Do u guys understand that amp reading setup? I don't get what it is...
Also,as djozz uses this method - low value high watt resistor (0.01 ohms or so, 50W) in series with the cell, like a DMM, but you measure voltage across the resistor and calculate amps - supposedly more reliable than amp meters, clamp or DMM's. The resistor is anywhere from 5$ to $8 or so. Mouser has a good Vishay Dale one, 1% accuracy, for like $8. I got a 0.1R on order, and got a great quality 2 post connector all set to go in a small plastic enclosure (connector and enclosure provided to me). Thinking the connector will help with the setup.
This is the one I'll get in my next Mouser order: mouser.comRH050R0100FE02, probably can be found else where, just couldn't find it at a good price.
Ohhh - got my B158 today, finally - shipped Dec 7th - gonna open it up in a few...
I like the zipelgas rig- simplicity and ease of use at it’s finest Besides, I’m a softie for analog meters. I think it goes with me getting old and nostalgic (but not nostalgic enough to fix my Heathkit VTVM and start using it again!)
I’ve used it on almost every flashlight powerful enough, for me to care about amps and no problems so far. Additionally you can always attach heavy duty leads and use it in whatever situation.
But I don’t want to highjack this mod thread, so I created another with a few more pictures.
For painting the inside of the lens area around the LED, would something like Plasti Dip work?
It is pretty matte and easy to use, doesn’t flake for those using dedomed emitters. If you mask off the LED and spray several layers, the mask pulls off with a clean line when you pull it off wet.
Just asking and I will give it a shot when my B158 gets in.
I put LD-2 driver into the pill add XP-G2 S4 2B de-domed and got 2,10 Amps reading on tail-cup (CAT III 1KV 10 A (silicone leads)
I put also BLF A6 A17DD-L FET driver and got same readings more or less 2 A
Does XP-G2 S4 2B LED, limits amps up 2A ?
Using same setup with xml 2 led both drivers, i got 2,85 Amps max. on tail-cup, It is higher than on XP-G2 S4 2B.
Do i got low amps XP-G2 S4 2B leds ? I want more Amps 4-5A would be great.
The LD-2 has a low resistance fet and will limit current to whatever the sense resistor sets it to but does not take into account parasitic resistance in the host.
Take the tail switch apart and clean it and put it back together.
Make sure you have a good driver ground.
Make sure the pill is screwed in tight and that the end of the tube it is screwed into is not anodized under the brass lip.
Make sure the switch retainer is snug.
Bypass the springs and use fat leads on your meter.
I made messurings without host and used both drivers. I pressed driver against battery” + “. and touched leads directly to driver and battery’s ” - “. The LD2/A6 have spring bypss. I got no more than 2.10 Amps on xpg- 2 using A6 driver and , around 2.85 Amps on LD 2, ln host it’s 2.55 Amps. So without host am getting more Amps on LD2 but still below 3. Why is it so ? Why so low readings on A6. Don’t know what is going on.
DMM leads - stock ones never work well, never. You will even get inconsistent results, so whatever you report won't matter til you can give us a real readings with heavy wire leads.
Mmm, disappointing. Is everybody experiencing the same? blitzwing, would have been great if you could do a ceiling bounce between stock and XP-E2 to see the difference.
To get high amps you need to eliminate places where there are voltage drops which are due to resistance. The common places are protection circuits on cells, internal cell resistance, bad switches, coated steel springs, poor ground connections, poor led connections, thin dmm leads, inadequate surface to surface connections, less than optimal fet choices, any or all of these will drop voltage robbing the circuit of the potential of dropping it across the LED instead at higher current. Without seeing your set up all we can do is point to possible sources for you to check.
I just got my B158 and I love it after putting in a MTN-17DDm driver and dedomed XP-G2 S4 2B. I am interested in doing a green led pill. I didn’t order the green version, but I have an extra pill to play with. Does anyone have an led/driver recommendation for a green setup? Alternatively, does anyone know where I could buy the stock green pill only? Thanks
