It now has a reverse clicky and a 17DDm FET +1 driver with BLF A6 firmware. I would put better glass in it, but for the life of me I can't get the head open. I really love this pocket rocket. Getting 4.8 amps out of a 30q. In town I can light houses at 2.5 blocks.
Yesterday I coated the threads of some cheap flashlight ( Ultrafire F13; Small-Sun ZY-R13; and other…), had much tolerance with the tailcap.
I used aluminum adhesive tape (0.12mm thickness.), The work came good, now the tolerance is “free but without tolerance” (roughly). After I recommend using Teflon grease.
In the photo, left without modification; to the right with the change.
Filed some parallel grooves into the external heatsink on my modded 3100 lumen DQG 18650 Tiny III.
The heatsink already had fins. But it still felt a bit slippery to me. I used my checkering file to carve groves on top of the fins for added group. Paint job was quick and dirty and my superglue was starting to gel up so the finish isn’t quite as thin as I’d like. I might redo the finish later. Maybe spend more effort at matching the color with the anodizing on the body tube.
On the upside, the new parallel grooves were successful. They greatly increase grip at the head.
I reflowed a 219C off the cheap star it came on and onto a 16 mm. Noctigon. The first try, it shorted + to ground. I didn’t see any bridge when I took it off, but it worked when I put it on the second time.
First, I dedomed the original XM-L in my TrustFire Z5 zoomie. It made a big difference in the spot intensity for this light, and I ended up with decent tint afterward as well! In this case, I’m happy with the outcome, but this light probably won’t get used any more often than it did before:
Second was a dedomed XP-E2, for use in my UniqueFire HS-802 thrower. In this case, the dedome was a bit more difficult due to the smaller die, and I had trouble getting all of the material off the surface. It turned out okay, but had a bit more tint shift than I liked. Still, made a big difference in output. Using my cheap DX lightmeter, so I consider it to be more of a relative change than anything more definite, but:
With all measurements made at a distance of approximately 6’, with the original domed XP-E2, I noted a peak intensity of 23k lux. With the dedomed emitter, the peak intensity went to 33+k lux! Some of that difference may have been due to my spending more time to find the optical depth in the reflector to maximize intensity. I’m happy with the results! Should currently be the longest range thrower in my arsenal until my 75mm 1508 arrives…
[edit]By my calculations, this turns this light into a 100k@1m thrower! :bigsmile:
Finally got that FX3 in. I’ll post a review/mod thread once I get some more parts in. So far, I’m not 100% thrilled with it, but we’ll see what can be done.
Ok, so I was not happy with this light at all. 1.25 amps at the tail and horrible range. I built a MTN MAX 22mm driver, braided both ends and de-domed the stock XM-L2, did not have copper for it. I will need an XM-L2 on copper to finish this one. OMG this thing is a beast! I can now get light on the next farmhouse almost 1/2 mile away!
I am presently carrying an unanodized BLF A6 with short battery tube.
The tail cap’s o-ring prevented it from screwing all the way on. I checked my smallest chain saw file, but it was too big to make the o-ring groove deeper. I settled for a change of o-ring from my junk bag, maybe from an SK-68.
I haven’t done many but I never know how much solder paste to use, I always think it’s better use too much than too little and the excess beads out. They’ve worked so far which is a relief, one less thing to think about.
I’ve watched a few video’s and it looks like the emitter pulls itself into position on the pads by the solder, so I’ve tried to make sure that the Noctigon is near level before I apply the heat underneath using a small gas torch.
Just finished putting together my Convoy M2 host that arrived today.
The Black Maggot work light is going to take a back seat to this M2.
I put in an XM-L2/Noctigon, with 1.4A Nanjg & 1-mode firmware, installed forward switch, bypassed the spring & finished it off with the Neo magnets on the tube with heat-shrink.
I know it sounds boring, but it's a great configuration for a work/inspection light. Hopefully it can take a knock or two....
I use too much solder paste all the time, and even if the led does not suck itself in place with excess solder squeezed out (i.e. Oslons on XP-boards never do that), I still can not measure significant lower performance.
Too little paste almost certainly influences performance.
Sometimes I do what Old Lumens does. After the emitter snaps into place, give it a little tap with the back of the tweezers. You’ll be surprised how much excess solder will pop out of there sometimes.
The wife unit bought me some new Eneloops for Christmas so I've been making some battery packs out of the more beat-up looking older cells in my collection. The wrapper damage came from test fitting experimental 4AA battery holders into non-bored maglite tubes. I don't do that anymore.
The latest ugly eneloop application was to the battery pack of my old cordless Dremel. The original pack was 700ma NIMH in 6s configuration. It never did have any power or run time so I expect both to improve. Only thing is charging is going to take forever with the 200ma dremel charger! That's a Duraloop mixed in with the white and blue.
I finally found, and replaced the reflector to my TrustFire T6-F16.
The reflector original was for a SSC P7 (then adapted to receive an XM-L) and deep 20,5mm.; I put one of 24.3 mm. with a reflector double level. Now the flashlight has reached its harmony, with a gradation between the center and the border.
