My First Real Mods/Builds
30 posts / 0 new
robo819
robo819's picture
Last seen: 21 hours 45 min ago
I finally got the nerve to try doing something more than a simple spring bypass.
The 2 lights I decided I would either sacrifice, or make better, were the Thorfire C8 and a Small Sun ZY-T16 to try my first real Mods or Builds on.
Both Lights DO have spring bypasses at both ends on these. The ThorfireC8 was a fairly simple removal and swap of driver and MCPCB and replacing both. I used a17mm FET+1 six mode driver (moon – turbo) with 120 second turbo timer and a 20mm Noctigon MCPCB with dedomed XM-L2 U3 1A emitter. A little bit of sanding on the insulator gasket (centering ring) and focus was just right. Getting 4.57 amps at tailcap with 18650 LG HE4’s. I don’t have a lux meter or any way of testing lumen output (just yet).
I added the 175yd shot BEFORE the build (on the C8) for comparison in the beamshots below.
Beam Profile / Light 3ft from Light Gray wall
Gate 100 yards (Turbo)
Before The Build at 175 yards
After build 175 Yards (turbo)
The far WHITE marker is at 400 yards
400 yards (turbo)
400yards ENLARGED
The Small Sun ZY-T16 I used a 20mm FET “guppydrv” for the driver (lots and lots of settings) and a 20mm Noctigon MCPCB with a dedomed XM-L2 U4 1C emitter.
Driver here (scroll down to Universal guppydrv Rev 1),,,,,,, http://www.mtnelectronics.com/index.php?route=product/product&path=67_11...
After installing everything the heat dissipation and the focus were both pretty bad on this one, so I had to make a copper disk (started out with a piece of copper tubing) to go under the MCPCB to get that fixed and moving some heat. I had to mess with the focus ALOT. I got the heat management doing great and the focus is good now, other than close up when wall hunting it has some slight rings. (these are not noticeable in normal use a little further out)
Made the copper disk from this,
Finished the disk and put it in the pill with thermal paste under it,
Then used thermal paste under the MCPCB and got everything put back together.
The end result with this Small Sun I am really pleased with, as the tint and the output are a lot better than I had expected out of it, and it was being such a pain in he rear to get everything just right. Getting 4.19 amps at tailcap with 4000 mAh 26650 King Kong (black) unprotected button tops.
Beam profile / Light 6ft from Light Gray wall
Gate 100 yards (high)
175 yards
400 yards
400 yards ENLARGED
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 01/22/2016 - 08:57
chuckhov
Last seen: 1 year 4 months ago
Nice Job, Rob!
Thanks for showing!
-Chuck
will34
will34's picture
Last seen: 1 day 19 hours ago
Nice mods! Great tint on that C8, looks CW and not greenish at all.
saypat
saypat's picture
Last seen: 39 min 45 sec ago
I’d say that was quite a bit more then a spring bypass Shocked Looks like you’re a natural modder. My modding experience was removing a reflector from a light once.
thanks for sharing, it encourages the faint at heart.
robo819
robo819's picture
Thanks guys,
Yes the tint is a cool white on the C8 but not quiet as cool or bluish as the photos show. I didn’t adjust anything on the pictures from the beamshots, so they are as the camera captured them, and not exactly as my eye sees them (although fairly close), the Small Sun is a very good neutral white.
chadvone
chadvone's picture
Last seen: 22 hours 2 min ago
Thanks for posting. I plan on attempting a C8 build in the future. Do you remember you camera settings ?
robo819
robo819's picture
It is a point and shoot camera (Fuji 14mp), I just set it for night time shots and use tripods.
I don’t have a clue what the setting would be.
chadvone
chadvone's picture
Well you did a good job on the photographs. If you check the properties of the photo it should tell you camera settings.
I would like to see the settings for the pics with the gates.
DBSAR
DBSAR's picture
Last seen: 12 min 15 sec ago
Nice job on these mods Smile i have the same Thorfire C8, but have not modded it yet.
robo819
robo819's picture
Doh I knew that brain dead ATM I guess………
here ya go….
4608×3440
600 dpi
Bit depth 24
ISO-200
focal length 6mm
Max apeture 3.44
Brightness -4.67
Landscape Mode
robo819
robo819's picture
It is a good one to mod, the one I have came with the solid screw out pill in it, I have heard they were putting a pill with a hole in the middle of it for awhile.
chadvone
chadvone's picture
Got you PM. I m very impressed what these C8’s will do. I am working on a shopping list right now.
Did you dedome the LED yourself ? Thinking I might just get a HI version.
robo819
robo819's picture
I have dedomed a few LED’s, but I got these from Richard at Mtnelectronics already dedomed on the boards.
Be sure if you do order from him you check the box for it to be dedomed at the bottom of the image if you are in fact wanting a dedomed emitter.
http://www.mtnelectronics.com/index.php?route=product/product&path=60_61...
Ouchyfoot
Ouchyfoot's picture
Last seen: 4 months 43 min ago
Great mods. The small sun is one of those lights that has all kinds of possibilities.
The Miller
The Miller's picture
nice mods, looks great!
Aspire7
Aspire7's picture
Last seen: 2 years 1 week ago
Sweetness!!! Can definitely see the difference. The beamshot at 175yrds looks a bit like daylight. Sure you didn’t call on the sun gods to help you in that shot?!??
pilotdog68
pilotdog68's picture
Last seen: 2 months 2 days ago
Nice work. Fun, isn’t it?
robo819
robo819's picture
It is satisfying to see the results in the end for sure pilot.
Getting there can be a hair pulling experience at times though when you just kind of winging it…..lol
mattlward
mattlward's picture
Last seen: 16 hours 19 min ago
The attention to detail shows in the beam shots.  I have found that I really like working with the KD C8.  If you are looking for a host, they have a complete light for 10 bux with brass pill.  They have a good selection of reflectors for XM and XP emitters in smooth and LOP.  I actually like to run a de-domed XP-G2 with a LOP reflector so that there is some usable light outside of the pencil beam.
Good focus and good work in general, keep up the good work.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
robo819
robo819's picture
Thanks for the info matt, have plenty of C8’s ATM but I will keep those in mind. Right now I have plans to put a dedomed XP-G2 S2 2B in my XinTD V5 C8 with FET and guppydrv , already got the spring bypass done on the tail end and waiting on parts. I think it will give me a heck of a throw, although I don’t know what kind of spill I will get with it.
mattlward
mattlward's picture
A de-domed XP-G2 4C, yes I said 4C.  I like warm light, I maybe should have used a 3C since it is a bit yellow.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
robo819
robo819's picture
Warm is ok with some of my lights but in a thrower I prefer to have a neutral if I can end up with that, just my personal preference.
Tom E
Tom E's picture
Last seen: 19 hours 17 min ago
Excellent work on these mods! Small Sun's can be a challenge - the quality and consistency is somewhat lacking, but it's all work-able. I bought a T43 for modding, but ended up a total disaster - not simple modding at all - stripped out the threading, etc.
I use purchased copper discs in various thickness's so try to work out the vertical spacing in advance but it's not always easy. Generally on the bigger lights that use 25 mm stock MCPCB's you are replacing 2.0 mm MCPCB's with 1.6 mm copper MCPCB's so you start out going in the wrong direction from where you want to be. I really like the 26 mm Maxtoch MCPCB's but they are costly, and still too thin.
I'll reflow the copper spacer to the MCPCB so it's one solid chunk of heat sink, which helps.
robo819
robo819's picture
Thanks Tom. I have a Zy-T43 in there with stripped threads too, hahaha…..the threads came out with the head when trying to take it apart so there it sits.
Thanks for the rest of the info also, I will be putting this in my knowledge bank for future reference.
You will have to let me know where to get those copper disk though , that would save about and hour of time trying to make one as I did.
Itinifni
Itinifni's picture
Last seen: 4 days 6 hours ago
Great work, a couple of nice lights you have there.
I wish I had more open space nearby to let my throwers stretch their legs, all woods and hills around here.
I remember a time, when I searched for lights to fit my needs. Now I search for needs to fit my lights.
robo819
robo819's picture
Thanks, we have a lot of woods around but also a lot of cattle/ranches also , so we have a good mix of both open and wooded.
MRsDNF
MRsDNF's picture
Last seen: 22 hours 15 min ago
Very nice mods and thanks for showing us.
robo819
robo819's picture
Thanks MRsDNF and YW
Lotus_Darkrose
Last seen: 1 day 11 hours ago
Nice work. Simple, yet effective is my style Smile
robo819
robo819's picture
Thanks Lotus_Darkrose yes simple is definitely the eaisiest way to do things usually and my preferred method also.
