Is it just plug and play?
Like I said, you just have to slightly grind the outside (less than a mm on the diameter)
Congratulations, you can make a review of how you did with pictures and some beanshots?
thanks
greeting
Yeah I may do that this week-end…I’ll make an update
thanks
So, you just unscrew the bezel, then drop the o-ting, glass and reflector :
Stock reflector vs TIR :
You have to slightly areduce the TIR diamter by filing it :
You then just drop the TIR and put the o-ring, then the bezel :
Stock beam at 15cm and 1m :
Now we are talking!! Thank you!!!
Ordered 45 degree model thanks for the info
Thank you
the higher degrees more open?
the spot fades with more or less degree?
Yes, the higher degree provides the more spill (more opened beam).
The spot is quite inexistent with those type of optic
anyone knows a 100 degrees TIR optic mod for the HC30?
Shop?
thanks.
I don’t think you can physically get a 100 degree TIR, the specs are for HALF the angle of spread (ie a 20 degree optic will give you a 40 degree cone).
I switch the led for a warmer last year, change it for a XM-L2 4D. This is how it looked inside. Maybe you have fixed it by now. There is more pics if some one needs.
Thanks for the review!
how you did unscrew the bezel? i can’t get any grip on it.
I used the rubberized side of my mouse pad, pressed down across the top of the bezel with my thumb and twisted. I had to replace the driver in my HC30 already. :~
It worked thanks.
Only problem is that this is no longer waterproof.
. . . Ya, with the bezel and lens removed it would not be waterproof.
Hi, I just swapped the stock reflector of my freshly unpacked HC30 with a 60 degrees TIR optic.
It’s now a useful headlamp for close up tasks !
Thanks for this little mod, I like it much better without the hot spot! Uncertain which lens I preferred as I can’t identify them (I ordered both 45 and 60 degrees, but the text on the label doesn’t help much - 09 122 18 ; 89 5 73 on this one, whatever lens that is). Still doesn’t feel as wide as the flood on my Fenix HP25, but this will do just fine, and I won’t get neck problems from it…
Next step : swap the emitter !
I’ve heard here that it’s always difficult to swap emitter in Nitecore products, but it wasn’t that hard (okay, it’s not a screwable S2 pill…)
Sooo, I put an XM-L2 T6 4C and it’s way more usable now !
Oh, I also replaced the stock clip with an Olight one (much more sturdy) and put 3 neodymium magnets on it to stick it everywhere !
Oh, I put a spring on the positive side to remove the reverse polarity protection
And put a magnet on the negative side, after removing the spring :
Sorry for the last pic, my smartphone made it weird…
Nice job. Do you think it would be possible to swap out the driver too?
