First Attempt Rayfall headlight Mod
22 posts / 0 new
chadvone
chadvone's picture
Last seen: 1 month 1 day ago
Bought this. http://www.gearbest.com/led-flashlights/pp_70417.html
Headband was to small. PWM. Blueish tint. Terrible UI. Plastic Lens. I like the O-rings, switch location, balance, aluminum reflector, and the beam was a good mix for my style of hiking and outdoor travels. I have decided to attempt a driver and LED swap. I contacted Richard at Mountain Electronics, to work out some possibilities. He asked for some photos of the light. Here they are.
I am leaning towards a Qlite driver, if we(Richard) can figure a way to hook it up.
I WILL edit this thread as needed to add info, clean it up, etc. Oh, and for spelling mistakes. But will do my best to keep important info.
Edited by: chadvone on 01/05/2016 - 17:06
chadvone
chadvone's picture
EDIT, had trouble with uploading photos.
1-5-16 Edit. The Qlite has a custom option. Where you can pick your output levels. I have been looking for the perfect output levels since I got into flashlights. One of my favorite UI’s is the Novatac lights, if you hacked it you had your choice of 4 levels out of 21 possible. Other lights levels to far apart, some to close together. Some have to many, some not enough. So how many levels do I need/want?? What are my ideal lumens??
How do I attack this with sanity. Lets keep it simple. I will start with 2 modes. There will be more, but I figure I needed to find the 2 levels I that fit me the most.
I took 9 lights out for a walk. Used one light at a time and picked a Low and a Hi. Lights ranged from Wizard to M2X-U2 Javelot. I had flood and throw. Warm and Cool tints. They all had more than 2 modes. I found the lowest I could easily navigate a known trail with at a slow walk. Next I found the lowest level I could easily navigate off trail in heavy woods, scan for reflective markers 200 plus yard, find rabbits Red was tracking, Etc etc etc. It was a great night for flashlights, no moon, snow, clean air. Processed all this in my Bic and Mead computer. My numbers were 43 and 159.
Factoring in the conditions of tonight. My low should be between 45-60 OTF My hi should be between 170-210 OTF
Well I did some playing (have been for years) with low modes. Attempted to see how many lumens I could shine directly at Heather without waking her. Trips to fridge and toilet, adjust the head, etc etc. I came up with 5-7. So to simplify my choices I have came up with.
5-50-200-MAX
bugsy36
bugsy36's picture
Last seen: 8 months 1 week ago
With that switch....That one should be easy for Richard to come up with a driver (he has two models) . Since there is no battery in that one there should lots of room. Just ask him to play it safe and give you some extra length on the emitter wires. I have recently purchased and used 4 of his e-switch drivers.
It is really too bad that Rayfall is one of the worst companies to deal with. They have a product line that has a lot of potential but as they told me they just do not have the time to deal with end-users.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
chadvone
chadvone's picture
Thanks for the reply and the hope :bigsmile:
I have taking many lights apart, few I have assembled.
chadvone
chadvone's picture
Anyone have any idea’s if the switch can be removed??
chadvone
chadvone's picture
Updated post 2 with some over thinking. I will keep post 1 focused on the build and use post 2 for my thought process.
Next step in level selection will be stealth level.
bugsy36
bugsy36's picture
Don't try and remove the switch if you can avoid it. It looks like the wires are long enough there. Also forget about the modes. Go with the moppydrv on this driver http://www.mtnelectronics.com/index.php?route=product/product&path=67_11...
Here is what is available with moppydrv:
User Selectable Groups:
MAIN GROUPS | [SPECIAL/DOUBLE CLICK ACCESS MODE]
  1. 100% Only
  2. 5% - 100% | [100%]
  3. 30% - 100% | [100%]
  4. 70% - 100% | [100%]
  5. 50% - 10% | [100%]
  6. 75% - 20% | [100%]
  7. Moon - 30% - 100% | [100%]
  8. 100% - 30% - Moon | [Strobe]
  9. Moon - 20% - 70% - 100% | [100%]
  10. 100% - 70% - 20% - 0% | [Strobe]
  11. Moon - 5% - 15% - 50% - 70% - 100% | [100%]
  12. 100% - 70% - 50% - 15% - 5% - Moon | [Strobe]
  13. 100% | [Strobe]
  14. Strobe | [100%]
  15. 100% | [Blink1]
  16. 5% - 33% - 100% - Blink1 - Blink 3 - Beacon | [Strobe]
chadvone
chadvone's picture
Yeah. I have thought of that option. Not sure the levels I want are there.
Are those percentages based on lumens or drive current ?
Anyway I am working on stealth level. Don’t want to get shot on the way to the fridge or toilet. Don’t want to get lost either Smile
electricjelly
electricjelly's picture
Last seen: 6 hours 15 min ago
In my opinion, the best headlight ui out there is Dr Jones’s lumodrv.
From his site
“Key features: Easily accessible ramping (just press and hold); hidden extended modes; double-click to high etc.; momentary mode; battery indicator and low-batt step-down.” I have built three headlights using this ui. My latest and now my favorite is a noctigon triple nichia 219c crammed into a skilhunt h02 host, running a Dr Jones lumodrv driver bumped up to 4.5amps.
It looks like you can fit a triple noctigon in there no problem.
bugsy36
bugsy36's picture
Speaking for myself, I would much prefer Mobydrv/Q as it is much more like the UI's I am accustomed to. The new Nitecore HC30 has that ramping UI and makes me nuts....BUT...that is just me.
Chadvone - I do not know if those percentages are based on Amperage, Output, or PWM. More inclined to think PWM because as far as amperage and output there is curve involved but again I do not know. The last two I just received (standard 3.04A) were flashed with STAR and I just asked Richard to space them evenly.
Star is much more like what I am used to.
chadvone
chadvone's picture
electricjelly— nice build, I will check out Dr Jones drivers.
bugsy36— UI’s have made me crazy since I got into lights. Richard told me he could get them close to the levels I wanted.
Novatac and HDS has spoiled me on UI’s. Double click to toggle between 2 modes of your choice, click press to turbo(or just press for mom-turbo), and a triple click for your 4th level. How can that be beat ???? There downside, No headlamp, price, 18650, runtime, and max output.
update— Richard is making me a driver with close to 5-50-200-max
updated post 2 or 1 by the counter
chadvone
chadvone's picture
Got my driver today Qlite with star program. All excited to hook it up. But but….
I don’t know what leads go where.
I have 2 leads on star side. 2 leads on back side.
I am guessing back side are for LED Star side are for switch
Where do I hook the battery leads ???
I am thinking spring post and outer ring.
bugsy36
bugsy36's picture
Post a pic so we can see
chadvone
chadvone's picture
pilotdog68
pilotdog68's picture
Last seen: 3 months 2 days ago
Sounds like you have it right, but I agree with bugsy, a picture would help.
chadvone
chadvone's picture
Pics came out darker than I expected, I can brighten them up and try again if its to dark to tell anything
pilotdog68
Yes, I believe everything looks right
chadvone
chadvone's picture
Switch = Star 4 —> GND , I haven’t learned that language yet Smile
bugsy36
bugsy36's picture
The star side is for the switch AND battery spring. The other is the emitter.
chadvone
chadvone's picture
Ok, gonna hook the power up to the center post and the outer ring.
Postman lost my lens today, hoping they find it today.
chadvone
chadvone's picture
Thanks for your help guys.
chadvone
chadvone's picture
I was too excited to take assemble pics. Got it hooked up. Did a short test. Liquid taped all connections, and back of reflector.
Waiting on lens. Should be here tomorrow.
I asked Richard to do custom levels of 5-50-200-MAX.
I just lightboxed it and got 7-47-201-640. I scale everything out past 200.
I would have to say he did an EXCELLENT JOB at getting them close.
Thanks to ALL that posted to this experience. I am hooked at modding.
Chad
