Was sort of interested at one stage, still not 100% on the aesthetics of the torch (too busy for my liking), but apparently this is one pretty compact torch with a decently throwy beam for its size.
Fully programmable driver too. About the same price as a V10R Ti though...
*quoting a post on another forum*
[quote]
How to do it is no so complicated:
- Power ON the light and quickly half press 10 times the switch
- The light starts to blink slowly, meaning you are now in programmable mode
- To reset the light in order to restore the factory mode (only low and high levels), at any time into programmable mode, quickly half press 5 times the switch. voila !
- To program the light, first you must chose how many levels you want. If you want single level, half press the light just after the first blink of the programmable mode. The light starts to ramp up slowly. Half press again to setup the level. that's it ! (remark, the light flash when arrived at max brightness)
- To setup 2 levels, when in programmable mode, half press after 2 blinks, then the light starts to ramp up slowly, one half press to chose first level, the light starts again to ramp up slowly from min brightness, half press again to setup the 2nd level.
- To setup 3, 4 and 5 levels, repeat the ramp mode as many times as your number of levels.
- Finally, if you half press when the lamp flash, you setup a strobe mode.
[/quote]
I don't really see a big reason to get all too excited about this light... Its got a great driver, but nothing else really stands out as being ultra awesome for $130. Somehow a V10R still appeals more for this kind of moolah... for me anyway.
