Thanks TK! Got it working on my tablet in firefox. Nice for in the evenings, and when I want the classic style I start blf in chrome
It is now even more obvious that the battery is inserted backwards in saypats avatar
Yes, I removed the ‘top’ links. Or maybe the file I started with did that, I forget. I haven’t missed them though.
If you search the css file for “jump to top”, there’s an obvious “display: none” line to edit to get the links back.
On Android, after reading through a thread, I usually just pull up my bookmarks and go directly back to the my-subscriptions page to find the next topic. I’m not sure if this works for you or if getting the ‘top’ links back is better.
I don’t mind the lack of the top button, but when at the end of a thread, I normally use the home button to get back to the recent posts page, now I have scroll to top to hit the recent posts button. Or do I do something obviously wrong?
That’s odd, since I didn’t actually style that. I’m not even sure how to style it, since it renders itself with some fancy javascript. However, it seems that I can at least change the text color by changing the main global document text color.
BTW, did you see the complaint earlier about the interest list in one of your threads?
It seems the list items have explicit background colors set. I’m not sure if there’s an easy way to remove the style though.
Ah, okay. I never noticed those links before. It looks like the file I started with got rid of the entire footer. I added them back though, and it’ll be in the next update.
Also, a couple other separately-installable styles added to get rid of other page elements, but not published on userstyles.org (only on tk.net). They remove stuff which shouldn’t be removed, like the search widget or some other things, so they’re not included by default or as easy to install.
The day that the forum was down we chatted about which linux distro would work on my netbook, got linux mint installed and flashed my first drivers from linux last night…i owe you much gratitude (and drinks!)
