Also used to wrap firearms/equipment for hunting…
Yes, forgot to mention that. It’s very nice as it’s removable without leaving any residue whatsoever.
length really only 200mm/20cm?
The length of the tape is 200cm long.
We would update it asap.
Thanks for your reminder.
Some new flashlights have appeared on Kaidomain.
D1326 Cree XM-L2 U3 White 1000 Lumens Stepless Adjusted Diving LED Flashlight - Black ( 1x32650 ) for $29.91
DP150 Cree XHP50 White 1800 Lumens Stepless Adjusted Diving LED Flashlight - Black ( 2x26650 ) for $42.10
DP170 Cree XHP70 White 2000 Lumens Stepless Adjusted Diving LED Flashlight - Black ( 2x26650 ) for $49.43
hm…what it mean,if my order is still 6 days Order Pending status?…cant wait to get it of course.but so long??
you ordered during chinese new year it sounds like
That would most likely be the reason for the delay. If the order isn’t processed within a few more days I’d suggest you approach the Kaidomain customer support
http://www.kaidomain.com/home/contactus initially to learn of progress.
Dear Vresto,
Sorry for any inconvenience cause to you.
Since there is Chinese New Year holiday on last week, some package would be delayed for some days. I am sorry for the delay. We would try our best to process and ship out your order asap. Hope you can understand with us.
You can PM me with your order number and i can help to follow it.
If you have any question, please feel free to contact me.
Best Regards
Ban
Two New Cree XP-L HI LED arrival to KD.
Cree XP-L HI V3 1A White 6500K LED Emitter
http://www.kaidomain.com/product/details.S024900
Cree XP-L HI V2 4B Neutral White 4500K - 4700K LED Emitter
http://www.kaidomain.com/product/details.S024831
Cree XHP35 HI D4 1A White 6500K LED Emitter
http://www.kaidomain.com/product/details.S024903
Thanks
3 Mode 3A C2/C8 dropins down to $9.99 These use the KD V2 Driver.
Cree XP-L HI 3000K Warm White 3-Mode Type 2 Copper Drop-in for C8/C2 LED Flashlight (Dia. 25.8mm)
Cree XP-L HI 3000K Warm White 3-Mode Type 1 Copper Drop-in for C8/C2 LED Flashlight (Dia. 25.8mm)
Glad to see these tints in a C8 drop in. I’m not sure the drop-in would be compatible with my non KD C8’s, so I may have to wait for them to release the entire light . . . or buy an XM-L2 C8 and one of these drop-ins too. Does anyone have a XP-L HI in a C8? Is it too throwy? I got one of the P60 drop-ins from KD with the HI and it seems to throw like a XM-L in a C8.
Anyone know whether these C8 drop-ins work with any other brands besides Kaidomain? I’ve got a Thorfire C8, Thorfire C8s, Convoy C8 and a generic C8 (I think it’s an Ultrafire clone).
I would think it would be most likely to work in the ultrafire. I have several of these pills, we could compare measurements. I do not have a metric pitch gauge.
Possible except for the Convoy C8. Don't have a ThorFire C8 but have several generic brands, and found these pills to fit some of them. It's a lot of hit n' miss.
I used to be known as the "C8 guy" (then the "Super Shocker" guy) here a ways back . Had a lot of variety of them, lots of mods back before our own FET drivers.
And don’t forget that these pills fit in your UF-T20
Kaidomain, after several years, even though they seemed to have been asleep for a while, are still selling some good original own stuff, a variety of leds that are not seen anywhere else, really good drop-ins, own drivers, flashlights with a good choice of emitters, many many types and sizes lenses, reflectors and other optics. Nice!
All I know is I have at least 15 C8’s of many makes and these pills didn’t fit any of them.
Only fit my one KD C12, but not the other one which was only 8 months older than the new one and was also a KD model.
I used the driver on another light and pulled the XPL HI for another light.
Still a good deal, just wish the brass pill could be put to use in other lights.
Just my experience.
Later,
Keith
For the $10 risk, I think I’ll pass.
If I’m going to throw away money, I’d rather pick up another Ganzo knife that-I-don’t-need rather than a pill that might-not-work-and-I-don’t-need.
Or send it to my favorite Presidential candidate, again that-I-don’t-need.
Hi guys
Thanks for your interesting with KD C8.
There are many different C8 products in the market. As you know, C8 has a very long history. It has many different variation, generation. For the KD C8, it is a standard C8 version.
I will list the measurement for this pill. You can know more that it is supporting to your own C8 or not.
Overall Pill Dimension: 26mm(Dia.) x 13.5mm(Height)
Upper Part:
Outer Part: 26mm(Dia.)
Inner Part: 21mm(Dia.)
Bottom Part:
Outer Part: 19.5mm(Dia.)
Inner Part: 17mm(Dia.)
Thread Spacing: 22mm x 1mm
This pill is better used with the Lens with 2mm thickness.
Best Regards
Ban
djozz,
Thanks for the heads up on fitting the UF-T20.
Just got done doing the swap, retaining ring on the lens was a bear to get loose but after that it was easy.
I left the shorter spring on the KD drop in intact, now the light will accept longer batteries without a fuss and still runs shorter unprotected cells as well.
Now it is bright, great tint and no rings, Got me a new Pocket Rocket:)
What do estimate the throw/lux to be after this swap?
