You guys might want to take a look at one of those cheap RC watt meters if cost is a concern and current measurement is the only thing that interests you. I got mine off Ebay for $14 and it seems reasonably accurate.
KuoH
KuoH
But the question would be what voltage drop will be caused by the meter… The measurement will be accurate but the current could be much higher if the drop is too large to be negligible.
Will try to get a quote on Monday. DMM is not in flashlight department, so it may take another few days more to get an answer.
Sweet, thanks for doing the legwork
I’m also interested in the UT210e
If we need more participants for the price to drop
UNI-T DMM's have been rock solid for me - I got two, never a problem. A "super tech" I work with has like 5 of them all over his lab, plus others he has at home. He's got a Fluke also, but loves his UNI-T's.
I'm in on a UT210e deal for sure. The UT204A is $41 at FastTech here.
Dale has a MasTech, not sure of the model...
So you can tell from the fuse used if it is a good or a bad quality DMM.
The big fuses are only necessary when working with higher voltage and high current, like in industrial settings.
The small fuses can break anything at low voltages, but the meter may not have enough protection to handle the current.
Clamp meters are not precision meters, but are fine when a few percent tolerance is acceptable. They are not good at lower currents, there the precision will be even worse and it is important to zero the meter
I’m in on a UT2010e at the mentioned price range, but I prefer an option for direct pay, not through PayPal if that’s possible. Interested regardless, awaiting details.
Phil
(Edited my post and noting that PayPal is pretty universal and I’m quite sure will be usable here if you want it- I just prefer otherwise where I can)
Hi guys
I am.interested in the 210e group buy. Paypal please
Useful meter with decent reviews.
I will support a group buy for the 210E as well.
A look at the Uni-T UT210E - Page 1
I’m also interested in the UT210e, but it will have to wait until the 27th for me to get it - Christmas left me broke;-)
-Chuck
-Chuck
If you have to wait that long, you might have to wait much much longer. Chinese New Year is coming soon. :_(
Also interested in UT210E in a good price
Interested in the 210E for a good price :-)
Thanks for making me want a device that I never missed before
Ahah… It happened the same to me….
Mmm to be honest it happens constantly… And I’m sure I’m not alone in this boat…
Table is up (GB-thread). Be the first to get notified when GB is up. Vendor will contact supplier in the next few days.
Please add me to the table for the clamp meter.
Cheers.
I am interested in the Uni-T clamp meter, what do I need to do to join the group buy?
I bought my Mastech MS2108A trying to upgrade from the Velleman DMM I had that I knew was lousy with stock leads but seemed pretty close with home made 8.5” 12Ga Turnigy leads. But I was getting into higher amperage lights and knew too that the Velleman was gonna blow. I’ve read over 21A on the Mastech, thinking I might have seen 36 once but am not sure, that was on a big triple XHP-70 light if I recall correctly but chances are my memory is jerking me around again.
At any rate, I’d like to get one of these to stay on the same page with y’all, have a comparison with the the Mastech and see if we can find “the truth”.
I just ran a test on the Lucky Sun D80 BLF Special Edition, stock group buy light that I received around 10 PM on the 28th of Dec.
With a Sony VTC5 at a rested 4.20-4.21V I got these readings…
6” 20Ga loop from the negative pad, flashlight fully assembled (sans reflector and lens)…. 3.92A
6” 20Ga leads soldered to each pad of the Noctigon, directly connected to the cell… 4.99A
20.5” 12Ga loop tail reading, still same C5 cell… 4.36A
Velleman DMM with 8.5” leads, same cell… 4.04A
So I’m willing to buy this Uni-T model for verification of what I’m actually using now, and comparison to what y’all get using this clamp meter. Should prove interesting…
Dale, Freeme may see your interest here, or you can post “I’m in for the UNI-T” in his groupbuy thread linked in the OP.
23) DB Custom
I am interested in the Uni-T clamp meter…
