I’m actually shocked and insulted by the response to my knurling issue. I’ll keep following up to get a replacement. I normally wouldn’t mention anything but am pissed by the customer service so far.
Nope, that only turns it off. Technically, it sets the heat ceiling to 255. Then after going up to full power it actually measures the temperature and stores that instead. It keeps reading and storing the temperature every couple seconds as long as it stays on in that mode. So, when you turn it off, the new ceiling is whatever it last saved while it was running in unlimited turbo mode.
To set a new ceiling, you actually have to get it hot… and a 3.2V cell isn’t going to get it hot.
We (I) will see what we can do after CNY. That may have been Neal or an assistant .... not sure. This much I do know... Even though your knurling is fowled up they have been buried with the BS stuff and that is going to play a part in anything from here on...if anything from here on. Just because things are not being posted do not believe for a minute that people are not making attempts to get refunds, discounts etc etc and that is going to make it harder for the few that have issues.
I just tried it to be sure, and mine keeps its memory regardless of tailcap. It can’t even tell the difference between whether I use a tailcap or a paperclip to connect the power.
OK. I do apologize for airing my dirty laundry. Was just upset because a fairly legitimate issue was met with a $3 offer. I just want a tailcap. Not a token.
People have a variety of opinions on flashlight grease… I find that “Super Lube” (PTFE / Teflon grease) works well, and it has virtually no interaction with anything.
Note that the copper is coated to keep it shiny. I’m not sure what the coating is, but people will likely want to know how to preserve it and how to easily remove it. Dale stripped one of his, but it sounds like it was a lot of effort.
[/quote]
Thought I could buff and polish off the dings, now with the coating it’s not feasible. Your info came at the right time.
Not at all Jack. I’ll make what I said simpler for you. The people who do all the work on these group buys would be entitled to profit from them. Even $5 a light would make them a little money, and all of us would be more than happy if they did. They don’t want to. They put in A LOT, so all of us can have great lights. When someone else, usually a new member who has not contributed, tries to re-sell these for a profit to other members, yes, I find that despicable. It goes against my sense of right and wrong. Get it?
The individually-generated coupons were there to make sure each person could get the amount they reserved, to make sure nobody tried to scalp them in bulk then re-sell them. But after the reservations are filled, it’s really just up to people to do whatever they want.
Did you see the prices people listed for reselling the BLF A6 on Amazon? Kinda crazy, but predictable.
