ENEDED
Gearbest dropping the ball again, sigh. :|
I interpret GB's 3-5 biz days as this:
"we ain't got it, but we thinks we can get it quick"
So technically true - anything 3-5 biz days is not in stock with GB. The "we thinks" part can drive you nuts at times though .
BOSS1 gb is up for discussion today. Apologize to all for the delay, vendor overlooked one of my 4th Jan reply. I proposed for custom upgrade parts but it was turned down due to low demand (<100). Anyway, we will try our best to group buy back on track and list the stock light up for sale soon.
MAY’s answer was “we may get it next week, if it comes”. Not good enough for me, “3-5 days” here means it shipped and will take 3-5 days to arrive.
Sorry to disorganize the GB. It looked like it was on hold and not moving forward, so I posted about GB.
Back to the original thread.....
Hey Justin - No worries. Soon the wife will join BLF to find out what you need to mod and then order a bunch of stuff for ya....just to get you out of the house. LOL
Yikes, with May saying 'if it comes', I'd be in doubt for sure. Glad to see the GB is getting a bump. Thanks freeme, again!!
I confirm that, just recieved a mail, they ask me could i wait just a little….10-15 working days, maybe a little bit more….
What can i say, i was so exited about that flashlight….
Oh well, stock is acceptable. Time to start setting aside cash for batteries for this ridiculous beast. :P
Have batteries, will wait.
Nice to see you contemplating again Justin, warming up a bit huh? :wink: Beautiful day today, just gorgeous out… 65 and a light breeze, blue skies, but I’m sure we’ll get some nasty yet, always seem to in late Jan or early Feb.
I think its time for you to accept the SI system, that 65 is kinda scary to me
Celsius, meters, good things like that :slight_smile:
He was speaking in Celsius.
it gets hot in Texas :wink:
OMFG! Realy? I cant believe that! Once i had 54 in Egypt back in 1999 and i never ever want to “feel” it again
65……and Tamafly costs 130$….Texas isnt a place for me realy :bigsmile: realy 65? Come on, its unholy temperature
Tom… here we go…
Edit: Sorry, forgot to mention, each LED was tested for 20 seconds.
It was difficult taking photos with my mobile phone of all the readings I took. I eventually only took 2 photos of my setup.
Here I’m measuring a fully charged 25R. I’ve used the 25R to get an indication of the voltage drop when applied to an XP-G2 S4 LED. With initial contact, it dropped to 3.99-4.00 volts.
I then had to dialed in my power supply (seen in the background) to 4.70 volts to get 3.99-4.00 volts when applied to the LED. The wires running from my power supply is thin and quite long.
The wires running from the amp meter to the LED is 18 gauge and around 10cm long. The amp readings I get on this meter is 99% in line with that of my Fluke Clamp Meter.
Here’s what I got. From low to high readings:
IOS XP-G2 S4 2B, domes on
4.6 Amps | 3.97 Volts (18.262 Watts)
4.6 Amps | 3.98 Volts (18.308 Watts)
4.7 Amps | 3.95 Volts (18.565 Watts)
4.7 Amps | 3.96 Volts (18.565 Watts)
4.8 Amps | 3.94 Volts (18.912 Watts)
4.8 Amps | 3.95 Volts (18.960 Watts)
4.9 Amps | 3.93 Volts (19.257 Watts)
I then reflowed my only 5 x FastTech XP-G2 S2 2Bs onto 16mm noctigons, domes on
5.3 Amps | 3.85 Volts (20.405 Watts)
5.3 Amps | 3.86 Volts (20.458 Watts)
5.4 Amps | 3.85 Volts (20.790 Watts)
5.7 Amps | 3.78 Volts (21.546 Watts)
For the fun of it, I them measured 5 x XM-L2 U4 1C I had available, dedomed
4.8 Amps | 3.93 Volts (18.864 Watts)
:wink:
That's right, it only gets that hot down here ;)
shrick - wow, lot of work there - great info! Interesting the FT XP-G2's had the greatest variance, where the S4's and U4's were pretty much in the same range. You did get some high amps from those S2's though, more inline with what Mitko gets I'm suspecting from those #'s. Wonder if the reflow method of temp/time/solder used makes a difference, or just that there's such variance in the LED's, or something. I'm suspecting this more and more, since Mitko does high volume, seems to be fairly consistent results, while for me, I'm a little all over the place - different methods, maybe different time/temps, and I got lower amps on S2's mostly, even with domes on so not related to dedoming.
Will be there a group buy for this light ?
Hope so, soon. freeme's doing it - see his last status on it in post #325 here, probably running the GB from this thread: https://budgetlightforum.com/t/-/35973
Direct drive / solder using 18AWG copper wire, XP-L HI 3B.
BOSS1 on top, TK61 (stock) at the bottom.
How come TK61 so dim? You are outstanding during contest with Courui.
TK-61 gettin schooled by the Boss! :slight_smile:
