5xT6... come on, you know you want to
29 posts / 0 new
weiser
Last seen: 7 years 1 week ago
http://www.cnqualitygoods.com/goods.php?id=1314
That's about $20 lower than the Manafont light, correct? Still too rich for my blood. Especially for SkyRay, which hasn't been too reliable lately it seems.
Edited by: weiser on 11/08/2011 - 01:14
harry25175
harry25175's picture
Last seen: 6 years 8 months ago
niceee...
Tas62
That head with three xm-l's in wider/deeper reflectors than current offerings.
pseudox
Last seen: 6 months 3 weeks ago
I have been looking at this light, Im waiting to buy this until there is a proper review.  Also I saw a warning on manafront not to run the light on high for a long time.  I am excited about a light having 5 emitters this powerful.  I already have a 3xT6 which is very bright as it is.
edc
edc's picture
Last seen: 4 years 5 months ago
I want 6 xml
http://i1193.photobucket.com/albums
weiser
Seriously... doesn't this remind you of the razor commercials: 2 blades for a cleaner cut! Now with 3 blades!! The Schick Quattro!!!
gen1.3_
gen1.3_'s picture
Last seen: 7 years 2 weeks ago
I really dig this light. So who wll be the lab rat? I'm also waiting for a review before I buy it.
2100
Enquired on the tailcap current from Ric, he is able to do it.  It says 5 x 1.5A.  It should get at least 2.5A with good 4.2V cells....to 2.8A for not so charged ones and say TF Flames.
MF just said 1.5A, if it's 1.5A at the tail then forget it.
Noodles
Noodles's picture
Last seen: 1 year 6 months ago
Not sure but don't you go HID at that point?.
My fist is lubed up...
UP my own at this point.
I guess we will have to see beamshots of this from an owner, even @ 1.5a each that is mega.  Can a poor 18650 even pull it off?
If I am wrong in this my hand is still lubed Smile
The Giggle Loop
DrJones
DrJones's picture
Last seen: 3 years 11 months ago
For seriously driving one XM-L you need about one 18650 cell. I'd be interested if that light took 5*18650 - Well, ok, 4*18650 would be interesting, too, like in 2 rows of 2.
benckie
benckie's picture
Last seen: 6 years 12 months ago
ill pass its a fry raY
VFMaddict
Last seen: 1 month 1 week ago
It has often crossed my mind that a 5 emitter light with an XR-E R2 center for extreme throw and four XM-L's around it might be a terrific light.  Just a thought.
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
DrJones
DrJones's picture
Won't work out. That center XR-E would have a very small reflector and thus wouldn't give much throw.
2100
VFM, the beam profile of 4 x XM-L and 1 x XR-E would be quite wierd too.
Driving XM-Ls optimally, ie > 2.5A per emitter, in a 75mm head = DRY kind of performance. Pocket rocket.
TK70 with 105mm head and 3 x XM-L driven optimally raises the head from 30 deg C to 45 deg C in 10 mins of run.  I think this Sky Ray gives about the same performance in lumens OTF, maybe 35k cd of throw and around the same heat rise characteristic in a 75mm head, with the 5 emitters driven at 1.5A.
So in a cold country < 10 deg C with some wind, you probably can run continuously....not too bad for close to 2500 lumens OTF.
I am asking Ric to get more info from the "factory" ie specifically the tailcap readings as we all do not trust manufacturer specs. Any info is better than no info, this is not a $50 triple.  Also the availability of spare drives for purchase.
VFMaddict
Actually I was thinking of a new light not a re-work within the current head size.   More like an MRV sized center with smaller XML reflectors around it.   The biggest problem would be the drivers.
SPAMBOT
SPAMBOT's picture
Last seen: 2 years 3 months ago
The lab rat would be me, will post a first impressions & current draw once I get it.
Now with 100% all natural asbestos!
2100
Ok, thanks!  Will count on you man!
FX-32
FX-32's picture
Last seen: 3 years 10 months ago
I think it needs a better driver that pulls 3A on a let's say "Turbo Mode", and then 1,5A on High, etc. That would be nice.
http://www.youtube.com/watch?v=RH6_MaUFM10
2100
Problem is it won't be able to do this with 3 x 18650 safely.  That means at least 5A from the cells...
FX-32
FX-32's picture
Well, But there are a few high discharge rate batteries around...
2100
If you read Manafont and forums threads here, people are already having issues with 2.5A discharge rate (and ramping up to low 3 amps).  With this one it would go up to 7A.  Slot in a TF/UF unprotected battery and it would surely go BAM.
Spivey
Last seen: 7 years 1 month ago
What about a good dose of AS5 & run 3 AW 18650 IMR's?
You could throttle it back when it gets too hot...
On the other hand, I don't know if SkyRay's paid attention to the many concerns posted about their quality.
2100
Too dangerous.  Can't rely on regular humans for even 80% reliability.  LOL!
Actually, AW 18650 IMRs are also feeling the heat at 6A, believe it or not.  And would really be very short burn time.  Really makes no sense.
ttwhin
Last seen: 8 years 1 month ago
adaptor SKY RAY L1
battery tube SKY RAY L1
Seems it have an adapter-ring.  May(be) it can be fitted with bigger diameter battery tube  D size perhaps? Cool   Fenix TK70 have 4, so this should could manage with 4 or 5 Ni-MH ? If one need to go bigger and safe current..
gen1.3_
gen1.3_'s picture
SPAMBOT thanks for taking one for the team. Will be patiently waiting for your first impressions and amp readings.
FlashPilot
FlashPilot's picture
Last seen: 21 hours 37 min ago
+1. My fingers are crossed for you spambot. I hope this turns out to be a descent light.
pseudox
Thanks spambot for your early adopting courage, looking forward to seeing how good this light is.
SPAMBOT
SPAMBOT's picture
I have it in my possession now, and apart from a dented bezel it is quite a nice light Cool
benckie
benckie's picture
I think this will be much better and its has a claimed max current draw of 7.5 amps not 1.5 amps like the skyray, it does not have to fry ray name, looks much better, but it is $2.80 usd more, But you can run either 18650,s or 26650,s.
So i just brought one.
TrustFire TR-J12 Cree XM-L T6 5-LED 4500-Lumen 5-Mode Memory Flashlight - Black Aluminum Alloy Finish (3  x 26650/3 x 18650)
As soon as it get,s here ill do a review and some long run time test, range test, current draw and i might even have to pull out the new lux meter.
