First Attempt Rayfall headlight Mod
With that switch....That one should be easy for Richard to come up with a driver (he has two models) . Since there is no battery in that one there should lots of room. Just ask him to play it safe and give you some extra length on the emitter wires. I have recently purchased and used 4 of his e-switch drivers.
It is really too bad that Rayfall is one of the worst companies to deal with. They have a product line that has a lot of potential but as they told me they just do not have the time to deal with end-users.
Thanks for the reply and the hope :bigsmile:
I have taking many lights apart, few I have assembled.
Anyone have any idea’s if the switch can be removed??
Updated post 2 with some over thinking. I will keep post 1 focused on the build and use post 2 for my thought process.
Next step in level selection will be stealth level.
Don't try and remove the switch if you can avoid it. It looks like the wires are long enough there. Also forget about the modes. Go with the moppydrv on this driver http://www.mtnelectronics.com/index.php?route=product/product&path=67_116&product_id=209
Here is what is available with moppydrv:
User Selectable Groups:
MAIN GROUPS | [SPECIAL/DOUBLE CLICK ACCESS MODE]
  1. 100% Only
  2. 5% - 100% | [100%]
  3. 30% - 100% | [100%]
  4. 70% - 100% | [100%]
  5. 50% - 10% | [100%]
  6. 75% - 20% | [100%]
  7. Moon - 30% - 100% | [100%]
  8. 100% - 30% - Moon | [Strobe]
  9. Moon - 20% - 70% - 100% | [100%]
  10. 100% - 70% - 20% - 0% | [Strobe]
  11. Moon - 5% - 15% - 50% - 70% - 100% | [100%]
  12. 100% - 70% - 50% - 15% - 5% - Moon | [Strobe]
  13. 100% | [Strobe]
  14. Strobe | [100%]
  15. 100% | [Blink1]
  16. 5% - 33% - 100% - Blink1 - Blink 3 - Beacon | [Strobe]
Yeah. I have thought of that option. Not sure the levels I want are there.
Are those percentages based on lumens or drive current ?
Anyway I am working on stealth level. Don’t want to get shot on the way to the fridge or toilet. Don’t want to get lost either :slight_smile:
In my opinion, the best headlight ui out there is Dr Jones’s lumodrv.
From his site
“Key features: Easily accessible ramping (just press and hold); hidden extended modes; double-click to high etc.; momentary mode; battery indicator and low-batt step-down.”
I have built three headlights using this ui. My latest and now my favorite is a noctigon triple nichia 219c crammed into a skilhunt h02 host, running a Dr Jones lumodrv driver bumped up to 4.5amps.
It looks like you can fit a triple noctigon in there no problem.
Speaking for myself, I would much prefer Mobydrv/Q as it is much more like the UI's I am accustomed to. The new Nitecore HC30 has that ramping UI and makes me nuts....BUT...that is just me.
Chadvone - I do not know if those percentages are based on Amperage, Output, or PWM. More inclined to think PWM because as far as amperage and output there is curve involved but again I do not know. The last two I just received (standard 3.04A) were flashed with STAR and I just asked Richard to space them evenly.
Star is much more like what I am used to.
electricjelly— nice build, I will check out Dr Jones drivers.
bugsy36— UI’s have made me crazy since I got into lights. Richard told me he could get them close to the levels I wanted.
Novatac and HDS has spoiled me on UI’s. Double click to toggle between 2 modes of your choice, click press to turbo(or just press for mom-turbo), and a triple click for your 4th level. How can that be beat There downside, No headlamp, price, 18650, runtime, and max output.
update— Richard is making me a driver with close to 5-50-200-max
updated post 2 or 1 by the counter
Got my driver today Qlite with star program. All excited to hook it up. But but….
I don’t know what leads go where.
I have 2 leads on star side.
2 leads on back side.
I am guessing back side are for LED
Star side are for switch
Where do I hook the battery leads ???
I am thinking spring post and outer ring.
Post a pic so we can see
Sounds like you have it right, but I agree with bugsy, a picture would help.
Pics came out darker than I expected, I can brighten them up and try again if its to dark to tell anything
Yes, I believe everything looks right
Switch = Star 4 —> GND , I haven’t learned that language yet :slight_smile:
The star side is for the switch AND battery spring. The other is the emitter.
Ok, gonna hook the power up to the center post and the outer ring.
Postman lost my lens today, hoping they find it today.
Thanks for your help guys.
I was too excited to take assemble pics. Got it hooked up. Did a short test. Liquid taped all connections, and back of reflector.
Waiting on lens. Should be here tomorrow.
I asked Richard to do custom levels of 5-50-200-MAX.
I just lightboxed it and got 7-47-201-640. I scale everything out past 200.
I would have to say he did an EXCELLENT JOB at getting them close.
Thanks to ALL that posted to this experience. I am hooked at modding.
Chad
