I don’t think I missed your point, but that we’re trying to focus on different points. (though misunderstanding is very possible in short text based communication)
Unless the “redone” light is made by Brinyte it’s a moot point, because that’s who you’re contacting (we all know how common similar looking lights from different manufacturers is). If it is done by Brinyte, perhaps more patience is required before you get a response, I bet around Christmas and New Years is a bad time to expect quick communication.
I’m still suspecting 50pcs isn’t enough to get them to change the design at all though, based on their reluctance to sell hosts as part of the group buy. Had they been willing to sell hosts at $20 each I would have bought 30 hosts instead of 20 lights and 20 bare pills. I try not to complain about it, because I realize I have to deal with their business model, not what I wish it was.
Had no probs with communication from Brinyte. And I’ve got two batches of lights from them. I ordered two B158’s as test samples, and they kindly put my own logo on the lights, even for just two.
Back onto the topic of modding, I’m still waiting for my pills from Gearbest. Delivery seems slow, even for one of these sorts of places.
4.1-ish A on a Samsung 30Q fresh from charger (also djozz fet driver).
I made a video to show that measuring the way I do (voltage measurement over a 0.01 Ohm sense resistor) gives some variation, when the (fat solide copper) wires are pushed down well, it is between 4.1 and 4.2A:
I use UNI-T UT210E clamp meter and very thick gage wire. Maybe it has higher readings than your dmm? If so that would mean that it draws about 4.1 as with your cell (HG2 and 30Q are almost same in performance), and about 3.6A with panasonic NCR PF... But I don't really think it reads wrong...
KKW,
I just wanted that you recognize that flashlight and you did not managed. It is UF 1504 ODM order.
BTW I got instant response from Brinyte (with email Mnhalen gave).
I figured you would. As far as my communications with them go, brinyte has probably the nicest customer service rep I’ve ever dealt with. No exaggeration at all.
I just received mine and i was quite amazed to see that the centering ring for the xml-2 led is the same Convoy uses in their flashlights, although it seems a bit thinner at the bottom, anyways this is a good thing because i have XPL centering rings from Simon on the way so they would help focusing that xpg-2 that is going in the B158.
I will do measurement again and will take pics. It really jumps high but it settles at lower A after 2-3 seconds. I will show result again when I fill up NCR PF.
I'm not too happy with the current jumping up and down in my measurement above, with the thick copper wires I do not get a good enough contact for a stable current.
Yes. I measured again with uni-t ut210E clamp meter.
LG HG2 (brown), Panasonic ncr PF (green). Both charged to 4.25V.
This clamp meter has a bit of jump than it settles on real readings. Silicone 12AWG high strand wire used with tinned ends(maybe I should leave exposed wire for better contact?)
So HG2 has 4.4A while NCR PF has 3.9A readings.
I will mention that this was taken with savage finger press on battery - and exposed aluminum at the end of flashlight tube. Since this meter has hold function my wife pressed it :)
Also if you will gently press you will get even lower readings than that. Interesting... Gentle press low A readings, savage press higher readings.
Maybe all that means that solid + - contact(firmly pressed battery inside flashlight) also has some influence on current draw? I don't know.
This stands to reason since contact area and total number of contact points will definitely affect the contact resistance. I would think that well mated surfaces would be more influential than just pressure alone.
There's a couple of factors from my experiences. For my test leads that simply have solder blobs at the end, I refresh the solder on occasion and get higher amps. I've also found NO-OX-ID treatment on the solder blobs will sometimes bump readings, or stabilize the readings. In addition, sometimes a heavy wire jumper from batt- to the body tube gets lower lumens measurements than a fully bypassed tailcap assembled on the light. So, there are issues in contact surfaces.
Heat the end of your jumper till the solder melts, then mash it flat quickly with a screwdriver blade. Gives you a lot more strands in contact with the flat battery end and hopefully more current flow. Not sure what to do with the body end as each light will be a bit different.
I told ya! I wasn’t exaggerating when I said they have the nicest customer service rep I’ve ever dealt with. I’m talking USA too. They sent me a personalized Christmas email when it had been more than a month than I had talked to anyone there. I guess the key is having the right email address. If anyone ever wanted the email just shoot me a PM and I’ll pass it along.
