BLF Kronos X6/X5 GB - Group Buy now closed.
This reminds me of an issue on another flashlight.
About a year ago I wanted to see which of my 4 HD-2010 throwers worked the best.
The brands are Fandyfire, Trustfire and Tangsfire. All of them are the older good batches with the direct drive East-092 driver, of these the Fandy had the worst indoor 5 foot white wall beam. Big ass donut hole. So I spent probably 2 yours trying different centering rings, reflector height, lenses, etc. Got it a little better but not clean like the others.
Well wouldn’t you know that “bad one of the bunch” is my best 2010 thrower when you finally get around to using for what it was meant to be, an outside flashlight.
I went back to the original spacer with the even bigger donut and the throw got even better.
Also got a Conrui Big Head flashlight from a fellow BLF member that he had been modified. Upon arrival it had bad donut hole and a couple slight rings.
Thinking WTF, that guy doesn’t know what he’s doing. Then night came, THEN I saw that sucker was dialed in for what it was made for. He had it right.
Sometimes we have to accept the fact that not all inside beams are going to be pretty.
So, point here is, that little bit of yellow that a certain member is obsessing over, is not visible at any real distance, so no big deal.
It may be less visible with reflector tweaking or it could get worse. Even worse would be to get rid of it and only then discover that you lost output of got the dreaded “Rings of Saturn”
I have one Kronos X6 that has the yellow spot, I consider it the laser center:)
Not Touching it.
P.S. To get the reflector loose, try covering the top to keep inside surface protected and blast the rim with Computer Duster spray with the can turned upside down. The cold blast may help it come free.
HTH
Keith
I would agree with this, with one added negative - balance. These dense lights are already kinda top-heavy in the hand. A shorty tube would probably make the thing feel like you’re holding a small bowling ball (with a little protrusion). I wouldn’t be interested in that.
A triple head, however, is another matter. I know there’s been some talk already and I hope it comes to fruition. What I’d really like is another copper “light engine” piece for my stainless light that’s cut for a triple. Just unscrew the reflectored light engine from the bezel and battery tube and swap in the triple engine.
+1 to all those points.
Just ordered my SS/cu set. Thanks to everyone involved that made these happen and for giving me the opportunity to join in a bit late. That won’t happen again after experiencing the A6 first hand. Now I refresh the special edition lights section everyday. Thanks again!!!
How about an adapter ring to fit a A6 head onto a X5 body?
I got mine yesterday, and all the serial numbers lined up. These lights are so impressive, and the workmanship is crazy great. I really don’t know how the manufacturer can make any money on these. Anyway, I showed my wife these, and she of course does not support my flashlight obsession. After playing with, she said, Can I have one?! And of course I told her, “Go get your own! Ha!
These lights are awesome! The X5 throws like a beast…
Some close up shots:
Just noticed in a pop-up ad from Banggood something that looks exactly like the BLF Kronos X6/X5 for $199. Wondering if anyone knows if it’s just the result of something automated on their site, of if they’re actually available, and if they are, do they say KRONOS?
You are right, the only way to see the spot is inside on the wall or ceiling, outside it will have no impact. Will try the duster spray trick, but it’s not so important now that I know that I can live with the yellow spot. I’m not going to use this light just inside, I have so many other lights for that.
Sorry Bugsy36 for all my complaining… see others have the same issue, but they can live with it. But still something to take with you and the rest of the team for the next GB, to make sure the producer have better QC on each light. Can we agree on that?
Hope you can pull of a 3 or 4 led light, but then in a X6 or some else light with 18650 battery, so you actually can enjoy it for some time, and not just minutes before the 14500 battery is empty.
It’s a placeholder for the light in the store. But you need a code to buy it. But they have to list it on the store so people with codes can buy it.
Will34: Really nice pictures.
Reasonable assumptions can sometimes lead to unreasonable expectations.
I LOVE building triples and quads, really, I do! :bigsmile: But while we can reasonably assume much greater brightness and output, it’s not reasonable to assume that it’s a good thing to do. A good triple is going to pull 9-11A. Since we don’t have any 11,000mAh 18650’s, (well, you know) then it SHOULD be obvious it will take a light with a minimum of 3 parallel cells to supply power to a good triple. This means a big light. Most of us don’t want a big light. So we put up with the shortened run times from the little beasties. :wink:
I really like how the SS acts as an insulator against the heat, protecting the cell from the truly incredible amounts of heat that can be produced in the pill. The SS/Cu X6 is a perfect candidate for a triple XP-L HI. I’m actually amazed at myself… my SS/Cu X6 is still virtually pristine! (This too, shall come to pass…) :wink:
I need to get some higher drain batteries, the laptop pull I’m running in the X6 isn’t cutting it, and neither is the efest red imr I’m using in the X5, I think I’m way under-driving them. They’re still very bright but I’m definitely missing out.
I should walk out to the car and get my meter but it’s snowing and it’s warm inside. What a horrible situation I find myself in.
Run out there and back as quick as you can then turn oin your hand warmers. You will think it was worth it while everybody thinks your crazy. ;)
My SS/CU set are stuck in USPS Purgatory! According to the tracking information I should have received them yesterday, so I got prepared Wednesday evening and charged my cells so I would be ready to try them out as soon as I opened the package. Unfortunately USPS seems to have dropped the ball, the last entry on my tracking number is:
2016-01-30 09:09 ISC LOS ANGELES CA (USPS), Processed Through Sort Facility, Your item has been processed through our sort facility in ISC LOS ANGELES CA (USPS) at 9:09 am on January 30, 2016.
The USPS site said to expect delivery Feb 4th, but it seems my package got stuck / misplaced somewhere. USPS really does a poor job of tracking packages! I hope this is a temporary issue and my package will still arrive in the next few days! It is driving me nuts to see all the posts talking about the lights people have received and mine are still not here!
Waiting very impatiently,
Melven
Melven, sounds like it’s waiting to go through customs. The approx dates are rarely correct when customs is involved.
I’m sure I’ve been seen using flashlights in broad daylight. It’s too late for me to appear sane anyway, I’ll go get it :slight_smile:
I thought since it said processed through the sort facility that it had already done customs
I know this isn’t going to help much Melvin, but I live in MA and I had 2 sets that were in NY last Friday according to tracking.
One set was delivered Monday, but the other set somehow was sent to CA, then back to NY and then up to MA and it was delivered Wednesday.
I got my meter, but the stupid fuse is blown, must have happened at work…. So the question now is, Harbor Freight or Home Depot? I saw in the Home Depot deal alerts thread that somebody found a Klein auto-ranging meter on clearance, I wonder if I might get lucky.
