Same problem here, they really took “The Slow Boat to China route” ordered on 12/20/15, shipped on 1/1/16 and the tracking doesn’t update
I want to know if the Manker T01 reflector is compatible with this light, I would like to change the Led for a XP-L Hi and smooth reflector if possible
If you take it apart, can you measure the dimensions of the reflector?
RemanG you’re not helping at all with my attemps to save some cash with all these reviews you’re doing!!! First the A01, then fenix E15 and now you’re telling us the U11 is mod-friendly… slow it down man
Nice review, thanks! can you take tail amp readings? I also read it has constant current output and doesn’t have turbo timer drop, would be nice to see if it’s true.
Will do today! I hadn’t thought to time for a turbo timer, but I did run it on the simple UI turbo for at least five minutes. It did get warm, and I do not recall a step down.
With a clamp on ammeter, 3.7A (3.68 actually after 30 seconds with a Samsung –20R)
Can someone measure the exact dimensions of the reflector Diameter, height, hole diameter of the U11? I am planning on putting a XP-L HI and a smooth reflector when I get it.
Is the Manker T01 reflector a direct fit for the U11? I also have a T01 on order and might swap reflectors/leds if they are fully compatible.
Nuts, Hang on, I will pop it back out. The Reflector is narrow at the bottom and there is no stock centering insulating ring. The Regular XPL centers itself with its corners.
Give me a bit…
About 27mm wide, 20mm deep and the back hole is 5mm with a 1mm shelf around it that sits on the board.
I got the U11 in the mail today, I like it! The USB charges the battery to 4.18v checked with 2 different batteries the beam pattern and size is almost identical as the Zebralight SC600. the U11 hotspot is just a very tiny bit smaller, when comparing the 2 lights in their brightest setting the U11 is brighter.
Fit and finish is superb! I might swap the Led for a XP-L HI whenever I have time. But so far I think Manker has a winner with this light. Good Job Manker!
Not having a ZL to compare to, this is great to hear… What tint XPL-HI are you thinking of replacing the stock emitter? I have been very happy with the warm white I put in…
2B is my favorite cool white… I just used the stock board and reflowed the new one on it. You may have to thin a noctigon down as the stock board is thinner than a noctigon. A 20mm Noctigon will need some filing on the edges, but a 16mm should fit the screw holes already there. Easiest way is to just use the stock board….
Manker U11 standby current (parasitic drain): measured 0,2µA! This is practically zero. It will drain an 18650 in 2000 years, theoretically. Even better than Zebralight (4µA).
