Does it always starts on high?
i would like to get one:)))))
Depends on what driver you use.
One of my DQG Tiny III triples has a 3.8 amp (10x7135) 105c driver with DrJones Mokkadrv firmware. A quick press from off starts on high. A long press starts on low.
My other one has a FET driver with Moppydrv firmware. That one will remember the mode it was last turned off in, but also has shortcuts too moonlight (long press) and turbo (double-click).
Sorry, I meant stock 4th version.
From OFF
One short click to LOW
Two Short clicks to MED
Three short clicks to HI
Hold to TURBO
From ON
Hold to Cycle LOW-MED-HI repeat cycle starts in the mode your in
Double click TURBO
From TURBO
One click to last mode
2 clicks to off
Don’t think I forgot anything.
That’s about right.
The hold for turbo from off is a little long. I think you have to hold for 2 seconds. Would have been better if they made it 1 second.
Also there is a turbo timer (I think 1 minute). When the turbo timer times out you end up in whatever your last non-turbo mode was, or in low if you used the shortcut to turbo from off.
This light does not have mode memory.
http://edc-light.com/dqg-18650-click-cree-xml2-smallest-led-flashlight_p0861.html
this one with the grey metal tailcap is the older version?or?
i bought the last version,but the modes type is not good.too confusing…anyway,neutral version i bought is beatiful.now lets change the driver.
That one you linked is the Tiny III. You can tell because it has knurling on the tailcap and a metal switch button.
The latest model, the Tiny IV, has a black rubber switch boot and no knurling on the tailcap.
The Tiny IV is superior due to higher output, internal heatsinking, a better UI (it has a shortcut to turbo from off), is less likely to accidentally turn on in the pocket, and is easier to mod.
helou.i want to change the driver in this flashlite.which could be good?thanks.i want maximum,maybe turbo timer.something,like our fet.but this is side switch…
See my previous post.
The light uses a single board that contains both the driver and the LED. There is no separate star. Merely changing the driver isn’t an option since typical replacement drivers do not have the LED on them and there isn’t room to mount a star in front of the driver and still have room for the optic.
However, it is possible to convert this light to a triple. The shorter optic on a triple frees up enough space to mount a platform for the triple star ahead of the driver.
oh…lost this infos….oh no…thats bad for me…tripple is too hard to do.i wanted only new driver…so,thats the end of the moding…bleeeeeeeeeeeee:)))
my 4th tiny
did you open it???
Yep
http://forum.fonarevka.ru/showthread.php?t=31935
more photo
http://forum.fonarevka.ru/album.php?albumid=1062
so driver change is possible… or make a triple:)
make a triple will be not so easy.
It is necessary to make a new bezel. The diameter of the old 20,2mm. Optics will fall out from it.
It is a 22mm optic in stock form. Does anyone know where to get extras or floodier optics for this light?
https://www.fasttech.com/products/1607/10001027/4380501
https://www.fasttech.com/products/1606/10007055/1574902-21-2-12-6mm-pmma-optical-lens-for-cree-xm-l-t5-t6
http://www.aliexpress.com/item/New-flat-glass-watch-crystal-diameter-21-5mm-Thick-1mm/1097050471.html?spm=2114.30010308.3.1.I4YGUo&ws_ab_test=searchweb201556_0,searchweb201602_4_10017_10005_10006_10034_10021_507_10022_10009_10020_10008_10018_10019,searchweb201603_9&btsid=49ff1652-3c04-46b5-a3b5-ea2fe93d133e
Serp, thanks! I did not see those when I was on FT….
I’ve converted a couple DQG Tiny IIIs into triples. Both of them also had the 20mm bezel, just like the Tiny IV.
Fortunately, it is not necessary to make a new bezel. Both of these solutions work:
- Place a fat o-ring on top of the bezel. Just thick enough to project over the edge of the bezel onto the optic; or
- Buy a 22mm AR coated plastic lens from flashlightlens.com. Then file part of the edge of the lens so just the edge is much flatter and fits under the bezel (this is the option I preferred for my lights). The lens sits on top of the optic and holds it all together.
