The Miller, that is great. Now I gotta go cook a flashlight.
Any idea of the temp the change takes. Wondering if it could be done in OVEN?
If not I am off to the RV
No we were just amazed by the changing color, totally forgot to measure the temp /insert face palm/
I hope somebody knows a little more about this process, I find not a lot googling on the phone now.
I’m thinking of doing the top portion only of my new TR-J20, it needs some character. What do you guys think about just doing the top part that is flat and says Trustfire, it unscrews from the finned area. Whoa! Or maybe just do the finned area and leave the top and battery section black….
wight (or anyone),
Can you try viewing that post again in Firefox and in IE. It should work now with Chrome, Firefox, and IE. I think that the latter two didn’t like the image links being SSL. It’s post #144 in the thread (What did you mod today? - #140 by ohaya).
I’m on chrome and the images are fine. Safari too for that matter.
You can only bake the cheap anodized lights. HAIII anodizing will not change colour.
Mt TF JR-J20 is cheap ano isn’t it?
Sorry PD, a little OT.
It’s a modding thread, I don’t think we’re off-topic yet
My wife just got a deep fat fryer, what temp do I need to set it on
I found this statement also in an old thread on the other forum. I can’t find real info why this color changing is happening. You know HA3 won’t work, but why?
And bummer since that would mean no shiny brass colored X5/X6
But wait, for me all this started with this thread:
Hi Freaks. Cause I don’t like the black bezel & tailcap, I changed the color with heat: [image] [image] [image] [image] [image] [image] [image] [image] [image] [image] [image] [image] [image] [image]
And the specs of the Meteor clearly say it IS HAIII!
Hi,
Thanks. I think/hope they should be ok for all browsers now. I think that the SSL links is what might have messed it up.
025
And the specs of the Meteor clearly say it IS HAIII! Puzzled
True HAIII anodizing shouldn’t turn colour when baked. I don’t think there is any true HAIII that isn’t black. Time to question the specs. I’ve blasted real black HAIII with a blow torch with no change at all.
Well too bad, luckely we got the cheap ones! YAY!
Flashlight burning on a stove is very nice to do.
We did it again with the Ultrafire C8.
Tricky, 4 parts that all behave different because size and shape.
The color of the different parts is not a 100% match, we stopped a little too early, so the really brass that the tube of yesterdays had was not reached, however, this looks a lot like copper now.
Also hard to get in nice on picture
Before and after:
I’m in a modding streak I guess. I had promised an Oslon SSL80 4500K 96CRI build in my test thread, and this need was emphasized by Ouchyfoot in his Oslon try-out thread. So I thought let’s make it a nice triple. I had an Eagle Eye X2 spare that had been my bike-light until replaced by the BLF-A6, and one of the shorty tubes from ReManG’s effort fitted it so this has become a 18350 shorty:
Specs from front to rear: clear o-ring instead of green stock one, stock glass lens, Carclo narrow optic, 3xSSL80 4500K 96CRI, triple Noctigon, 20mm diameter x 8.7mm aluminium spacer, flattened brass pill, BLF-A6 driver with 680Ohm bleeder over C1, silicon wire bypassed driver spring, flatted copperwire made into a ring as extra spacer between pill and battery tube because the battery tube is just a bit too short for a 18350 battery, intl-outdoor Be-Cu short spring on tailboard, PD68 switchboard with white small Omten, PD68 dumb six-led lighted washer with 3x 22KOhm resistors and yellow/orange/red leds, translucent silicon tailcover.
I think it has become one of my cleanest mods, every problem was solved with a quality solution.
Measured without the tail it draws around 8 amps on a purple Efest 18350 and about the same with the black Keeppower IMR. 8 amps is a bit too much, I was aiming for 6, but the switch will lower the current somewhat, and the battery drainage will solve it as well
The turbo output at start was 860 djozz-lumen, 725 after 30 seconds. Moon is 0.2 lumen.
Some efficiency numbers. At turbo the efficiency is a mere 26 lumen/W. Even budget cheapies (from the time when they were still using Cree’s btw) did 40 lm/W. It is no wonder, the leds at 2,7A are already on the flat bit at max of the output curve, SSL80 leds have small 1x1mm dies, and you can not make 96CRI for free. At low currents it is much better: level3 is 32 lumen with 56 lm/W, level 4 is 101 lumen with 50 kumen/W.
The tint/colour reproduction is outstanding, less rosy as the Nichia 219A 4500K 92CRI with which I just compared it, but more plain white, I like it even better.
And the tail-illumination is wonderful, a bit less bright than last mod which is much better at night, more an indicator than a bright beacon. The moon mode draws combined 9.6mA because of the bleeder resistor, this limits the moon setting to about 3 days. When off, the tail leds on a fresh battery draw 0.3 mA, assuming that the current lowers a bit when the voltage gets lower, it will drain the battery in about 4 months.
looks like you built a campfire under the tail, nice!
Now if TK could get those to flicker….
That’s some unique looking C8 you’ve made there :laughing:
Just for laughter i did tested this “baking” treatment on a blue convoy s2+ middle piece that i had left from a 18350 conversion
It started from a blue to a weird color that… it had just a little blue but mostly gray
Then few minutes later it started to shift colours again, this time towards golden tint, and for some reason i like it
And some before/after
I might do this to the rest of the flashlight, just to make it a bit different, because why not
Nice mod Jos!
Bobbymk, that is the best color, we should have kept the C8 on the flames a little longer.
You know this YouTube channel Simple cooking?
He uses a song, simple cooking as lyrics, my son and me are running around singing “flashlight cooking”
My wife asked to do hers as well.
And an yellow golden tube we just left on to see where it would stop, a shiny grey.
Next up a SRK
Baking ano goes back a bit here:
With the “Orange Dry” thread here:
Well i decided i love the Dry but the look was well Dry, lol so i decided to follow Chicago and Dthrct, and do something different ,, i flamed mine in the oven ,, the tube could have probably stayed in longer but i decided having it two toned was cool , and if i want i can put it back in the oven to match it up i suppose but for now i think it looks cool , still dont know how to put pics in here so u will have to click on it sry ,, this is actually the first forum i have had trouble with pics an…
…and promptly followed up by the “Dry Orange” thread here:
All this talk about Orange Drys with brown centers got me thinking...why not dry oranges with brown centers? Since you already have the oven fired up after oranging your Dry why not lower the heat and dry your oranges. The wife will be more impressed with your dry orange than she will be with your orange dry. [image] Simply cut slits in your oranges like the ones in the pic above and bake in a low heat (around 150 degrees) for a couple of days until fully dried in the center. Use them for d…
I’ve baked a couple of my lights but don’t really prefer the change. I have used it to separate lights when I have more than one host of the same style, and selectively bake a bezel to make one stand out from the other.
Well I like it, lots of fun.
On the gasflames it is really fast as well
The SRK turned out shiny silver with an extremely light golden tint in the head, very beautifull but very hard to make a pic from.
We have tow mere identical zoomies, 1 is my wifes EDC, she loves it and will not part with it, even though it is not a high quality.
So we baked the second one, t turned out very bright light color, like platinum.
And in the process of doing all the rest my wife liked the new olors and asked us to do hers as well.
We cut off the heat a little sooner to keep it a tad goldenly like.
Here ou go
left the original looks.
middle the first one changed
right the EDC of my wife, she is very content with it.
wight (or anyone),
The images are still not working for me. I tried Chrome and IE.
