Good to know. Thanks texaspyro. :)
Also, we know there's a spike in this design, think from comfy's tests on a scope and think Richard confirmed, and the 13A can tolerate it, but we've been suspecting the 25/45/85 is more sensitive to it. On the 85's w/Narsil, the 0.1 uF cap across gnd and Vcc would fix it, but I thought that didn't seem to work on the 25 w/OTC firmware - I had it on and took it off. Ohh - I can still program the MCU's btw with the SOIC-8 clip with that cap jumper on the MCU.
In Spain itās a tradition to get presents from the āThree Magiā on 6th of January, so here is mine for you.
It is designed so that, in case it is needed, C2 could be easily stacked over diode and C1.
If there is something you think could be improved, let me know.
https://oshpark.com/shared_projects/KhXTokok
Iām far from beeing an expert at this circuit/electronics stuff, but may I make some suggestions:
-in my mind this thread deserves getting stickyād, I think itās important atm (the more people see it the more people could contribute)
-would be nice if everyone that wants to share his experiences would give detailled informations on:
EDIT: by the way: thanks Tom for sharing your experiences and coming up with solutions, great work! May I ask what start-up time you had set, 64ms?
I've built a ton of well working 85's and a couple of 25's now, so I could certainly do this.
We are eager to know about your experiences
Iāve yet to run into problems, but Iāve only built one driver.
wights FET+1 Board
ATtiny25
PSMN3R0-30YLD FET
1x XM-L2
bistro rev. 165
4ms start-up delay
Only thing thatās not working for me is the moon mode, it just doesnāt light up. Will try reflashing tomorrow to see if itās just too low of a PWM-value.
Tom, did you manage to build a fully functional triple with a 25/85 driver yet? From your experience with that one issue not showing using a weak cell, Iād think the more amps we push through the FET the more likely weāll see weird behaviorā¦ Also, did you always use SIR800DP as FET? Again, thanks for all the insights.
Hhmm, everything I got and used has been posted here, maybe not all summed up in one spot though.
The fuses are documented in the beginning of the source code, and also in the t85fuses.bat file, also shared on the google doc link (fuse values tell you the start-up time being used).
If that doesn't work, please let me know. Atmel fuse calculator here: http://www.engbedded.com/fusecalc/
I'm @work now, so don't have access to all my resources though, and don't have the time here either.
I use the SIR800DP FET exclusively now.
For a triple? Yes - in a SupFire M6 that I upgraded. Also had enough problems with a 219C and a high amp single LED, and solved the problems.
For your moon mode problem, are you using a 380 mAh 7135? If so, you need a higher value PWM. You need maybe a min value of 4-5 for 380's, for 350's, a PWM value of 3 always worked for me, using PHASE mode of course, not FAST.
I ensure now I use only 350 mAh 7135's in all FET+1 drivers.
Thank you very much Tom. Iāve been reading through all different types of threads concerning driving a FET properly, but having major problems understanding everything and not confusing stuff. Even the āoldā threads with great inputs from comfychair, PilotPTK, wight, JackCY and many more. What a pity most of these guys left and comfyās pics are all goneā¦ Iām glad that youāre still here!
ATM, I only have tiny25ās here, so my plan was to illuminate the bistro with a triple XP-L HI.
But with those issues reported especially with big amps, I thought I wouldnāt be able to get it running properly. Heck, Iāll just give it a try.
EDIT: yes, i was using 380mA AMCās. Thanks for the advice
Hhmm, Mitko led me to believe the FET+1 wight drivers were maybe not performing so well, so my last driver mod/build was using a 25 on a single FET driver, and found the "fix" was to stack a 2nd 10 uF cap on the regular C1 cap (doubled up).
Didn't use Bistro, but believe I tried it and had the same problem before the fix, so I think the double up cap would work fine for Bistro. I'm thinking now, Mitko might have run across an issue with using firmware not supporting FET+1's well, where you don't get the max amps you can from the FET, so think it was a firmware issue, not hardware issue of the driver.
So it's weird, but, I got two fixes I've been using - a 0.01 uF cap across the grnd and VCC pins of the MCU (on FET+1's using Narsil), or stacked C1 caps (straight FET driver running my own firmware for a power switch light) or the equivalent with a 22 uF cap instead of the 10 uF used for C1.
Also the 12K resistor across the FET gate worked great to 100% eliminate the flicker going from hi to moon on a power switch setup using a Tiny25 with FET only driver.
Thanks again for taking your time and sharing very useful information Tom.
I played with my driver today, swapped the 380mA AMC for a 350mA one, still no moon. Had to adjust the values. I wonder why this driver doesnāt show any of the issues thatās been talked about. Maybe Iāll encounter some when I hook it up to a triple. Itās still driving a single XM-L2 now. I am also going to test a longer start up time fuse setting to see if thatāll make any difference.
What PWM value was it before/after for moon? I don't think the problems consistently occur on every driver, every LED/amps, etc. Lots of variables.
I builded my first A85 driver today, tom`s design( Thanks for your effords mate) and initial tests shows its has great potential especialy in Y3 style/double flashlights, will update tomorroy with some questions cause my kids want a bed story
Tom - Your Narsil looks very impressive!
Started with
380mA AMC and PWM-value 3, no light.
350mA AMC, PWM-value 3, no light.
350mA AMC, PWM-value 4, one of the lowest lows Iāve seen. Very cool to look at, but for me maybe a bit too dimm in terms of useability.
350mA AMC, PWM-value 5, thatās what I went with for now.
I didnāt know that a X+1*AMC350mA-driver can give that low of a low mode!
I used TKās level_calc.py to calculate ramp levels. More re-flashing to come, want to play around with it some more, calibrate voltage and adjust OTC-values to my liking (faster).
I agree with bugsy36, your Narsil looks very impressive, indeed.
Hi guys, could someone please help me with troubleshooting?
Iām trying to get bistro running on PDās Double Down driver, but it wonāt flash.
ATtiny25 is mounted to the driver already, driver is installed in a light with long wires.
I get this
verification error, first mismatch at byte 0x0000
0xff! = 0x87
I donāt think the problem is in the connection, I can flash tiny25 airwired, but not mounted. Have my connections to the programming clip like in Hoopās tutorial.
Because of the long wires, I was able to desolder C1 and tried to flash again, same story.
Do I have other options before pulling off the tiny25 to flash it unmounted?
EDIT: Never mind. I donāt know how but I got it running. I have a new favorite light now:
EE X6 3x XP-L HI U6 5A, bistro on PD68DD with FET+2, itās amazing!
Thanks!
Thanks, any Q's/comments/thoughts/suggestion, please let me know. Always look'n for feedback.
Thanks Too! Glad your problem worked out. I found a few issues in getting those errors, and some others, from time to time:
Looks like Atmel has been soldā¦ to Microchipā¦ so long competitiion, you will be missed.
Sold again?
BTW, stacking a second 10uF cap works like a charm, now my flashlight is flawless.
My sincere congratulations to all the people who made this possible
Ugh, >600 posts. It feels like being back in the booster seat. If Iāve ever gotten mad at a noobie for not reading the entire thread (I have!), I repent. I was trying to read front to back, but itās taking a long time. Maybe Iāll try back to front.
Iāll throw down a few things now anyway with only 20% of the thread under my belt so far. I apologize in advance.
