People live for that. They run out of lights to fix, so the next best thing is helping other people fix lights.
Andyman,
Sounds like a bad driver to me if that did not fix it…
Any light can have quality issues, this one too, so I hope these get fixed, it is a nice little light…
Well, I haven’t got mine yet (it’s in the mail), but I don’t expect high quality on a sub $10 light. I do expect it to work, but if it has a few glitches occasionally that’s what I expect from a cheap light. I would certainly never use a cheap light like this as a primary light where I really needed it (like a nighttime walk in the woods or something like that). So I’ll use mine around the house, or carry it when I don’t really think I’ll need a light (but where a light might come in handy).
It is a cheap light for the features, but not being able to use it when you want to, or if it is your back up light, kind of negates the reason for it…
I don’t know how many have been sold, but so far one scratched emitter and two possible bad drivers are not that bad, especially if Banggood makes good on them…
To turn a cheap light into a reliable expensive light, just carry two of them. One of them is bound to work when you need it, and it will still cost much less than a reliable expensive light.
I like the way you think!
Could this use 10440 li-ons?
It can and it’s brighter with 10440, but gets hot quickly. 10440s are not supported officially, so I can not tell whether it will damage the light in long term or not. I will use it with AAAs.
It does not officially support 10440’s, I have tried the 3.2V LiFePO4, and it worked for a couple of minutes during testing…
It is so nice on AAA/eneloop, I see no need for 10440’s in this light… Just my opinion, if anyone runs 3.7V for a long time, report it here for this that want this knowledge…
I purchased two. I was unable to get one to work until I removed the spring and cleaned the inside of the barrel. That would not be too bad, but every time I change the battery I have to remove the spring and reinstall it for the light to work. The price on Banggood is $11.95. I recently purchased two Tank 007 e09 lights with the FT discount for a total of $22.54. My experience with the two lights persuades me that the Tank is much better so I do not think the Astrolux is a particularly good buy.
Jerry
Jerry
Pull the tail spring, wrap some fine sandpaper around a pencil or dowel and polish the end of the tube with it where the spring goes.
There was some anodizing over spray in the purple one I had. This should fix your issue with that one. I cannot think why else removing and replacing a spring would be needed, except for bad contact surface where the spring is…
Just the comparison with the Tank 007 E09 makes this a not so good light? I do not think you can get a high CRI version of the Tank without moddding it yourself… The Nichia 219B V1 is $4 by itself… So you would have to add $8 to your total and mod it yourself to make the Tanks High CRI…
I agree the Tanks are good lights, but they do not make this one a bad purchase either… For what I want, these are my current favorite….
ReMan and ImA,
I finally got around to playing with this a little more. Shaved the donut (reduced thickness by about half), and while I didn’t think this was possible, it got even weirder. Now it’s a 1-mode light! Really - it doesn’t cycle through modes any more. It actually turns on a little more easily, and at least it’s consistent - the twisty does feel more “normal” and less finicky. But where did the modes go? It still turns off when I tighten the head all the way, but I have to tighten pretty hard for this to happen now - it doesn’t turn off with a normal finger-pressure tightening, only when I grip it harder and actually try.
Overall I have to say it’s improved, but I was hoping for a light with modes…
Is there someone here who represents BangGood that I can PM to hopefully get a replacement? Or would I be better off emailing their general CS contact?
Thanks!
Andy
For my two Astrolux’s, I encountered two different problems that affected the UI.
First, overspray of the anodized finish onto the threaded end of the barrel. Easily taken care of by filing/sanding the edge.
On the end of the tube. [image]
Second, gunk or sludge-like residue on the flashlight head (positive node) plate that prevents the flashlight barrel from making a good, clean contact. You need to clean the plate off.
Try the old paper clip trick. Bend a paper clip around the AAA battery, clip the excess off, and fit it into the head of the flashlight. Tighten the head down with a reasonable amount of force (slightly more than simple “hand tight” force) to make contact. If this doesn’t work the first time, take the ring out and put it back in a different position. Try this several times. [image] [image] [image] If the flashlight works, the problem isn’t short threads (as is usually the case when the space…
Once these problems were taken care of, the UI worked smoothly and reliably.
I had a problem with it not turning on. I somehow fixed it by messing around with the head (moving the pill clockwise a little bit). The head had problems, and it still does, the foam is not stiff enough, so as soon as I put on the head, it turns on. It was finicky and too loose with turning on. I put on another retaining ring, and it didn’t help. I eventually have it mostly working by pressing on the spring a few times so it would not press it so hard to the foam.
It works but feels very loose.
Try wrapping the threads in the teflon plumbing tape. A couple of wraps have tightened up my threads on another light and make it easier to keep from coming on accidentally. Neither of my A01’s heads are loose enough, but we all know that threading can vary…
ReManG, you contact with seller and manufacturer.
Can Astrolux create 1x AA flashlight with same LED, driver, but with button and slighlty bigger (AA size) heatsink in head (as in 1xAA Zebralight’s), for cooler work in 100lm mode ?
My second one arrived yesterday and the head wont screw all the way past the o ring . It works but mot waterproof at all. Its liker the threaded part of the body is too long or the pill isn’t screwed in far enough I cant get it to move any further in to the head. Anyone else had this problem?
Thanks
I’m interested in a nice orange
I have definitely fallen behind ReMan, You always have the best reviews, AND the GB I also just found for the Cu’s
I had wished these would come out in Cu and you have it done, fantastic, these little lights are great and really were a surprise when I got it back around Jan, from packaging on great light…
One caution — be wary of these coming on accidentally at the bottom of a pocket or purse.
My orange had the flicker problems mentioned earlier; I worked most of that out with disassembly and cleaning up, and now I just get a bright flash before the moon level, but not the jumping around and skipping.
But it’s twice now come on deep in a pocket. I have to turn the head WELL past the “off” position to avoid this happening.
The threads are wobbly enough, apparently, that a little pressure sideways on the light can cause it to bump on and bright.
Then it gets really hot fast if it’s down in some insulating material.
I’m putting a fat O-ring on the light that I can slip into the groove behind the head when the light is off, as a safety.
Could just be a mismatch between head and body if the threads are plus-or-minus the desired spec and I got the smallest body/largest head threads.
Anyone else noticed this?
I had not noticed the coming on of the light, but I can see it happening… I put a few wraps of plumbers Teflon tape on the threads on all my twisty lights to tighten them up… Give that a shot as well… I like the oring idea though…
