For sale: High efficiency 365nm 3535 UV LED,ZWB2 20x1.5mm filters
Update 15.12.2015.
Shipping price is now separated,no minimum orders for EU,25$ minimum for rest of the World(excluding shipping).
Specifications
Led type: SMD 3535
Led color : Ultraviolet
Chip(die): Semileds
Package size: 3.5×3.5×2.0 mm(XP footprint compatible)
Dominant wavelength: 365-370nm
LED Power rating: 1W
Forward current: 350mA
Peak pulsed current: 700mA
Typ. forward voltage: 3.5V
Typ. radiometric output: 410mW(+-7%)
(If=350mA,Tj=25C)
Viewing angle: 120deg
Operating temp. range: -20~+80C
Already tested by djozzTM here : https://budgetlightforum.com/t/-/36025
Great review as usual,so I want to thank djozz once again,and I will copy/paste just his conclusion about this LED here:
"Conclusion: I think this led is a great one, the UV-output is at least close to 365nm and the amount is impressive, more than the Nichia NCSU276A U365, and it comes from a small XP-E size die, so it can throw as well if you like that. The only drawback is the large amount of visible light it puts out as well, like most 365nm leds btw. I solved that by using a UV-pass filter, but these filters cost some money, between 10 and 20 dollars.
Thanks for reading!"
So this LED has efficiency similar to high-end UV leds like nichia 276A,or about 3 times more than decent lower cost LEDs like mentioned RY3535UV,or 10-15 times more than cheap ebay UV leds!
Notes:
*Power rating of this LED is 1W (350mA),so overdriving affects led characteristics like lifetime and wavelength,just like in case of white leds.According to djozz's tests,it seems that max./optimal driving current for this LED on Noctigon should be around 700mA.
*This is budget/low cost LED,so there may be tiny imperfections like little off-centered die and dust on lens that doesn't affect output of this LED.
Price:
5.9$/piece
_______________________________________________________________________________________________
ZWB2 20x1.5mm filter lens
Price:
1.9$/piece
Shipping: Priority airmail shipping(pretty fast): +2$
Tracking number option: +5$
Estimated shipping times:
EU 3-5 days
World 5-20 days
Paypal fees-included
Paypal and contact/info: led4power@hotmail(dot)com (replace (dot) with .)
Note:for Italy only tracked shipping is available
Thanks
Why don’t you post the datasheet for this LED?
Upper mentioned specifications is only what I got,but that’s why I sent few LEDs to djozz,his tests show much more than any datasheet could do :wink:
Payment sent for 2 of these bad boys.
Thanks,
ZWB2 20x1.5mm filter lens added.
My question is, Would one use both the UV LED AND the Filters?
Or does the LED emit enough light?
I really don’t want to sound repetitive in my questions…but I am trying to garner enough information to justify to my company to invest in me purchasing medium sized quantities of parts to create inspection lights.
I “purchased” one UV light already, but it emits to little UV be used in our inspection. The requirements for Black Light inspection is 1000 u/cm² at the work surface (about 15 inches). The one I have is about 200 u/cm²…
I have located this LED, already on a board…
LED Engin LZ1-10UV00-0000 - Single Color Ultraviolet 365nm Emitter w/starboard
http://www.mouser.com/Search/Refine.aspx?Keyword=897-LZ110UV000000
1: $35.48
10: $31.35
25: $28.14
100: $23.93
I do not know if this is a decent price per 25.
Yes, you would use the UV filter with the UV LED to filter out the excess visible light that is emitted along with the UV. I installed one on my 365nm UV light and it really makes fluorescence punch. Enjoy a nice walk through your bathroom for a fun time… Even walking through the house… Every particle of dust glows.
hah…I would rather not…I am not OCD and would prefer not to become one!
Got my UV LEDs, very fast shipping. Great LEDs!
I fascinated by the amount of UV light/fluorescence it creates. My kitchen and bathroom look absolutely hideous.
PM sent.
Working with these tiny objects for me is like trying to push a camel through the eye of a needle.
Is it possible for you to send me a led on a (16mm) Noctigon? And if possible, what would be the price for a led+board?
It is easiest if led4power does this for you, but if not, I can reflow the led for you also.
If you asked me,yes just tell me which noctigon,16mm or 20mm(+2:money_mouth_face:.
PM and PP sent.
Best regards,
Wim
Earlier this afternoon the mail(wo)man delivered:
- a tiny UV-led, spotless flowed onto a 16mm Noctigon
- covered with a minuscule “jock-strap” to prevent it from damage
- packed in a small anti-static bag, sealed,
- packed in a small bubble bag, sealed,
  • packed in a bubble-lined envelope.
A quick test with my DMM led to the conclusion that everything was OK.
So if this build leads to something less than expected, I only can blame it on myself :wink:
Thank you.
Sooo I bought one of this emitter, along with a ZWB2 glass and put it together in an S2 with a 2*7135 Nanjg driver.
Here are some crappy pics of it :
Random emitters :
Glow paint :
Plastic tool handle (sorry…) :
Tail light of my bike :
Garage sink (ugh) :
Highlighter ;
Snowboard :
Phosphor is reallty glowing with that UV :
Thank you led4power !
If you could source some 10mm ZWB2 glass I would make a nice pocket 348 with this LED !
So… Gearbest seems to be worse than I imagined, they used one of my pics above to make a false review of the ZWB2 lens they sell :
Paypal sent for 4 leds and two lenses
THANK YOU
Paypal sent for one led and one lens.
Thank you :slight_smile:
I already got it :+1:
The dot on the top side is which polarity?
