I haven’t seen any posts from anyone saying they successfully modded the DQG Tiny 18650 other than myself. The mod had a number of significant challenges involved. Definitely not a beginner level mod.
If you do successfully mod them these make beautiful EDCs though.
One of my DQG Tiny III triples has a 3.8 amp (10x7135) 105c driver with DrJones Mokkadrv firmware. A quick press from off starts on high. A long press starts on low.
My other one has a FET driver with Moppydrv firmware. That one will remember the mode it was last turned off in, but also has shortcuts too moonlight (long press) and turbo (double-click).
The hold for turbo from off is a little long. I think you have to hold for 2 seconds. Would have been better if they made it 1 second.
Also there is a turbo timer (I think 1 minute). When the turbo timer times out you end up in whatever your last non-turbo mode was, or in low if you used the shortcut to turbo from off.
this one with the grey metal tailcap is the older version?or?
i bought the last version,but the modes type is not good.too confusing…anyway,neutral version i bought is beatiful.now lets change the driver.
That one you linked is the Tiny III. You can tell because it has knurling on the tailcap and a metal switch button.
The latest model, the Tiny IV, has a black rubber switch boot and no knurling on the tailcap.
The Tiny IV is superior due to higher output, internal heatsinking, a better UI (it has a shortcut to turbo from off), is less likely to accidentally turn on in the pocket, and is easier to mod.
helou.i want to change the driver in this flashlite.which could be good?thanks.i want maximum,maybe turbo timer.something,like our fet.but this is side switch…
The light uses a single board that contains both the driver and the LED. There is no separate star. Merely changing the driver isn’t an option since typical replacement drivers do not have the LED on them and there isn’t room to mount a star in front of the driver and still have room for the optic.
However, it is possible to convert this light to a triple. The shorter optic on a triple frees up enough space to mount a platform for the triple star ahead of the driver.
