I have a small set of files with the handle end being about 1/8” in diameter. I worked this smooth 1/8” file shank into the metal clip of my X5 then supported the file on both sides over my bench vise with rubber covered jaws while the clip hung loose between the jaws. Then I drove the clip onto the file til it was up against the curve of the bend. When I pulled it back out, the clip was perfectly parallel! My bench vise is plastic, so I wasn’t hitting the clip all that hard with the hammer, the hammer is a ballpeen hammer head but it has no handle on it.
Very pleased with how this worked out.
At first I really loved the blue. Blue is a mood light, has a calming effect, often elemetary school walls will be painted light blue to chill the kids out, at least that is the theory. When reports came in of its brightness, espescially for dark adjusted eyes, my mild concern was immediately for inadvertantly resetting circadian rhythms. That’s what blue light will do: the studies are old, from the late 1960’s, and sufficiently repeated since then to become known as “good science,” (as opposed to “junk science” that is so popular, and untrustworthy, which is what I think Dale was getting at). As others mentioned, the issue has recently been in the news with LED screens disrupting sleep patterns for iDevice-like consumers keeping themselves awake inadvertantly with bright screens with a lot of blue light coming out of them. Some manufactures are responding to this, adding a feature to reduce the blue light, a night mode.
Then I had to admit to myself, in all honesty, that I am a night owl, so this won’t affect me adversely being up all night anyway. Night time is peaceful. The blue light will accentuate the peaceful mood with a tranquil calming. Though I love the Sun, flashlights work best at night.
Now after seeing your images, I realized suddenly there is a problem with blue light due to my subtropical location… bugs! For that reason alone, I may opt to switch to a lower frequency, higher wavelength. Most bugs should be entirely unaware of 660nm… but then there is the heat of red, which mosquitoes are somewhat attracted to, can apparently detect, and they investigate. I’m not sure what the ideal light frequency is to both avoid both attracting the little harmless critters as well as the annoying biting ones is— possibly an orange, 600nm, orange-red, whathaveyou.
With all the earlier talk of replacement switch assemblies without the LED, I’m now wondering of the possibility of attaining more switch assemblies with the LED, so multiple colors can be created for full swaps. How about entire assembled tail caps, so swapping out becomes nearly effortless? These lights can benefit from neat technical accessories like that. But I don’t know how far is too far, too luxurious and decadent, as having a drawer full of tail switch assemblies in their own tail caps, mostly going unused.
Yes, science is not truth, but instead but an evolving process that brings us ever-closer approximations of truth. Science attempts to model truth. Camelot! Camelot! Camelot! Its only a model. That’s not Truth! The science community moves forward when long standing paradigms are shattered by new theories backed by experiments that are repeatable anywhere with the same results, when these theories give us more accurate results. I’m not sure the paradigm-model of science is even the best one possible, but that’s what everyone has been using for some time now. Oh, you have a new idea? Its crap because this paradigm exists, and your ideas will be suppressed, maybe until long after you’re dead, until the evidence is overwhelmingly in your favor that you are correct. Until then, you’re just a wacko, fringe pseudoscientist. Science is approximations of truth, and models for predictions, and paradigms to protect the models. And it is clear there is a lot of junk out there, mostly the stuff that makes it to the popular media. I left science to study philosophy, because I love knowledge and I was interested in truth. Truth is the domain of philosophy, I’m afraid, and as it turns out, truth is likely unknowable. And science backs this up. What a waste of time and money. TIME and MONEY, now that is the new hotness. Forget science and philosophy, what you want is time and money.
I answered your questions despite being irritated with your tone numerous times because I thought that there was no way that someone could receive as much criticism as you have and continue to be difficult when someone treated you kindly in a gesture of good faith.
You didn’t say thank you, even though myself and others have tried to help you. You refuse to listen when others who are authorities on the subjects you question try to give you information that would solve your problems. You insult all of us by claiming that you were the one that was being reasonable.
If you have any other questions, I hope someone else has more patience than I do, because I’m done.
Btw, I’m not going to alert Neal that you are a trouble maker, but I wouldn’t be surprised if someone else does or already has.
You are on my permanent “Do not deal with” list that I keep in pen on paper on the top shelf of my desk.
I think I may leave the ramped opening away from the body that little bit so it has less chance of marking it up. It’s not really secured by that pinch factor anyway, with the more substantial weight of the full copper light it hangs deep in the pocket with ease as long as the clip can accept a hem. Probably won’t carry this one anyway, as I’ve got the quad on me at all times.
wow that warm glowing cap on the copper really brings a sensual dimension to it and takes it up another level in the ‘artistic’ rendition of a sophisticated tool.
The blue looks good on the ‘cold steel’, maybe a tad bright, but can be tamed easily with a bit of filter/diffusion, using circular cutouts of acetate sheets/gels right at the top of the boot, without doing any circuit modifications.
The SS is just too heavy for clip carry, but without the clip, a gap there dis-harmonize the continuous line…what to do ?
my reflector in my x5 is jammed also is this a problem? can i try and force it or will that be bad? any chance that the copper would shrink if its really cold or hot?
“…Its crap because this paradigm exists…in the popular media…”
Fret not…A Priori has it’s limits, because it deals with the past. Relish your own discoveries in the present, and look ahead in wonderment what tomorrow may bring.
(…The slow one now will later be fast, As the present now will later be past…B.Dylan)
Keep writing code TK, all’s well.
I absolutely love your photography, I need to break out my dslr, I learned a little bit trying to photograph frogs as a kid, my phone doesn’t cut the mustard. I had to apologize sending pics of the X6/X5 to my brother in law who is a photography buff.
Thanks for all the pics, you are a huge reason why this forum is fun for me. I’m thinking a tripod is in my future.
Good advice. I spend too much now thinking of then.
Good artists copy, great artists steal, so they say Picasso said, and Dylan stole that gem from Matthew 20:16. Sorry for being pedantic, but I had to look it up. Is it more important who is saying, or what is said? The words reformulate, but the message stays the same.
Coefficient of aluminum is much higher than copper so cooling it will shrink the reflector more than the copper head. If it’s jammed then either cross threaded or just too tight. If cross threaded it might appear tilted in the head. Copper is soft so over tightening could explain this or just from snugging the bezel. Don’t know for sure just educated guesses at this point.
Dale, I’m glad the file and hammer trick worked for your X5 clip, but it didn’t for mine. I might have been too aggressive with the hammer. Anyway, I’m now in the market for a new clip. Preferably with a wider and deeper loop than the stock one.
Notwithstanding my new clipless state, these are awesome lights. Just spent 20 minutes with my 5 year old son playing with my Al X5. He figured out how to turn on turbo, laughed like a maniac, then suggested that we should get another one as a present for mom. And now she can be mad at him instead of me when I buy it. Win Win!
I hope you understand that I in no way intended to minimize the efforts you put into this light ToyKeeper! I truly didn’t mean it that way. I was simply stating that being understanding of both; those who had legitimate claims of a defective or inferior product, as well as those who went through the grueling process of bringing this set to fruition, should not be considered mutually exclusive of one another.
1. Many people worked very hard to make it possible for this GB to happen.
2. This group buy IS a first in many ways.
3. There are problems with all GB’s.
4. The lights are, as a design and implementation, amazing.
5. No single thing is perfect.
I could keep going for a long time, but instead I’ll get to the point of why I’m writing this.
I WANT these lights to be incredible.
Why?
Well, I have been playing with LED’s since I was a little kid. My dad had drawers full of all kinds of electronic components and anything that made lights or sounds was always something I wanted to play with.
I had asthma as a kid and had a bunch of inhalers around. They looked like pretty good pistol grips to me, so a little electrical tape, a toggle switch, a few LED’s, some wire, etc, and I had a gun! (Yet I thought MacGuyver was awesome, explain that!)
I still have the first flashlight someone other than my parents gave to me, it’s a AA mini-mag with red anodization. It’s the old kind with the shorter head and reflector, I just can’t bring myself to mod it. It was a gift from my friend’s mom, I just found out she has cancer. I’m going to stop by soon and I’ll probably mention how much it means to me. Not because it’s a flashlight, but because I treasured it as a kid.
I’m not trying to make everyone sad or tell sob stories, it just happens that LED’s and flashlights have been a part of my life since I was a little kid. When I found out that other people were into them I was a little upset, only because it was always MY thing, and it’s not like I was on the football team or anything. (Full disclosure, I got big in my early twenties)
You’d think that because I’ve been interested for so long I’d be just about the most knowledgable. Nope. I knew about the good LEDs fairly early on, I’m pretty dang good at modifying Maglites, and I’ve done a few other pretty cool projects, but nothing like what many others here have accomplished. Here’s where this becomes relevant to this thread again if you’ve managed to read this far.
The people that put these sets of lights together are almost painfully modest.
I read a comment that suggested that it was an easy task due to the fact that the X6 had already been designed and produced. That is a drastic simplification of the situation.
I’m not going to go into boring detail, but these lights are very special. The details of the changes and features of these lights are pretty well documented in this thread. I suggest if you have further doubts to get a set of the SS/CU in your hands. No, you can’t borrow mine
Take a moment to realize that these lights are just a moment in time, there WILL be brighter lights, there WILL (probably) be another group buy that involves lights with a similar set of features, there WILL be moments in which you will be dissapointed for a myriad of reasons about something that you purchased.
But none of that matters. What matters is that most of the people that were looking forward to these lights are not disappointed or jaded or complaining. If they are like me, they have been showing these suckers off to anyone that will listen! These lights are, to be frank, AfreakingMAZING!
All of that being said, I return to my original statement, with the hope that what I’ve written will be heard and maybe even have the effect I was going for.
We’re all here because we like FLASHLIGHTS!
Turn on your favorite light. Don’t you want to talk to somebody who gets it?
