I installed it with the “Stylish” addon (Firefox) — which will install and also optionally auto-update from a URL; do you feel secure enough to support automatic updating once it settles down?
If so you could give it a URL name like “latest” for the auto-update to find. I know you know that, just, er, mumbling.
Not that I think automatic updating is a good thing. I’m just lazy and prone to miss improvements if I’m not alert.
i thought this thread would be about secret after dark BLF activities, such as secret societies, rituals, sacrifices (of lumens of course) and so forth.
nope, i posted that in the migration completed thread
FWIW, I noticed that I forgot to style private messages. So… I did that, and updated the css file. It now applies different styles to new messages vs old messages. I’ll post a screenshot after I get a new private message (but not too private ), and maybe after fixing another little issue I just noticed.
Need to do something about the message number text. It shows:
… with the last number on a new line. Even though there’s plenty of room on the previous line. Probably some sort of hard-coded size in the parent stylesheet, I’m guessing.
TK could you alter the theme to make the color of the Maim Menu (on the left) items the same as the brighter blue color of the “Home>Forum>Miscelaneous” items on the top? The same goes for the thread list, they’re too dark to read against the dark grey background, they need to be a little brighter.
I found that I had to override it the forceful way though, which had some side effects… like, links which used to be white turned blue. And I found it seemed a little too bright. So, for me personally I think I’ll stick with the un-styled links (inherit the default style from BLF instead of overriding).
In any case, it’s at that link and the one-line change is tagged with DanielM if you want to find it or modify it.
Finally themed the tab widgets, like at the top of the account settings.
No more weird wrapping on the private message thread pager.
Less obnoxious “Tag this conversation” widget.
Shadows on links to increase contrast, instead of making the text color brighter.
That last one is probably the most noticeable. It showed me a few things I didn’t realize were clickable before, like in the commercial sellers’ rules:
I haven’t tried, but I don’t see why not. If it can run the Stylish extension, it should be able to do this.
So, I looked it up. I’m seeing “May 14, 2015: Google Chrome for Android will not be getting extension support any time soon, Chrome developers say …”
However, it seems to work on Firefox on Android. After installing Stylish, I told it to get styles from userstyles.org, searched for “BLF”, and then followed the links to install it.
As it says in the first post:
To use this, install the “Stylish” extension, then search the userstyles.org repository for “BLF” and follow the instructions there.
