ThorFire C8s UK need review! 20 people needed![UK Only]
I think Thorfire/Doeracil are being naughty. I received this email from Doeracil:
“VG15 Waterproof Flashlight Free sample link here:”
http://www.amazon.co.uk/dp/B013DZTG4E”
“Could you plz make a nice review with video?”
So I replied saying I’d be happy to write a review if they sent a sample code, but it’d have pictures not video. They then sent this:
“Could you plz make a pictures review with 5stars?”
“Can you send me your review link of VG15 afer you finish it?”
I replied saying I’d do an honest review if they sent a code. I have not received a code. It sounds like they wanted me to first agree to writing a 5star review. I can’t see how this is a language issue.
My message to them is that they should not do this. I wrote a C8s review and gave it 5 stars because it deserved 5 stars, it was an honest review, and I’d have given it 1 star if I thought it deserved 1 star. :slight_smile: Has anyone else had this experience? It does damage confidence in other reviews, sadly.
I received the same email about the VG15. I do not have the time to do a video review so I declined.
That is naughty if they are expecting 5 star reviews as a matter of course.
Edit: I didn’t notice my C8 is a different model then is being offered as was pointed out to me, my apologies, carry on.
I have got one of the previous models of the Thorfire C8 and I see all of the tailcap readings you guys are getting with this new version seems to be a little on the low side?
Are most of you or all of you using the stock leads on your multimeters? Do any of you have heavier gauge (12awg or even 10awg a maximum of 12 inches long)?
I think you should be getting a minimum of 2.5 at the tail, (provided they haven’t changed something on the driver), this is just my opinion though. I got 2.78 with a protected Panasonic 2900mAh and would be even higher with a unprotected or high drain battery. I have modded mine now so any readings now would not reflect the stock driver.
Link to my video review if any of you are interested……….
Teardown starts at 4:11 Beamshots at 5:54 and shining around outside starts at 6:48
Your review is of the “C8” 3/5 mode. The “C8s” 4 mode model has a completely different driver. Nice review btw.
Ah ok I didn’t notice it was s different model , my bad.
And thanks for the complement on review.
This model seems to have a different driver, the modes are different and it has a hidden strobe, plus the reflector is aluminium now.
Ok, I just got back home yesterday and picked up the C8s and the bike light from the post office, so this is a quick first look.
First impression: Very nice quality. Great fit. The matte anodising looks a little dry and easy to scuff, but this is deceptive. With a little handling it smooths and becomes a very nice finish. I suppose if you like things shinier you could use e.g. a hard car wax on it. It passes my “scratch” test, it is definitely hard.
After successfully checking it out with a battery for a few minutes, I had to take it apart.
Which was very easy, nothing over tightened, no thread lock used.
The business end:
Faultless. Perfectly clean. Perfect reflector surface. Perfect LED centering ring (white) which sits flush with the LED die, no masking. Big hole should accommodate almost any size LED.
The bezel:
O-ring to seal against glass, and another one for the thread. Scalloped for safety, not an “attack” bezel, no worries about e.g. airport security. Now if it was made of stainless steel for durability, it would be perfect, but not so “stealth”.
The glass:
Plain (no AR), ground edge, no chips, 2mm thick. Optically clear, no visible tint (e.g. greenness).
The LED assembly:
Looks like an aluminium star, secured with screws, Can’t quite see the thermal paste, but I’m sure it is under there. Not familiar enough with DTP construction to guess whether this is or not. 20mm diameter, but room for something bigger. Pill is a separate piece inserted in the head. Looks like it could unscrew backwards, but I bottled out after firm hand pressure didn’t shift it. I’ll try again once I’ve made a tool to engage the screw holes. It may however be pressed in. Neat soldering.
The reflector:
Flawless. No hint of waviness to the surface. Big hole to accommodate larger LEDs.
The driver:
Securing ring unscrewed easily, standard thread. 17mm diameter. Beefy inductor. Plenty of room inside the cavity. Neat soldering, good shiny appearance, clean, gold plated. Concerned about proximity of red LED wire to edge, potential for short. Spring has three turns of 0.6mm wire. Lightly attracts a magnet, definitely not steel (good). Same spring used at tail.
The tube:
Beautiful square threads, lightly greased. Anodised at tail for lockout and durability. OAL 70.6 mm ID 19.1mm. Battery fit: well the tube is 70.6mm long, but the springs bind up slightly before then. The longest I have tried is 69.3 mm long, and it fitted just fine. Well fitting O rings, two spares also provided.
The tailcap:
Lovely internal thread, anodised. Locks out. Just enough tolerance to avoid jamming if some grit etc. gets in. Tube contacts tailcap metal, securing ring not touched. Securing ring has left hand thread (good) and was firmly but not over tightened. Switch PCB nicely done, plenty of vias to transfer current. Decent soldering. Un-named switch, nice lead design allowing heat sink clamp to avoid damage when de/re soldering. Big rubber boot with moulded pip to reinforce switch area. 16.5 mm dia. Aluminium washer to ensure solid clamping to avoid leaks. Looks like a good candidate for illumination. Excellent tactile feel. I like the shrouded design, I’ve had trouble with e.g. my BLF A6 going on in my pocket.
The lanyard is a bit rubbish. This is the one thing I would like to see improved. And a belt pouch would be nice.
Now to performance:
First impressions very very good. Excellent cool white tint. My BLF D80SE is in bits at the moment, so I can’t do a direct comparison. But I suspect it will look even more like the dog’s breakfast that it turned out to be,
No visible PWM, and I have tried hard to see any. Nor does my camera see any. Nor does the T-coil on my hearing aids pick up any EMI.
Nicely spaced modes, and lowest is very usable. Not “moonlight”, its similar to the second level of the BLF A6SE. Mode memory works well, time constant is about five seconds. I’ll put it in the freezer later to see how stable this is. Mode changes have a slight but noticeable delay.
Quick and dirty tailcap measurement (standard DMM leads, 18AWG, 2m total length)
Efest purple 2500 mAh 35A
lowest 9.4 mA
low 84.5 mA
medium 660 mA
high 2.50 Amps.
So far so good.
BUT this light is specced to run from 2xCR123 i.e. 6 volts.
So being adventurous I tried it with 2x18350, which fit nicely. And nothing has blown up (yet).
Sibeile 18350 700mAh 10A.
lowest 15.6 mA
low 145 mA
medium 650 mA
high 1.27 Amps.
Now consider that these currents are at double the voltage, you can see that all the lower modes are much brighter, but full power is almost unchanged. Which I find interesting.
Summary: this is a really good torch, at a great price (remember we have 20% VAT here), Fulfilled by Amazon , with all the confidence that inspires. Perfect for modding, especially if I can figure out how the pill is fitted. It will be getting five stars when I pen my review.
Thank you Mandy, and Doeracil.
Update:
Low voltage protection warning kicked in at 3.35 V when the torch started blinking. But you can then re-cycle back to turbo (or any of the other modes) and run the battery down to 3.24 V before it starts blinking again. And you can eke it out for a while longer by using lower power modes to reduce battery droop. Nicely done.
Better leads on the cheap multimeter. 20cm total of fat loudspeaker cable, chunky gold plated banana plugs. 2.66A with 42 mV drop across the multimeter i.e. the multimeter shunt resistance is 16 milliohms. This is probably as good as it gets.
Run on turbo, fresh cell, tailstanding, maximum temperature at the finned part of the body stabilised at 25C over ambient. IR thermometer. This is a very cool running torch.
Update2:
The mode memory is interesting. If you enter the (hidden) strobe, with a double-tap, it remembers it. Turn it off, then on again, straight into strobe. Then the next tap jumps you back to the last remembered standard setting. Which could have been e.g. lowest, or turbo, or whatever. How cool is that ?
Update 3:
Curiosity got the better of me. Just a little more force, with long nose pliers against the screws, and the pill unscrewed easily out of the front.
Its very nice, a lot of thermal contact with the head due to the long length of deeply square cut threads.
If spare pills become available (preferably copper :stuck_out_tongue: ) I can see this being THE modder’s C8.
Rather than post my own pics, I refer you to the thread by Flashlion at Thorfire C8s Review(one of the HQ C8 lights)900Lm Max output + New pictures of the pill(Removable), whose pictures are far better than mine :bigsmile:
Yeah the new u shaped tail cap looks good
Perhaps you got an older version ?
On mine the pill is immovable and fitted from behind, so the shelf will always be correctly aligned inside the head.
If you had the old standard C8 pill design, screwing in from the front, then tightening it up could have loosened the reflector fit. If so, you could shim it out. On mine, everything is snug. Not possible to assemble it incorrectly.
If you look at this review, Thorfire C8s review and teardown dated Wed, 07/15/2015 it is a completely different torch to mine.
Almost everything has changed. The reflector (his has two distinct grooves machined into it), the pill (completely different, and the thermal compound shows that it was not exactly flat, nor conducting the heat properly), the head is redesigned for the new rear-fitting pill, the driver PCB is quite different, the driver mode order (it now ramps up, not down), the springs, the tail switch PCB, the switch itself and the spacer for the tailcap rubber. Even the weight (mine is 151 grams).
Every difference from mine suggests attention to detail, and continuous improvement.
That’s why I am so keen to see the next version. I wonder what they could have further improved ?
Update: I was wrong about the pill, it does unscrew out of the front. I’ve updated my original post.
I wrapped some copper wire strands under the pill to shim it out now all fine, then i did a quick youtube review
Sealey Multimeter industry approved, can’t see the point of changing them just the same as most supplied in the uk
suitable for 240v 13 amp
Make your own pretty easily for ~$6. I can't recall a single DMM that had adequate stock leads for tailcap. It causes quite a bit of anger in group buy threads when people measure 2 amps with their super certified legit $200 DMM and stock leads. :P
Hi
Thanks for looking at my review, what leads would be better for testing on this eBay page
http://www.ebay.co.uk/sch/i.html?\_sop=1&\_from=R40&\_sacat=0&\_nkw=multimeter%20test%20leads&rt=nc&LH_PrefLoc=1&\_trksid=p2045573.m1684
None of ’em!
Most of those listings won’t tell you what the cross sectional area of the cable is in the leads because they don’t contain much, the ones that do specify it just aren’t thick enough. I’ve had some pretty poor DMM leads, one set I had to keep stripping and re-soldering the ends back on because the fine thread of copper kept snapping.
To give you an idea of the thickness of the wires being suggested here, 13 amp mains cable might be 1.5mm2, 12 AWG which was mentioned earlier as a minimum is 3.3mm2, i.e. twice as much copper as mains flex.
I’ve received my torch - it pushed me into buying the half-decent charger that I should have bought months ago, plus a pair of Panasonic 18650’s.
All told, what a great little torch!!
I’ve put my review on Amazon and I’ve also bought another Thorfire Torch albeit from Amazon.com at a cracking price.
Thanks for this giveaway - very happy to rate the torch at five stars.
SP
Update:
I have more than one multi-meter, so out of interest I measured the voltage drop across one meter whilst measuring tail end current using another meter. One meter gets set to measure current whilst the other measures voltage, the two connect up in parallel, probe to probe. I lose about half a volt when using either meter.
I’ve used one to measure the resistance of the other, one meter has a resistance of around 0.6 ohms while another one has a resistance closer to 0.2 ohms. What is surprising is how close the two of them are in terms of voltage drop given how different the resistances are.
Your problem is that by measuring “probe to probe” you are actually measuring the voltage drop across your test leads, as well as the meter.
Thus proving how cr@p your leads are. And I reckon one of your two sets is more cr@p than the other. Whereas the meters themselves are probably a small fraction of the overall drop. Swap the leads around and see.
Trying to measure the resistance of one meter with the other is futile. First of all you are probably doing it through the dodgy leads, which will dominate, secondly the actual resistance will likely be a few tens of milliohms, which your meter cannot resolve, even to one count.
You are probably just measuring the resistance of your leads.
Your meter may be a basic one with a minimum scale of 200 ohms. And a resolution of 2000 counts (i.e. 0.1 ohms). A better one might have 22,000 counts (4 digits). Even so, wrong tool for the job.
Half a volt loss is massive. Its like using a battery at 3.7 volts instead of fully charged at 4.2 volts.
To measure the actual resistance of the meter measuring the current, you need to measure the voltage across it at the meter terminals.
Difficult with shrouded leads, but if you can trap a strand of fine wire into the plugs you can monitor it there.
Of course with my plugs it is easy to connect straight onto the gold body.
With the meter I mentioned (£5) the total resistance through the two plugs and the meter was a mere 15 milliohms. (Volts drop divided by current).
Which is plausible, if you look inside you’ll find that the current shunt is just a piece of stout tinned copper wire. Sometimes just a thick PCB trace. No fuse etc. Very robust.
That’s also the reason they are not continuously rated. E.g. maximum 15 seconds, then rest for several minuutes.
It’s not that they can’t handle the current continuously, its because the copper shunt used increases in resistance as it warms up. About 0.4% per degree C.
As will your test leads, but more so.
A more expensive meter might use a better internal shunt, with much less temperature variation.
As the resistance increases, the current measurement becomes over-optimistic, i.e. a 10 degree temperature rise would raise the reading by 4%
I don’t usually worry about that.
These cheap meters are actually quite useful for tailcap measurements, providing you use them correctly (short stout leads). Despite the FUD spread by others on this forum who don’t necessarily understand what’s going on, or who prefer to spend much more money on “better” meters, but don’t know how to use them properly either.
Try measuring the volt drop at the meter terminals and let us know. I think you might be pleasantly surprised. :wink:
And knock up a set of short stout leads, I’m sure you will see the difference.
Resistance is futile… :bigsmile:
I was trying to measure the voltage drop caused by the meter with the leads included, i.e. the effect of the leads! I do have some heavy cable with banana plugs on the ends. They aren’t nicely shrouded so they should be kept away from multi-meters particularly ones that get used on mains voltages.
I haven’t tried using the good old AVO meter for a tail end reading, yet. I think it’s battery may need replacing, it’s getting a bit old!
I still have an AVO 8. Doesn’t need a battery except for resistance, I still trust it, and the analogue pointer can tell you stuff that no DVM can.
