So the consulate told me that VAT is only refundable if you shop in Italy. VAT is non-refundable for online orders.
Ballast and bulb have been ordered!! Also bought the OEM cooling fan, the 4 segment display, and both hot and cold restrike ignitors so that I can run multiple different bulbs from the same ballast. Ballast has a variable output from 381watts to 1000watts so if for whatever reason I have problems with the 1000 bulb running too hot for my reflector I can scale back to something with a more manageable heat output.
After 3 months of back and forth discussion with the MFG and having them accidently ship the ballast to the wrong country and getting all the problems corrected the ballast finally arrived. After all its escapades it arrived in pristine condition! Lamp should arrive soon too but sourcing the lamp holder is still a problem. I may be able to power it up without the lamp holder though. To be continued....
Goodies. Yum..
Intense! Short-Arcs can sheer out some real KCDs, and in a reflector of that size i can see it shoving a beam well past a mile.
Oh yeah. I think a mile will be an easy target for this light. We'll see though and we don't have much longer to wait before its fired up. Bulb arrived today.
I have all the major components. All I need now is the PGJX36 lamp holder and I can finish the light up!
Decided to test everything out just to ensure everything works as it should. After firing it up I quickly found out its best not to run this light in the house LOL. I wouldnt recommend doing that again.
To give you an idea of how bright it is here it is compared to a standard 60watt incandescent bulb.
Everthing worked perfectly except the 4 segment display. I never could get it to come on. I should have been able to dial down the wattage to run a much lower wattage bulb but since the display doesnt seem to work I may have to get the MFG to send me a new one or buy a DMX controller to control the ballast.
Also I'm not too sure how my reflector is going to handle that much heat. Out in the open my fan can easily keep the bulb cool. The ceramic base never exceeded about 150F but I could feel the heat from about 2-3 ft away, and those desk covers under the light started to melt. Inside of an enclosure I'm going to have to have some powerful air circulation going on to keep the bulb and reflector from getting damaged. The heat is actually much greater than I had anticipated...
Well, now you know how 85000 lumens on your desk look like :bigsmile:
Btw, if you don’t get that display working, just get yourself a clamp ammeter. Measure current*volt to the lamp, and you know the wattage.
I dont know whether there is a such thing as being scared of light but I certainly know I was pretty "scared" when the lamp just kept getting brighter and brighter and showed no signs of slowing down Lol! Even people who were in my house who know nothing about lights were like "What in the world are you doing!!!".
Polari do you think its safe to measure the voltage at the bulb while the bulb is running? I know the starting voltage is in the order of several thousand volts, but the running voltage is, if I recall correctly, about 85 volts. Multimeter should be able to handle that i think.
Just measure voltage and current between ballast and ignitor, and yes, should be around 85 volt on max power (when the lamp is warmed up) and approx 300 volt for a brief second during the ignition, so totally safe for a multimeter. For the current, around 12 amp on max. A clamp ammeter will definitely save you some hassle.
And no, do NOT hook up anything between the ignitor and lamp before ignition
Took these pics a while ago before I blew the bulb by trying to hotrestrike it lol! The bulb was just sitting in the reflector. Not sitting straight at all which means when it is properly aimed it will be a much tighted beam. Walked about 400ft away from the light and from that view I could see that the entire sky was lit up!! Beam extended as far as I could see. Camera couldn’t capture how impressive it was.
I pointed it at the tree line about 100ft away and then aimed my FF4 at the same tree line. Couldn’t even see the FF4 the HTI bulb was so freakin bright!! Scary bright I’m telling you haha.
Anyway the light is slowly coming together. Got set back cause I blew my bulb, but I’ll be buying a new one soon gonna and slowly gather the rest of the parts I need.
Oh, sorry about your bulb. I have played with similar bulb 705 HTI in 9.5” reflector, an 16” reflector. They do take some time to get to temp, and they put out a lot of light, but can never match dc zenon
lamp for cri, and crazy tight beam. For hot re-strike, it would be better to get double ended bulb. They are even brighter, and get to temperature faster. You may need a different ignitor for hot re-strike.
By the way,did you manage to find impossible to get socket for that bulb.
Dave
No I have not been able to source the bulb socket yet. I have found one place to get it, but I would have to buy them in bulk as they will not sell a single socket as it is a very low demand product. So I’m thinking I may have to fabricate a mount myself but I’ve been hesitant to do it because of how I would have to make it. There is a lip on the bulb that I can fab a mount to clamp on to but the problem is that this lip is very close to the terminals on the bulb. Anything I would fabricate would have to be made of metal and during the high ignition voltages I’m afraid I may get some arc over from one of the terminals to the mounting mechanism. The proper socket is made of ceramic, which is the material I should use but I’m not sure how mold ceramic.
Ive thought and thought about how to mount a double ended lamp in my light but I dont think its possible without using a different housing and making the light bigger. I could do that but for now I think Im gonna try to make a single ended lamp work as its much easier. I have both hot and cold restrike ignitors for my ballast so the ignitor is not an issue.
You can get GY-9.5 sockets from 1000 bulbs. Perhaps 705 HTI is worth a look, as they cost less than your bulb, and have a 4mm arc. Cooling this bulb may be easier as the socket is a little smaller in diameter
for your small vertex hole. Also your reflector is Optiforms P-19-3-AQ
Dave
That HTI bulb does look nice. My ballast is variable output and could definitely power it but the 4 segment display controller I bought for it does not work. Your suggestion is probably my best option but I’ll have to contact the ballast MFG and find out how to lower the output without the using the display to do it. It has a DMX interface connector so I might be able to use one of those controllers to do it. I have searched to the ends of the internet for the PGJX36 socket for my current bulb and nobody has it except in bulk or for extremely high prices.
Any updates? More beamshots?
Nah. I think I gonna use this 1000watt ballast and HTI bulb to build a work light. I’m gonna use this reflector for the UHP light I’m working on. I’m afraid the reflector is gonna burn with the 1000watt bulb and I’m not interested in losing my reflector right now LOL
Weird. That post of mine was much older, before you made your new thread. Hmmm…
