On mine the centering ring is circular. There should be an o-ring between the lens and bezel and a larger one between the bezel and flashlight head. If one of these is missing it could therefore be loose. It may also be worth checking that the pill is actually threaded in all the way. Here is a pic from battery side;
Hope that helps although this is kind of poor and I hope you will mention it in your review.
mine has centering ring too, but after screwing down the pill there is now a gap, just like my c12, no-one else had flickering led due to a loose pill, or am i just the unlucky one
Mine turned up and I’m quite impressed. The machining is good, the reflector perfect and the finish is flawless. The switch is quite recessed maybe excessively so, but it will stand on the tail end. I like the way that the modes are organised, you simply cycle through the different levels and there is no SOS mode. There is a strobe mode which isn’t in the normal sequence but you can get to it from any of the modes (once you’ve read the manual)!
The only thing I can critique (so far) is over zealous lubrication of the threads meant some grease escaped and got onto the anodizing and I had to wipe it off!
In the daylight it looks bright but I need some darkness so I can test it more thoroughly
[Edit]
I’ve tried it in the dark and it is bright, brighter in fact than my BLF D80 (my BLF D80 was running on a unprotected LiFePO4 cell and 3.0V isn’t enough volts, it’ll be brighter when the unprotected cells I have on order turn up). The beam is as you’d expect, hotspot and flood with no nasty rings.
I think it is the same. The round plastic part that is normally on the board has come away, and is attached to the reflector instead. I think in your case it is attached to the board, but is the same as mine.
I see you removed the pictures from Amazon. Probably a good thing considering it said not yet available.
Can you explain a little about the changes inside. I think you have a winner with the new tailcap.
I absolutely adore this flashlight. I ended up doing quite a lengthy written review on Amazon UK. I plan on doing a video review when I receive my new laptop in a couple weeks.
So I replied saying I’d be happy to write a review if they sent a sample code, but it’d have pictures not video. They then sent this:
“Could you plz make a pictures review with 5stars?”
“Can you send me your review link of VG15 afer you finish it?”
I replied saying I’d do an honest review if they sent a code. I have not received a code. It sounds like they wanted me to first agree to writing a 5star review. I can’t see how this is a language issue.
My message to them is that they should not do this. I wrote a C8s review and gave it 5 stars because it deserved 5 stars, it was an honest review, and I’d have given it 1 star if I thought it deserved 1 star. Has anyone else had this experience? It does damage confidence in other reviews, sadly.
