"After 3 years developed, Yeguang Technology changed to use “Brinyte” brand, focus on hunting and diving powerful led flashlight, especially OEM and ODM customs service."
You see they are specialized in this. Same like Uniquefire. They will machine and do whatever you need. MOQ could be problem. 50 pcs is small order but smart thinking would be to accept this order cause just 1 worker can make this in less than one day on 1 CNC machine, and if they accept we have a base for future cooperation. I can for example order twice per year next 2-5 years.
With some companies I am dealing with there absolutely no issues with this service. It is in their best interest to earn some $.
Good info. I’m betting it’s either a high MOQ and 50 doesn’t cut it, or they don’t cannibalize their own designs if you don’t hear something by the end of next week.
I will if they will respond. But after trying to contact them with same questions with 2 different emails several times during week or two with no response they really deserve that epithet.
Their B158 is really good. I did not said that their flashlight is bad :)
That light is more different than the B158 than it is the same, the only component that could be considered possibly the same as the B158 is the battery tube. The lens, head, tailcap, and pill are all very different, even if functionality is similar. Are you just guessing they’re made by Brinyte, or do you know for sure that they are?
I do like the idea of the 70mm lens, but the price is outrageous if compared directly to the B158.
Yes it could be redone. It would be simpler to machine a plain tube than with the lobes and tapped holes added but still the same multi thread zoom, seals, and head threads. You might have more success presenting them with numbers for a group buy than saying hey, make this for me and you’ll sell enough to make money.
I don’t think I missed your point, but that we’re trying to focus on different points. (though misunderstanding is very possible in short text based communication)
Unless the “redone” light is made by Brinyte it’s a moot point, because that’s who you’re contacting (we all know how common similar looking lights from different manufacturers is). If it is done by Brinyte, perhaps more patience is required before you get a response, I bet around Christmas and New Years is a bad time to expect quick communication.
I’m still suspecting 50pcs isn’t enough to get them to change the design at all though, based on their reluctance to sell hosts as part of the group buy. Had they been willing to sell hosts at $20 each I would have bought 30 hosts instead of 20 lights and 20 bare pills. I try not to complain about it, because I realize I have to deal with their business model, not what I wish it was.
Had no probs with communication from Brinyte. And I’ve got two batches of lights from them. I ordered two B158’s as test samples, and they kindly put my own logo on the lights, even for just two.
Back onto the topic of modding, I’m still waiting for my pills from Gearbest. Delivery seems slow, even for one of these sorts of places.
4.1-ish A on a Samsung 30Q fresh from charger (also djozz fet driver).
I made a video to show that measuring the way I do (voltage measurement over a 0.01 Ohm sense resistor) gives some variation, when the (fat solide copper) wires are pushed down well, it is between 4.1 and 4.2A:
I use UNI-T UT210E clamp meter and very thick gage wire. Maybe it has higher readings than your dmm? If so that would mean that it draws about 4.1 as with your cell (HG2 and 30Q are almost same in performance), and about 3.6A with panasonic NCR PF... But I don't really think it reads wrong...
KKW,
I just wanted that you recognize that flashlight and you did not managed. It is UF 1504 ODM order.
BTW I got instant response from Brinyte (with email Mnhalen gave).
I figured you would. As far as my communications with them go, brinyte has probably the nicest customer service rep I’ve ever dealt with. No exaggeration at all.
I just received mine and i was quite amazed to see that the centering ring for the xml-2 led is the same Convoy uses in their flashlights, although it seems a bit thinner at the bottom, anyways this is a good thing because i have XPL centering rings from Simon on the way so they would help focusing that xpg-2 that is going in the B158.
