Great review and tests djozz. I was wondering what this “black” Oslon was all about. I’ll be following all your Oslon emitter testing as closely as I can. I have some various oslons on the way from mouser. Fairly random, I’m not too good with spec sheets.
PS. When reflowing the oslons onto an XP-G noctigon, does the emitter snap into place, or do you have to hold it in place with tweezers?
I wonder how hard it would be for us to make a DD that switched positive insteed of negative. Would not only help with this flat emitter, but with all emitters. Would not need to run a negative lead to the driver. Bases reflowed to drivers will provide an excellent low resistance electrical connection.
While I was at mouser, I ordered some single emitter boards foe oslons. They’re aluminum with no DTP. No need to isolate the boards negative thermal path. I’d be interested to know how far we can push one of these emitters without a DTP. At what point would it be a problem?
My guess is that you start noticing a difference above about 1.5A, and up to 3A you are still fine (for this Black Flat led that may be the maximum on a non-DTP board) but with a little less output.
As a fan of HCRI LEDs, I really appreciate these tests!
I would love to hear your thoughts on how these new Oslon 96CRI compare tint wise to the Nichias.
IIRC, in one of your previous tests you mentioned that the Oslons were less rosy than the the Nichia.
The narrow emission angle of these newer Oslons remind me of the older Cree XRE so I’m guessing they will be relatively throwy.
These might work well with some narrow optics for good throw with minimal side spill.
I’m of the opinion that for distance ‘throw’ lighting less side spill is better.
Side spill can cause close up glare which hinders visually what we can make out from the throw beam and whatever it’s lighting up.
Lights with minimal side spill there is less distraction for our eyes and it makes for better focus on what we’re lighting up at distance.
Thanks djozz!
Are you sure the XP-E2 Torch has a higher surface brightness than the best performing XP-G2?
When I saw the graph of the Oslon Black Flat I thought it has to be the new alphadog… Strange that is was clearly outperformed by the XP-G2 S4 in your test.
That three-solder-pad-design without one beeing neutral is somewhat weird. I think they lowered thermal resistance that way…
I have actually not compared surface brightness for the latest bin xp-g2 and 'Torch'. Here we go:
-maximum output XP-G2 S4 2B: 1420lm
-maximum output XP-E2 'Torch': 530lm
-die size XP-G2: 1.48 mmsq.
-die size XP-E2: 1 mmsq
So (for the single two emitters that were tested) the surface brightness of the XP-G2 is actually 1.22 times the surface brightness of the 'Torch', if both are driven at max. In practice on a single li-ion the XP-G2 S4 2B does not get past 4.6A while the Torch can be driven at max, so the fair difference is 1.12 times, still the XP-G2 is brighter.
I did not expect that, thanks chouster for making me calculate that!
The Oslon black never had a electrically neutral thermal pad, this is not a recent change.
Could you post a mouser link to the other two oslons that you plan to test? Just trying to keep up my homework. Someone said you were going to be giving us a test.
The XP-E2 “torch” is still a great choice, especially for smaller single cell lights when heat management and runtime matters.
Yep, just took a look at datasheets of Oslon black versions 1.1 and 1.5. Two cathode pads on both. However they must have had a reason to do it that way…
Are there Oslon Black Flat emitters with larger die surface?
This small is pretty close to good old type of S4 2B…
Probably it would be the same if mcpcb could be hard pressed to thermal paste or soldered directly to pill, but as Djozz described; it has small issue (led-minus is electrically connected to the central thermal pad).
Wouldn’t he like to know as well!
I can tell you that Djozz is a bit frustrated about that but no worries: he has ordered some Oslon black flats for some mods…… :sunglasses: so I’m sure the will do some further testing.
A member of the German forum has modded his Eagletac M25C2 Turbo to over 1Mcd.
Of course the spot is tiny and the modded light uses two cells in series.
Measurements were taken with a calibrated Gossen Lux meter.
I’m planning to modd my Fenix TK61 with this led, and perhaps one of my Thrunite Tn31’s and the Olight M2X UT Javelot.
Focussing will be a bith thought, with a led this small
Ok, well I hope he does a bit more testing to figure out exactly how intense the flat black is, because I would really like to have an alternative to the XP-G2.
This is the graph I’m looking at, and I’m not sure if the S4 2B in this graph was dedomed or not…
If it was not, then the lumens coming from my XP-G2 are probably significantly less than 1400 since dedoming loses some lumens.
Since the flat black doesn’t need to be dedomed, it would still have 800lm/mm^2 which would be a lot more than the 500-600lm/mm^2 of the XP-G2 (because ~1000-1200lm / 1.45^2)
djozz does not measure luminance of LEDs, he measures lumens. Two totally different things. For throw you need to know the luminance [cd/mm^2]. Lumens per square mm of DIE-area should be a good estimate though, but only if the actually value (also the size) measured is actually precise and representative of all the LEDs of this kind. For Osram LEDs this isn’t the case, because you can’t buy the Black Flat 2 in a single BIN. Osram only sells you a range of Bins. In the German TLF forum multiple people have found out that there is a rather large variance between these LEDs. If you want a “good” Black Flat that will actually produce the super high luminance values, you either need to be lucky or buy multiple LEDs and test them individually under the same conditions. Testing means that you test with a lux-meter if it gets brighter until 4A or even 4.5A. If it doesn’t, you got a “dud”.
Here is a thread in the German TLF forum, where somebody tried to precisely measure the luminance of a Black Flat. His LED got brighter until 4.5A where he stopped measuring. He didn’t actually calculate the luminance from his measured values, but sma and I did that for him. His LED managed 250cd/mm^2. That is around 10-25% better compared to any XP-G2 that has ever been measured in this way.
Just like djozz he only tested one sample though…
Even just assuming that the 1420lm is with a dedomed S4 XP G2, the 800lm on 1mm area die should still be better than the 1420lm on 2.1mm area of the XP-G2, right?
EDIT- ok so I read djozz’s post wrong, the one that is NOT higher than the XP-G2 is the XP-E2, the black flat IS higher than the XP-G2
When talking about XP-E2: “(edit:I was wrong here, after a suggestion by chouster, a quick calculation learned that an S4 XP-G2 reaches a higher surface brightness when at max)”
When talking about the flat black: “(edit: also higher than a S4 XP-G2)”
So that clears things up…
Now the question is, can I pay someone to reflow a bunch of flat blacks onto copper stars? plz
