Attiny25/45/85 FW Development Thread
I've built a ton of well working 85's and a couple of 25's now, so I could certainly do this.
We are eager to know about your experiences :slight_smile:
I’ve yet to run into problems, but I’ve only built one driver.
wights FET+1 Board
ATtiny25
PSMN3R0-30YLD FET
1x XM-L2
bistro rev. 165
4ms start-up delay
Only thing that’s not working for me is the moon mode, it just doesn’t light up. Will try reflashing tomorrow to see if it’s just too low of a PWM-value.
Tom, did you manage to build a fully functional triple with a 25/85 driver yet? From your experience with that one issue not showing using a weak cell, I’d think the more amps we push through the FET the more likely we’ll see weird behavior… Also, did you always use SIR800DP as FET? Again, thanks for all the insights.
Hhmm, everything I got and used has been posted here, maybe not all summed up in one spot though.
The fuses are documented in the beginning of the source code, and also in the t85fuses.bat file, also shared on the google doc link (fuse values tell you the start-up time being used).
Google Drive share for Narsil
If that doesn't work, please let me know. Atmel fuse calculator here: http://www.engbedded.com/fusecalc/
I'm @work now, so don't have access to all my resources though, and don't have the time here either.
I use the SIR800DP FET exclusively now.
For a triple? Yes - in a SupFire M6 that I upgraded. Also had enough problems with a 219C and a high amp single LED, and solved the problems.
For your moon mode problem, are you using a 380 mAh 7135? If so, you need a higher value PWM. You need maybe a min value of 4-5 for 380's, for 350's, a PWM value of 3 always worked for me, using PHASE mode of course, not FAST.
I ensure now I use only 350 mAh 7135's in all FET+1 drivers.
Thank you very much Tom. I’ve been reading through all different types of threads concerning driving a FET properly, but having major problems understanding everything and not confusing stuff. Even the “old” threads with great inputs from comfychair, PilotPTK, wight, JackCY and many more. What a pity most of these guys left and comfy’s pics are all gone… I’m glad that you’re still here!
ATM, I only have tiny25’s here, so my plan was to illuminate the bistro with a triple XP-L HI. :smiley:
But with those issues reported especially with big amps, I thought I wouldn’t be able to get it running properly. Heck, I’ll just give it a try.
EDIT: yes, i was using 380mA AMC’s. Thanks for the advice
Hhmm, Mitko led me to believe the FET+1 wight drivers were maybe not performing so well, so my last driver mod/build was using a 25 on a single FET driver, and found the "fix" was to stack a 2nd 10 uF cap on the regular C1 cap (doubled up).
Didn't use Bistro, but believe I tried it and had the same problem before the fix, so I think the double up cap would work fine for Bistro. I'm thinking now, Mitko might have run across an issue with using firmware not supporting FET+1's well, where you don't get the max amps you can from the FET, so think it was a firmware issue, not hardware issue of the driver.
So it's weird, but, I got two fixes I've been using - a 0.01 uF cap across the grnd and VCC pins of the MCU (on FET+1's using Narsil), or stacked C1 caps (straight FET driver running my own firmware for a power switch light) or the equivalent with a 22 uF cap instead of the 10 uF used for C1.
Also the 12K resistor across the FET gate worked great to 100% eliminate the flicker going from hi to moon on a power switch setup using a Tiny25 with FET only driver.
Thanks again for taking your time and sharing very useful information Tom.
I played with my driver today, swapped the 380mA AMC for a 350mA one, still no moon. Had to adjust the values. I wonder why this driver doesn’t show any of the issues that’s been talked about. Maybe I’ll encounter some when I hook it up to a triple. It’s still driving a single XM-L2 now. I am also going to test a longer start up time fuse setting to see if that’ll make any difference.
What PWM value was it before/after for moon? I don't think the problems consistently occur on every driver, every LED/amps, etc. Lots of variables.
I builded my first A85 driver today, tom`s design( Thanks for your effords mate) and initial tests shows its has great potential especialy in Y3 style/double flashlights, will update tomorroy with some questions cause my kids want a bed story :slight_smile:
Tom - Your Narsil looks very impressive!
Started with
380mA AMC and PWM-value 3, no light.
350mA AMC, PWM-value 3, no light.
350mA AMC, PWM-value 4, one of the lowest lows I’ve seen. Very cool to look at, but for me maybe a bit too dimm in terms of useability.
350mA AMC, PWM-value 5, that’s what I went with for now.
I didn’t know that a X+1*AMC350mA-driver can give that low of a low mode!
I used TK’s level_calc.py to calculate ramp levels. More re-flashing to come, want to play around with it some more, calibrate voltage and adjust OTC-values to my liking (faster).
I agree with bugsy36, your Narsil looks very impressive, indeed.
Hi guys, could someone please help me with troubleshooting?
I’m trying to get bistro running on PD’s Double Down driver, but it won’t flash.
ATtiny25 is mounted to the driver already, driver is installed in a light with long wires.
I get this
verification error, first mismatch at byte 0x0000
0xff! = 0x87
I don’t think the problem is in the connection, I can flash tiny25 airwired, but not mounted. Have my connections to the programming clip like in Hoop’s tutorial.
Because of the long wires, I was able to desolder C1 and tried to flash again, same story.
Do I have other options before pulling off the tiny25 to flash it unmounted?
EDIT: Never mind. I don’t know how but I got it running. I have a new favorite light now:
EE X6 3x XP-L HI U6 5A, bistro on PD68DD with FET+2, it’s amazing!
Thanks!
Thanks, any Q's/comments/thoughts/suggestion, please let me know. Always look'n for feedback.
Thanks Too! Glad your problem worked out. I found a few issues in getting those errors, and some others, from time to time:
  1. Not having the grnd wired properly wired in my clip setup (once I did this, many intermittent probs went away)
  2. flux on the MCU pins (and gets on the clip contacts) causing intermittent issues (cleaning with isop. alcohol works wonders, always!!)
  3. not getting a good "clip" on the pins, maybe mis-aligned, maybe something in the way (not happening very often now)
Looks like Atmel has been sold… to Microchip… so long competitiion, you will be missed.
Sold again? :frowning:
BTW, stacking a second 10uF cap works like a charm, now my flashlight is flawless.
My sincere congratulations to all the people who made this possible :slight_smile:
Ugh, >600 posts. :wink: :wink: :wink: It feels like being back in the booster seat. If I’ve ever gotten mad at a noobie for not reading the entire thread (I have!), I repent. I was trying to read front to back, but it’s taking a long time. Maybe I’ll try back to front.
I’ll throw down a few things now anyway with only 20% of the thread under my belt so far. I apologize in advance.
  • First of all, looks like neat stuff. As you all know, any move to physically larger MCUs is a pain for the CAD folks - so I tend to resist that change. If it nets us nice thermal protection features though, I’ve got to be game! As usual I’d prefer to try cramming in the 20M1 package with ISP headers for programming.
  • On the failures to program - IIRC the OTC can be the culprit here. Again this is only if I recall correctly - but I think that leaving the programming clip hooked up can charge the OTC and prevent additional flashes from being successful. As I recall a trick is to get your hex all ready to flash, discharge the OTC if necessary (with tweezers) and then clip and flash fairly quickly.
  • Tom E - did you ever get a handle on the calibration points you wanted? 0c and 100c are easy to reliably achieve using ice-water and boiling-water so those are common at-home calibration points. Atmel bins some chips (not the ones we buy) for 105c and 125c, I think it’s fair to say that all of them are going to be OK at 100c long enough for a one-time calibration routine. Just throw the light in a plastic bag and drop it in for a while, right?
  • I wonder how much better an LDO driver would fair with the stuff mentioned in post #601 by Tom E. I did publish an LDO driver a while ago - it’s probably suitable for testing. A17DD-SO8+LDO
I got a bit behind here too… though not nearly as much as wight.
If I understand correctly, the driver reset problem was fixed by using a bigger capacitor. It was rebooting on the trailing edge of a FET full-output pulse. So, turning the FET from 100% to 0% caused a spike of some sort.
The brownout detection options don’t seem to make any difference in any cases I’ve tried. The 4ms or 64ms startup delay doesn’t seem to make any significant difference either.
I’m going to have to try some new tricks to get some bricked drivers flashed… I hadn’t thought about manually draining the OTC before or during flashing, but maybe it would do the trick.
Would you care to share your code? :slight_smile:
Also, the last version I have for Narsil was still called eswBrOutCfg. Can I simply rename it, or are there extra changes to pull in along with the name change?
wight wrote: . . .
  • First of all, looks like neat stuff. As you all know, any move to physically larger MCUs is a pain for the CAD folks – so I tend to resist that change. If it nets us nice thermal protection features though, I’ve got to be game! As usual I’d prefer to try cramming in the 20M1 package with ISP headers for programming. . . .
  • Tom E – did you ever get a handle on the calibration points you wanted? 0c and 100c are easy to reliably achieve using ice-water and boiling-water so those are common at-home calibration points. Atmel bins some chips (not the ones we buy) for 105c and 125c, I think it’s fair to say that all of them are going to be OK at 100c long enough for a one-time calibration routine. Just throw the light in a plastic bag and drop it in for a while, right?
  • I wonder how much better an LDO driver would fair with the stuff mentioned in post #601 by Tom E. I did publish an LDO driver a while ago – it’s probably suitable for testing. A17DD-SO8+LDO
I've been pushing for keeping the SSU footprint on the boards and just bending the legs. It really makes it easier to position the programming clip and the hold is much better. Those that have tried it have reported positive experiences so far.
I don't think temperature read calibration is worth the effort. Each light is going to behave differently anyway due to many factors. User adjustable seems the best approach to dealing with all the variables.
I think you may be on to something with LDO, I've been putting my 25/45/85's in buck and LDO (at opposed to zener modded) DD drivers and haven't had any issues yet, but I'm also using an older version of Tom E's FW for the 25/45/85. Unfortunately, the LDO I use is for 2S and higher cell arrangements only.
EDIT: Another benefit of bending the legs (which is easy) and is that the MCU stands higher. It allows low profile components like resistors and small caps to be placed right up to the legs, if necessary. Resistors could even go under the MCU.
