Firts unit ordered, great and many thanks to freeme !!
Second as well.
Received PM. Thanks freeme! I will order asap!!
UT210E ordered. Thank you!
UT210E ordered. Thank you freeme!
Hope it gets shipped before Chinese Newyear. Waiting to compare the readings of this one to those of my old DMM.
I have this meter for more than a year and half and I really don't know how to zero it :)
I also got much higher readings than with dmm for high current draw lights.
Also I would suggest very hard press to both surfaces (battery - and exposed aluminum on flashlight, or you could get lower readings).
What happens if you turn the cable the other way around in the clamp?
I got a UNI-T UT203 that I useally use for higher amp readings and when I messure it with the cables the other way I got higher readings.
PM the info please.
I’m on the list Freeme, could you send me the code? thanks for your efforts !
My DMM is rated up to 20A (UT50B here at FT), so don't think it's a problem, maybe?? I do have a couple triples - one S2, one X6, one quad X6, one quad SupFire.
I did do some quick testing on that - pretty sure when the clamp meter read negative, the amps readings was lower. @work now - no access.
Mine has a black button labeled: ZERO, press it, and the reading zeroes ?? Yes - I do always press hard, but also found a little NO-OX-ID treatment helps bump up the readings by improving connectivity at the contact points.
Again over the years, very consistent 2.9A to 3.0A readings with my DMM on 2.8A Nanjg 350 7135 drivers, so always thought my DMM setup was dead-on accurate for these relatively low amp readings. Again, drivers with 350 7135's always read high, 380 7135's always read low. Others have commented on the same thing.
I really need to do more head-to-head testing though, plus I didn't do it today, but plan on bringing my lights/meters into work and compare against the o-scopes with clamp meter attachments we have here. We got Tektronix, Fluke, and I was told the clamp meter attachments were pretty expensive, but I'll get more info on the equipment first. Don't think we do much here with this level of DC voltage at amps this high, but not sure.
One thing to consider is that the meter type has a much bigger impact on DD lights than current-regulated lights.
You can use a multi-meter with a relatively high burden voltage (shunt + fuse + leads resistance) and it will give good results with a regulated light. The driver will simply compensate to get to the correct output current, as long as the cell voltage is high enough.
But that high burden voltage will make a significant difference when measuring a DD light.
Ahh, thanks DEL - was suspecting something like that.
Sprung for insurance, order tracking and and slightly upgraded the shipping to priority direct.
Thanks for the code Freeme, I used your link, but I copy/pasted from one browser to another, not sure how that works.
For those who already have this meter from Banggood, how are the included test leads?
mmm they are standard decent quality AWG14 (externally look-wise, not written) famous brand chinese cable, pretty much identical to mastech
ordered. Thanks very much
Ordered 1. Posted a thank you to freeme in his thread. I'll post a thank you to PD68 here. :)
I ordered mine just now. Thanks for making me buying things i didn’t realize i needed before
Just ordered mine. Thanks for setting this up!
How much is it?
