’m done talking about it, this is between you and Brinyte not you and I.
Of course :) Will try with other mail and I'll see ;). Thanks again.
I highly doubt Brinyte owns their own 4-axis cnc machines. They design the flashlight and sub it out to a machine shop. The machine shop sends it to the annodizer. After that the assembler than to a warehouse. Brinyte recieves them complete, most likely. May not ever touch them, who knows. There is no way they can do what you are asking. You will have to sub the work to a real machine shop local to you.
This is what Brinyte’s website states:
Shenzhen Yeguang Technology Co, LTD is a full service producer of high power LED flashlights, batteries, chargers and related accessories. Our exclusive factory includes state of the art CNC machines, production assembly lines, testing labs and custom design CAD equipment. Through our years of experience, we have developed our own brand as well as development and patenting of other popular products.
Our key value propositions are as follows:
- We leverage quality processes that provide consistent and predictable quality
- We consult and assist our clients in ensuring they are informed on the latest technologies related to our business segment
- With our on-staff engineering capabilities, we assist our clients in consultative custom designs (including engineering drawings, CAD design and one-off sampling)
Number of employees: 80
Year Established: 2006
Flashlight production capacity (annual): 500 – 600K
Brand: Brinyte
Market Regions: Our current client spans over 100 countries including Asia, North America, Europe, South America, Oceania and Africa
Target Clients: We support the entire range of clients from large retail to small business opportunities
It sure does.
Forgive me for making assumptions :bigsmile:
They didn’t seem to be that large of a manufacturer. I was wrong :_(
