mine is regulated with constant current and with 3 x 18650,s ive taken it one many bush walks around 60 mins while on high the whole time and a few 85 min runs on cold nights, once the cells voltage is to low it jumps out of regulation and dim's depending on what battery i use i get the current draw of 1.69 to 2 amps on 2 x 18650,s and it will throw well. i can test my tail cap readings run it on high for 30 to 40 mins re-test it and it will read very close to the starting current so i say its constant current driver thats regulated like the geniune TR-3T6 the TR-1200 is a good torch that gets over looked.
Yeah I know. I mostly prefer floodier lights which is why most of my current ones are mostly flood. That said I definitely need at least one thrower in my "lineup".
it is winter here, Australia is warmer then some other places but i have not done full bore runs in summer yet as its not summer yet, a 2400 mAh battery should be able to give 2.4 amps for an hour in theory, so at 1.7 amps 85 mins is about the maxium run time before it drops out of regulation and the light will dim's.
85 mins timmed on my iphone while bush walking with the TR-1200 on high is as far as ive pushed mine, with 3 x 18650 the current draw is lower so run time should be longer but ive never pushed my past 85 mins as thats a bit extreme on high.
its warming up here and ill try long run test while bush walking on warm summer nights and see if i fry the driver but sofar its a great torch, i have seen some specials for them on here but they are cheap 2 x 18650 versions with plastic lens lols
i would like to try the HA3 model, but ill wait till this one is totaly worn out as my wife brought it for me, it turned out to be one of the best buy,s
Hahaha true flashaholic reasoning..! :D Where did you score your T40CS for $96...? The ONLY thing that even slightly puts me off of the Sunwayman is the "dark ring" around the hotspot as seen below.
The above gif is taken from selfbuilts review over on cpf forums.
I also have a Fannyfire STL-V6 (Sky Ray STL-V2) and it’s a budget xml led value.
My single die emitter green led PT120 aspherical 4D 10,000ma powered Mag build is my best thower @ 4000+ lumen.
