That makes complete sense. The voltage across each 7135 is going to change as the battery drains, as long as the Vf of the LED is within 7v of the input voltage all should be fine.
PWM is where I start to get hazy, with the driver still putting out short high current bursts to create a lower RMS power, will the 7135’s act like they’re driving an output with a lower Vf, or will the interaction be just like when PWM = 100%, just pulsed?
If it doesn’t act like just a pulsed version of the full output, that could be why they might die in a setup like we’re talking about.
I don't understand that aspect either. I know that 7135's hate heat and they run cooler as lower PWM's. I guess the breaks between on pulses allows them to cool off some.
I really can't picture 7135's dissipating 7 volts though. Even 1 volt gets them real hot. Proper heat sinking is critical.
My bad. RMM was right. Just now I tried this with 4S behind the zener modded 7135 driver + an XHP-70 and it does not work. I was never able to get more than 600ma from the driver, and the modes would not change.
I also tried this with 4 gen 1 XMLs and the poor mans setup and the result is not much better. I was able to get full power but only for a short time and after a bit I was not able to change modes again.
Neither setup killed the driver, but it did get hot very fast. In the XHP-70 test I even had it pressed into a copper slug similar to a C8 pill. Running it like this for long would have killed it I think.
The 7V limitation really only applies to the Vdd pin since the voltage drop from led- to ground is whatever is left after deducting the led Vf. There isn’t a hard ceiling as far as I could find other than above 700mW heat sinking becomes critical to maintain operation. 700mW translates to a drop of 2V. The other fine print item I’ve mentioned before is noting the benefit of up to 1000^2 mm of trace area for heat sinking each chip. Pretty sure there isn’t that much trace area available unless you mount each one on a 12.6mm board with nothing else but copper on each side(pi x 12.6 x 12.6 x 2 = ~1000). Given adequate heat sinking they can be driven much harder but I don’t believe they can share that sink with another heat source unless it is sized for both.
What eventuated out of this?
An ideal LED for a C8 and single 18650?
Or more a realistic option for a TM16 with quad XHP35?
Perhaps the TM16 is more suited to XHP50-70?
I know of one light which can possibly benefit from this LED. The XHP35 can do some amazing things, just in rather unconventional situations. The hi-CRI at 5000-6000K is one thing that we often never have access to, but I’ve seen another side to this LED which I am quite interested in.
How many lights currently use a boost that we know of out there?
The TR-S700 is one that does use a boost circuit. It has an amazing hotspot for 7-LEDs. It is also beneficial as the cell count, whether using 1, 2, or 3, doesn’t really effect initial output in the S700. It is just about ready all of the time to get up and go.
SC600 Mk III - now available with XHP35 in both cool and neutral tints.
SC600W Mk3
SC63 - available for preorder in both cool and neutral tints. Supposed to ship at the end of the month. SC 63w
If Zebralight can get a sufficient supply of emitters they are also thinking of offering the above lights in 90 CRI XHP35. That would be pretty nice: A tiny SC63-sized light with 1100 lumen output of hi-CRI 5000K light.
The high-CRI Zebralights sound nice, but I worry about whether they’ve finally fixed their tinted lenses and if the emitters still make a Cree rainbow. It could turn out to be a much lower CRI than advertised, depending on details like that.
Now, if they used a dome-less emitter, that would help a lot. And an untinted lens.
Even more amazing is that they accomplished this with a comparatively small boost driver that scales up to 12V or more from a 4.2V cell. I hope they can maintain CC boost regulation down to the claimed 2.7V LVC. Very cool indeed!
You’ll probably have to use 4 18350’s in series to get the voltage to run the emitter. I don’t know of any boost driver to up the voltage of two 26650’s to meet the 12v requirement.
The LD-51 does that trick. Driver for XHP35 LD-51
I’m currently talking with gearbest about that driver.
It’s not a direct replacement, it’s 28mm instead of 20.
Any ideas about modes? How many and what percentage?
