I ordered mine just now. Thanks for making me buying things i didn’t realize i needed before
Just ordered mine. Thanks for setting this up!
How much is it?
$28
With the effort you put in here it should be free from the supplier. freeme is organising this.
Edit. Took to long to type.
Confirmed as DEL mentioned, the 7135 based drivers do produce amp readings very close, very consistent between the UT50B DMM and the UT210E. Also confirmed, as Dale alluded to, the startling but expected contrast in readings of triple and quad FET DD mods - 8A-9A on the UT50B vs. 11A-12A on the 210E. I always knew my DMM readings were way low on these lights simply due to the fact of what lumens I'd measure vs. the amps.
To compare readings between the two meters, I took my triple X6 modded light and measured normally with the UT50B, but then added the UT210E clamped over one of the UT50B's leads, and the UT210E actually read slightly lower, about 0.05A lower in the 8A range of readings. This confirms to me the readings I'm getting on the UT210E are pretty accurate compared to my UT50B DMM, and the droppage from 11A down to 8A is due to the added resistance of the DMM (and it's leads) itself.
So, it's all good - very happy with the meter . Hope you all find it a step up as well. I think it's great we got so many signing up for this meter, since we will be on equal ground, plus we will probably get a good idea on reliability to see the # of DOA's and failures over time, which I hope we don't get many of, of course...
B6: UT210E ordered.
Thanks.
Interested in one, thanks.
Ordered. Thanks very much.
Has anyone’s meter been shipped yet?
It is moving out from the warehouse since Monday (GMT+8) but pace is a bit slow though.
Nope, still processing.
Mine too.
My order had been shipped on jan 17. Next day from the purchase.
Same here…
Mine was posted on the 17th but I did order as soon as it became available.
I ordered january 14th. It is still “Ready to Process” and I think it will stay that way until the festivities of the Chinese Newyear are over.
Mine is still processing as well. Ordered on 14th of jan. Expected shipping shows jan. 23rd. Will be a helpful tool!
My first order UT210E shipped, ordered 14th 00:20;
second ordered 14th at 02:20 and expected shipping date 23rd;
just received shipping notice also for the second order
“So the last will be first, and the first will be last.”
I ordered (and paid) on Jan 14, still processing
