Just a wee heads up - this works out at around £35 with the code - I could be so, so tempted had I not ordered a normal S1 from AE earlier today for about £23.
If Windows support is a necessity for you, I’d suggest sticking with a laptop or desktop. Windows support of these type of devices is poor. (What works now, works. When they issue an upgrade, all hell breaks loose.)
Got a bunch more stuff, Sanrenmui's, Ganzo's, the BTU, Skyray's 4x's, tools galore, drivers, xm-l2's, 2.5 and 3mm solder wick, solder paste, Convoy S2's, 3's and 4's. That was just today..
The stock S2+ draws a maximum of 2.8A, so just about any good quality 18650 will do. The flashlight has springs at the head and at the tail, so it doesn’t matter whether the battery is a button-top or a flat-top. And the choice of protected or unprotected cells should be based on your comfort level in following proper protocols for charging and recharging the cells.
Tried to order 3 car micro USB charger. KUNGHEI did not work. Time now is morning 7 Feb Eastern US time.
Update: it worked but I had to order 1 only, then changed to 3 then it worked.
If ordering 3 straight away the code did not work
I ordered some batteries yesterday and was also presented with Sweden Post as the only option (in the past I’ve used USPS Expedited for Battery).
I received a battery the other day from BangGood and noticed it was shipped via Sweden Post. Perhaps there are new shipping restrictions in place that’s forcing vendors to use Sweden Post for batteries?
I, with 20% discount, I bought SHADOW JM35; I also order the batteries, but the Swedes post have placed far too slow; also they serve 50 days, to make me get the goods, I left the batteries.
Sounds like you may have found some faults with their shipping system. If your having a problem, know what you want and send them your list and tell them the problems your having. Definitely make a ticket to make sure you get your discount, I would have done that right away as you may have. I've spent well over a thousand dollars over this discount period buying everything from solder wick to 100 dollars flashlights, over multiple orders. I have not run into any issues. But as you have noticed, batteries are a strange bird to ship. For the most part FT has been well above any of the other asian companies to deal with when issues arise. For me over the years they have been around 98% consistent. The longest I have ever had to wait for something to reach my door is 14 days. Earliest has been 6 days. Not one of the other companies can even reach FT's worst shipping time. I pretty much use them exclusively.
That is highly bizarre, but living in Hawaii might have something to do with it. I think it all gets shipped to the continent of the United States. The reshipped to Hawaii. I've never waited more than 14 days. What do you think?
I have noticed that FT has been slipping on shipping items that show in stock within a few days. I ordered the BTU when they brought it on board the same day and it did not ship for a whole week when it said in stock. I cancelled the order. But I went ahead and bought it yesterday because of the 20%.
