What did you mod today?
9456 posts / 0 new
OscarM
Last seen: 2 years 11 months ago
Today i have modded a trustfire 3t6, i changed leds from 3x xm-l to 3x dual nichia 219A.
A bit too much work in the end I’d say, since it ended up having a donut hotspot :~
I had hoped that somehow the 3 reflectors would help against that
Ouchyfoot
Ouchyfoot's picture
You really shouldn’t be getting a donut. I think if you try getting the reflector lower, or the emitters higher. Thin centering discs or paper gasket. Maybe sand down the centering rings you have. Did this light always have a donut?
pilotdog68
pilotdog68's picture
Last seen: 10 months 1 week ago
It sounds like he put two nichias in each reflector, and that’s what’s giving the donut
Ouchyfoot
Ouchyfoot's picture
It tried that once with a c8 and XP-G2… Big fail
chouster
Last seen: 9 months 3 weeks ago
Made a Convoy C8 with dual channel 105C-based driver running bistro, 10x AMC7135 + 1x AMC7135, and XP-L HI V2 3D. Played around with it for a short while, didn’t like beam that much. Would have done further adjustments, but than I saw a big black spot on the DIE. Bummer. Hadn’t had that happen until now. What could cause such a failure? The LED was bought already mounted on 20mm noctigon from IOS. Normally I reflow them myself…
pilotdog68
Usually it means there was something on the dome/flat part like dirt or something that burned a hole in that spot. Probably not anything to do with a reflow.
chouster
Have you heard about baking LEDs before reflow? Cree and Nichia recommend that if the LEDs were stored in a too humid environment or if you assume they could’ve been… Otherwise they can get destroyed during reflow process. Not saying that’s the case here…
djburkes
djburkes's picture
Last seen: 2 years 8 months ago
Built an EE X6 triple with a copper spacer, a fet+1, and XP-L V6 0D leds. She puts out alot of light.
chadvone
chadvone's picture
Last seen: 3 months 4 weeks ago
Put my blf a6 back together.. again…
Edit—- Trying to decide if I want to mod my M2x-ut or sell it. Planing a C8 or M2 build
lostheplot
lostheplot's picture
Last seen: 4 weeks 1 hour ago
Just thought I would share todays project
fitted triple xpg2 and narrow optic with a 18500
using a 18350 tube,its a little rough.
soldered the 3 parts together
used a blf driver without spring,tailcap bypass,, slides together metal ring holds it in and supplies good earth
with the centre tube
gets hot real quick ,..
,drains 8.6 amps
sorry all images down
thanks photobucket
MRsDNF
MRsDNF's picture
Last seen: 9 hours 10 min ago
Nice mod. It looks like you have been to the OL or RBD school of modding.
LSX
LSX's picture
Last seen: 1 day 16 hours ago
No pictures but I stripped the driver in my brand new Archon D22, LED+ lead straight to the top of the battery spring and LED- straight to the body. Also swapped out the XM-L2 for an MT-G2 on 20mm Noctigon. First diving light and it's pumps out some light underwater.
chadvone
chadvone's picture
Did some reflow tonight.
http://budgetlightforum.ddns.net/node/44796
Edit— Also set up a beam distance station in my mod room.
djozz
djozz's picture
Last seen: 39 min 47 sec ago
(actually two days ago) I put an SSL80 4000K 92CRI into a very cheap AA zoomie (from dx, FT has it too). I used a 6-chip AK-47-C1 for 2.1A current. Output is 300lm flood, 150lm spot, and I set the focus a bit above the die in the dome so that it is a smooth round spot instead of square.
The mod did not go smooth, the driver floating under the pill is not ideal during assembling, the ledboard+solder blobs were too thick so that the plastic clamping ring that pushes the board onto the pill hardly has a grip inside the pill cavity. The switch mod was not done well either, but with 2A max that it should survive.
The result is really nice though, like it a lot! Smile
WhitedragonBC
WhitedragonBC's picture
Replaced the 219A in my D25A with an XPL HI V2 5B4 and added a bit of solder to the positive contact so I could use a flat top Efest 14500. Warmer tint, higher output, runs cooler.
Also put the same LED in my Kronos X6 and bypassed the springs.
Unfortunately I only have one left and it doesn’t look like I’ll be able to get anymore.
djburkes
djburkes's picture
I put a fet+1 in a XinTD C8 7135 that has a XM-L U3 1A led in it. It’s a little brighter.
eebowler
eebowler's picture
Last seen: 2 weeks 5 days ago
I received an xtar charger that failed when the AC adapter was plugged in. Xtar warrantied charger and I told them I’d destroy the first since I couldn’t send it back as they requested. The shell, messed up circuit board and sliding contacts remained, so, I built a charger/light combo using a 4056 charger and half (4.2V) of a messed up MTG2 LED. Big Smile
The left ‘bay’ is the charger and the right bay has a 3× 7135 driver powering the LED. The ‘diffuser’ is piece of a toothbrush case stuck down with double sided tape. Big Smile
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
pilotdog68
that’s one of the weirdest things I’ve seen someone make on BLF :THUMBSUP:
chadvone
chadvone's picture
In charger lighting!
eebowler
eebowler's picture
:dance: Big Smile
Part of the reason was that I didn’t have a single 26650 light so instead of spending money…
chadvone
chadvone's picture
Stacked some chips on a stock Convoy C8 driver.
leroycp
I installed an A6 driver in a Nitefighter 502B. Driver ring was jammed so I drilled the driver and left it in place. Filled the gap with wire and soldered. The spring actually needs to be clipped but I chose to put a thicker Oring and all is well. I really do like the A6 driver. Wish the Bistro was available. Nice light now!!
CRX
CRX's picture
Last seen: 2 weeks 12 hours ago
Built a Trustfire Mini 01 triple today with some spare parts i had.
Copper & QTC pill in the tail for variable output, Also made a copper head spacer.
I didn’t realise the 3 XP-G2 were different tints until i had it put together, doh – i think there’s maybe a 2B, 2C and 1A in there, not entirely sure. :-/
This bothers my CDO so i will call it an intended tint balancing feature Wink
Also ground off the keychain attachment and installed a magnet in the tail and some heatshrink around the body.
djozz
djozz's picture
Nice mod CRX! I have some QTC pads waiting for a mod still.
CRX
CRX's picture
Thanks djozz, yeah the QTC pills come in handy for when you accidentally break drivers.
pilotdog68
Is the whole light copper or is that just the lighting?
CRX
CRX's picture
Just my terrible photography mate.
chadvone
chadvone's picture
TBF tint balancing feature. I like it. Maybe make a bezel cover with single hole so you could rotate it to select you desired tint Smile
CRX
CRX's picture
Pure genius Big Smile
jacktheclipper
jacktheclipper's picture
Last seen: 18 hours 29 min ago
I made a butter knife into a steak knife in four minutes to demonstrate the effectiveness of my Ken Onion Worksharp .
Have I mentioned how much I like this tool ?
Hat Beer
