Pilotdog68 designed an oshpark board with a switch inside the spring. It should swap in and add this ability.
[/quote]
So, this new switch will still have the LED , and it will function like the one on the aluminum light, a twist will turn off the light? Are these available now? Anyone know? Link please? Or contact Pilotdog68? Thanks.
The switch fits on the spring pad and only enables/disables the tail cap LEDs. It’s not in production and only an oshpark DIY board. You could probably find someone willing to put one together for you though.
My lights were stuck there from 1/30/2016 - 2/3/2016. I didn’t receive any notification until 2/4 and then it was delivered. Its the Blackhole of the USPS. Prepare to wait a few days. Have patience.
To the GB powers that be: I’ve bought lights in the EE X6 group buy, the A6, and now the Kronos set. It occurs to me, there has been a lot of complaining as well as a lot of love, but I think it’s fair to say each GB has been increasingly successful. The goals have been better reached, and the greatness of each light has escalated as well. At least it seems that way to me. So, I again say thanks, and hope everyone involved is proud, and encouraged. Things are skyrocketing, don’t you think?
I think the lighted tailcap adds a lot to these lights in terms of the ‘excitement factor.’ I was considering them without it, sure, really nice, but not as nice. Great innovation!
One of mine is staying in configuration mode. Trying to get it back to factory default. Let it blink 8 times and cut off during the shutter. Turn back on and it’s still in configuration mode. What am I doing wrong. Thanks for the video Dale, helps a lot.
How long are you waiting after cutting it off during the shutter? It takes a couple of seconds for that switch-off to register, and some of the lights seems to be longer than others.
From the factory it was in configuration mode. After letting it sit for about 20 minutes, it’s now has 3 modes, low, med, high. Tried the 16 half clicks to enter configuration mode, nothing happens, just goes through the 3 levels and never goes into config mode.
0805 is the correct size to use. I used a 10K 0603 because I happened to have a bunch of spare. The smaller one fits fine. I think with the 10K, it's still a little too bright.
southland - I'm not sure how that can happen, being stuck in config mode. Maybe TK can chime in.
