Thanks for the review and discount code. Was waiting to see a review on this light, just ordered it through your link.
Nice review. Almost makes me want to buy a second one, the grey color. Oh, I agree that the tiny button can be hard to locate by touch only (in a dark area), so I rotated the pocket-clip in alignment w/ the button. Problem solved.
what do you think-would be possible to chahnge here the driver by a fet driver? to get a smallll astrolux??
The DQG Tiny 18650 series lights use an integrated board that contains both the driver and the LED. Because there is only one board instead of a separate driver and star, this allows for the shortest possible light.
The downside of this arrangment is swapping in a replacement driver isn’t so easy. A standard FET driver won’t have a place for the LED on it, and there probably isn’t room in the light to add a separate star for the LED and still have room for the optic.
However, it IS possible to mod these lights into small triples. A 20mm Carclo triple-TIR optic is 7mm shorter than the stock single emitter TIR optic that comes with the light. 7mm is sufficient to allow installation of a small copper heatsink, plus triple noctigon. I’ve done this mod twice on DQG Tiny IIIs, and it looks to be even easier with the Tiny IV because far less glue was used to hold the head and body tube together.
If you mod these lights with a FET and triple XPL you have a true pocket rocket. Smallest single 18650 triple TIR light ever… and with an output of over 3000 lumens at turn-on with a fresh IMR cell. Downside, is there is very little room for heatsinking. The outside of the head will get burning hot within seconds unless you add an external heatsink.
hallo.thanks for breathtaking answer…hm…i woudl like to try it:)
is there someone,who can make it and sale? iam not into modding…
I haven’t seen any posts from anyone saying they successfully modded the DQG Tiny 18650 other than myself. The mod had a number of significant challenges involved. Definitely not a beginner level mod.
If you do successfully mod them these make beautiful EDCs though.
Does it always starts on high?
i would like to get one:)))))
Depends on what driver you use.
One of my DQG Tiny III triples has a 3.8 amp (10x7135) 105c driver with DrJones Mokkadrv firmware. A quick press from off starts on high. A long press starts on low.
My other one has a FET driver with Moppydrv firmware. That one will remember the mode it was last turned off in, but also has shortcuts too moonlight (long press) and turbo (double-click).
Sorry, I meant stock 4th version.
From OFF
One short click to LOW
Two Short clicks to MED
Three short clicks to HI
Hold to TURBO
From ON
Hold to Cycle LOW-MED-HI repeat cycle starts in the mode your in
Double click TURBO
From TURBO
One click to last mode
2 clicks to off
Don’t think I forgot anything.
That’s about right.
The hold for turbo from off is a little long. I think you have to hold for 2 seconds. Would have been better if they made it 1 second.
Also there is a turbo timer (I think 1 minute). When the turbo timer times out you end up in whatever your last non-turbo mode was, or in low if you used the shortcut to turbo from off.
This light does not have mode memory.
http://edc-light.com/dqg-18650-click-cree-xml2-smallest-led-flashlight_p0861.html
this one with the grey metal tailcap is the older version?or?
i bought the last version,but the modes type is not good.too confusing…anyway,neutral version i bought is beatiful.now lets change the driver.
That one you linked is the Tiny III. You can tell because it has knurling on the tailcap and a metal switch button.
The latest model, the Tiny IV, has a black rubber switch boot and no knurling on the tailcap.
The Tiny IV is superior due to higher output, internal heatsinking, a better UI (it has a shortcut to turbo from off), is less likely to accidentally turn on in the pocket, and is easier to mod.
helou.i want to change the driver in this flashlite.which could be good?thanks.i want maximum,maybe turbo timer.something,like our fet.but this is side switch…
See my previous post.
The light uses a single board that contains both the driver and the LED. There is no separate star. Merely changing the driver isn’t an option since typical replacement drivers do not have the LED on them and there isn’t room to mount a star in front of the driver and still have room for the optic.
However, it is possible to convert this light to a triple. The shorter optic on a triple frees up enough space to mount a platform for the triple star ahead of the driver.
oh…lost this infos….oh no…thats bad for me…tripple is too hard to do.i wanted only new driver…so,thats the end of the moding…bleeeeeeeeeeeee:)))
my 4th tiny
did you open it???
